Asus Zen Screen MB16ACV 15.6" 1920x1080 5ms Portable Monitor
Quicklinx: GKMDWS00 Mfr#: MB16ACV
Diagonal Size: 16in
Max Resolution: 1920 x 1080
Response Time: 5ms
Interfaces: USB-C
£167.12 ex VAT
£200.54 inc VAT
The ASUS ZenScreen MB16ACV combines a sleek, lightweight design with advanced display technology. This 15.6-inch LED-backlit LCD monitor delivers Full HD (1080p) resolution on an IPS panel, offering vibrant colors and sharp details from virtually any angle with its 178-degree viewing angles. Its anti-glare, antibacterial screen, complemented by ASUS Flicker-Free technology and Low Blue Light Mode, ensures a comfortable viewing experience even during extended use.
Designed for professionals and gamers, the MB16ACV comes equipped with features such as ASUS GamePlus and QuickFit Virtual Scale, enhancing both productivity and gaming sessions. Its portability is further enhanced by a built-in kickstand and the option for tripod mounting, making it an ideal choice for presentations and mobile workstations. With USB-C connectivity, it seamlessly integrates into any workflow, providing both power and video transmission through a single cable. Certified by TUV Rheinland for eye care and energy efficiency, it's an eco-friendly choice for users who demand high-quality technology and sustainability.
  • Sleek and portable design
    ASUS ZenScreen MB16ACV is ideal for life on the road. This sleek portable display weighs just 0.83kg and has a 10.5mm slim profile, so it fits easily in any travel bag and is ready for productivity, anytime and anywhere.
  • One cable is all you need
    ZenScreen MB16ACV uses an innovative USB-C hybrid-signal connection that handles both power and video signals. Its reversible, any-way-up USB-C design allows for quick connections to compatible devices, and there's also a driver that enables support for USB Type-A connectors.
  • Work in comfort
    A fold-out kickstand props the monitor up on any flat surface, enabling easy tilt adjustments to ensure comfortable viewing angles and working positions. A ¼"-threaded hole at the rear of the monitor lets you to attach ZenScreen MB16ACV to a conventional tripod or table-mount easily.
  • Work efficiently in portrait and landscape modes
    With ASUS DisplayWidget software, ZenScreen MB16ACV can automatically sense its orientation and switch the display between landscape and portrait modes while connected to your laptop. Landscape mode is ideal for presentations and spreadsheets, while Portrait mode gives you a perfect view of items such as documents, books or websites.
  • Embedded antibacterial treatment to keep you safe
    A proprietary antibacterial ionic silver treatment embedded in the bezels and rear of ZenScreen MB16ACV offers long-lasting protection, inhibiting up to 99.9% bacterial growth and adhesion to keep key areas of the monitor clean and hygienic. It potentially reduces the spread of harmful bacteria so you can feel safe while working on the go.
  • Extend your workspace
    The FHD (1920 x 1080) IPS panel delivers stunning visuals and 178° viewing angles, ensuring you get superb color and contrast even when viewing the screen from off-center positions.
  • ASUS blue light filter
    Exclusive ASUS Ultra-Low Blue Light technology protects you from potentially harmful blue light. It offers four filter settings that are easily accessed through the onscreen display menu via the hotkey.
  • ASUS Flicker-free technology
    ZenScreen MB16ACV features TÜV Rheinland-certified ASUS Flicker-free technology to reduce flicker, ensuring comfortable viewing experiences. This technology helps minimize eyestrain and other ailments typically associated with extended hours of viewing.
ASUS ZenScreen MB16ACV - LED monitor - Full HD (1080p) - 16"
LED-backlit LCD monitor - 16"
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/399648
Energy Class
Class B
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.179 mm
Brightness
250 cd/m²
Contrast Ratio
800:1
Response Time
5 ms (grey-to-grey)
Colour Support
260,000 colours
Input Connectors
USB-C
Screen Coating
Anti-glare, antibacterial
Voltage
35.79 cm x 1.05 cm x 22.48 cm
830 g
TUV Rheinland Low Blue Light Certification, TUV Rheinland Flicker Free Certification
Display Type
Energy Class
Class B
Diagonal Size
16"
Viewable Size
15.6"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.179 mm
Brightness
250 cd/m²
Contrast Ratio
800:1
Colour Support
260,000 colours
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
60 Hz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
HDCP, Trace Free Technology, ASUS Splendid Video Preset Mode, ASUS QuickFit Virtual Scale, ASUS GamePlus, Low Blue Light Mode, Flicker Free technology, Colour Temperature Selection, ASUS BacGuard, Display Widget
830 g
USB-C
Tripod mountable, built-in kickstand
ZenScreen sleeve
1 x USB-C cable , 1 x USB-C to USB-A adapter
Input Voltage
6 kWh/1000h
Power Consumption (Typical)
15 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption (Off Mode)
0.3 Watt
Shipping Width
43.3 cm
Shipping Depth
8.2 cm
Shipping Height
28.3 cm
Shipping Weight
2.7 kg
Diagonal Size: 16in
Response Time: 5ms
Interfaces: USB-C
Brand: Asus
