Asus Z87-Plus High Performance Z87 chipset mainboard with mDP, HDMI, DVI and D-Sub Outputs.
The Asus Z87-Plus motherboard supports Intel® 4th generation Core™ i7/i5/i3/Pentium®/Celeron® processors in the LGA1150 package, with iGPU, memory and PCI Express controllers integrated to support onboard graphics output with dedicated chipsets, 2-channel (4 DIMM) DDR3 MHz memory and 16 PCI Express 3.0/2.0 lanes. This provides great graphics performance. Intel® 4th generation Core™ i7/i5/i3/Pentium®/Celeron® processors are among the most powerful and energy efficient CPUs in the world.
The Intel® Z87 Express Chipset is a single-chipset design to support socket 1150 4th generation Intel® Core™ i7/i5/i3/Pentium®/Celeron® processors. It provides improved performance by utilizing serial point-to-point links, allowing increased bandwidth and stability. Additionally, Z87 chipset provides maximum 6 USB 3.0 ports and maximum 6 SATA 6Gb/s ports for faster data retrieval speed. Moreover, Intel® Z87 Express Chipset also supports iGPU function, letting users enjoy the latest Intel integrated graphic performance.
- Fan Expert2 - customize Fan speeds
- Digi+VRM - Precise Over Clocking
- USB BIOS Flash Back - Easy Bios Updates
- USB 3.0 Boost - Fast Data Transfer
- EPU - Green Energy saving
- New UEFI Bios Design.
One-stop PC remote control and home entertainment
Remote GO! links PCs, tablets, smartphones, and TVs wirelessly through a LAN cable and router. It allows you to stream multimedia content from PC to DLNA devices, access your computer anywhere using smart devices at home, and easily transfer files to and from your PC. Now upgraded with Cloud GO!, which syncs your multiple cloud storage accounts and backs up content to your PC with one click. -
Exclusive EZ mode adds useful info to become even easier
Media-renowned UEFI BIOS from ASUS provides the smoothest mouse-controlled graphical BIOS, and now features more intuitive functions to quickly take you to favorite BIOS pages and frequently-accessed settings through custom shortcuts. You can even write quick notes in-BIOS for future reference, view an activity log of setting changes and modifications, and rename SATA ports. EZ mode has a whole look, upgraded with extra-friendly capabilities like detailed fan controls, XMP profile settings, SATA information, and fast clock adjustment. Together, these perfect your BIOS experience. -
170% faster transfer speeds than traditional USB 3.0
ASUS USB 3.0 Boost technology supports UASP (USB Attached SCSI Protocol) USB 3.0 in Windows 8. With USB 3.0 Boost technology, a USB device's transmission speed is significantly increased up to 170%, adding to already fast USB 3.0 performance. ASUS software automatically accelerates data rates for compatible USB 3.0 peripherals without any user interaction. -
One-stop access to ASUS features
ASUS AI Suite 3 offers a user experience through a clearer and more attractive interface with support for larger monitors. It consolidates all exclusive ASUS features into one simple-to-use package, allowing you to supervise overclocking, energy consumption, fan speeds, voltages and more. This all-in-one app offers diverse and easy to use functionality, with no need to switch back and forth between different utilities. -
Dedicated direct BIOS access button
Designed for those requiring frequent BIOS access, users can easily enter the BIOS when the PC is on standby power with a simple press of a button. It saves you time during boot-up as you don't have to repeatedly press the DEL key. Convenience and ease at their best! -
Precise digital power control for both CPU and DRAM
Power control is one of the most essential motherboard designs. Intelligent CPU power draw detection with ASUS DIGI+ Power Control is an innovative, powerful technology that fully complies with Intel VRD12.5 specifications, increasing overclocking potential, enhancing system stability, and improving power efficiency with superior flexibility and accurate control. -
Discover future visual experiences
Following up on popular 1080p Full HD, 4K Ultra HD is the next big thing, and you're ready for the upgrade thanks to integrated graphics that natively support up to 4096 x 2160 via HDMI or DisplayPort. That's four times the pixel count of 1080p (1920 x 1080), offering incredible visual clarity, detail, and realism.
- ASUS Z87-PLUS - motherboard - ATX - LGA1150 Socket - Z87
- Product Type
- Motherboard - ATX
- Chipset Type
- Intel Z87 Express
- Processor Socket
- 1 x LGA1150 Socket
- Compatible Processors
- Pentium, Celeron, Core i5, Core i7
- Max RAM Size
- 32 GB
- RAM Supported
- 4 DIMM slots - DDR3, non-ECC, unbuffered
- Storage Ports
- 6 x SATA-600 (RAID), 2 x SATA-600
- USB / FireWire Ports
- 6 x USB 3.0 + (2 x USB 3.0 + 8 x USB 2.0 via headers)
- Max Allocated RAM Size
- 1024 MB
- Audio
- HD Audio (8-channel)
- LAN
- Gigabit Ethernet
- Microsoft Certification
- Compatible with Windows 7
- Product Type
- Motherboard - ATX
- Chipset Type
- Intel Z87 Express
- Processor Socket
- LGA1150 Socket
- Max Processors Qty
- 1
Supported RAM
- Max Size
- 32 GB
- Technology
- DDR3
- Bus Clock
- 2400 MHz, 2200 MHz, 2000 MHz, 1800 MHz, 1600 MHz, 1333 MHz, 1866 MHz, 2133 MHz, 2800 MHz, 3000 MHz, 2600 MHz, 2666 MHz, 2500 MHz, 2933 MHz
- Supported RAM Integrity Check
- Non-ECC
- Registered or Buffered
- Unbuffered
- Dual channel memory architecture, Intel Extreme Memory Profiles (XMP)
Graphics
- 1024 MB
Audio
- Audio Codec
- Realtek ALC892
- High Definition Audio
LAN
- Network Controller
- Intel I217V
- Network Interfaces
- Gigabit Ethernet
- Expansion Slots
- 1 x CPU , 4 x DIMM 240-pin , 2 x PCIe 3.0 x16 (dual x8 mode; single card: x16 mode) , 1 x PCIe 2.0 x16 (x2 mode) , 2 x PCIe 2.0 x1 , 2 x PCI
- Storage Interfaces
- SATA-600 -connectors: 6 x 7pin Serial ATA - 6 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5 , ASMedia ASM1061: SATA-600 -connectors: 2 x 7pin Serial ATA - 2 devices
- RAID Features
- Intel Smart Response Technology
- 1 x PS/2 keyboard / mouse , 1 x HDMI , 1 x LAN (Gigabit Ethernet) , 6 x USB 3.0 , 1 x DVI-D , 1 x VGA , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x audio line-out (side surround) - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack , 1 x microphone - mini-jack , 1 x TOSLINK , 1 x Mini DisplayPort
- Internal Interfaces
- 8 x USB 2.0 - header , 2 x USB 3.0 - header , 1 x SPDIF out - header , 1 x audio - header
- Power Connectors
- 24-pin main power connector, 8-pin ATX12V connector
- BIOS Type
- AMI
- BIOS Features
- WfM 2.0 support, Multilingual BIOS, ASUS Quiet Thermal Solution, ASUS EZ Flash 2, ASUS O.C. Profile, USB BIOS Flashback, UEFI BIOS, SMBIOS 2.7 support, DMI 2.7 support, ACPI 5.0 support
- Sleep / Wake Up
- Wake on LAN (WOL)
- Hardware Features
- C.P.R. (CPU Parameter Recall), jack retasking, ASUS Anti-Surge Protection, MemOK!, ASUS Q-Design, ESD Guards, Q-DIMM, ASUS EZ DIY, Q-LED, Q-Slot, CrashFree BIOS 3, ASUS Q-Connector, All-Solid Capacitor motherboard Design, audio jack detect technology, ASUS EPU (Energy Processing Unit), ASUS Precision Tweaker 2, Intel Extreme Memory Profile (XMP) support, NVIDIA Quad SLI Technology Support, Intel Turbo Boost Technology 2.0, ASUS TPU (TurboV Processing Unit), ASUS DIGI+ VRM, Intel Clear Video HD Technology, Intel Smart Response Technology, Fanless Design Heatsink, USB 3.0 Boost, ASUS 8 Phase CPU Power Design, AMD Quad CrossFireX technology support, ASUS DIGI+ Power Control, ASUS Fan Xpert 2, ASUS Network iControl, ASUS USB Charger+, Intel Rapid Start Technology, Intel Smart Connect Technology, ASUS 2 Phase DRAM Power Design, Intel InTru 3D Technology, Intel Insider, Intel Quick Sync Video, ASUS Remote GO!, DirectKey, Disk Unlocker, ASUS 5X PROTECTION, 4K Ultra HD ready, Intel Dynamic Storage Accelerator, Dual Intelligent Processors 4
- Included Accessories
- I/O back plate
- Cables Included
- 1 x SLI bridge , 3 x Serial ATA cable
- Software Included
- Drivers & Utilities, ASUS EZ Flash 2, ASUS AI Charger+, ASUS AI Suite III
- Plug and Play, RoHS, ErP Ready, ACPI 5.0
- 30.5 cm
- 23.37 cm
Asus Z87-PLUS S1150 Intel Z87 DDR3 ATX
