Asus X555LA-XX3016T Intel Core i3-5005U 4GB 1TB 15.6" Win 10 Home
Quicklinx: CQVDWS00 Mfr#: X555LA-XX3016T
  • Core i3
  • Bluetooth 4.0
  • IEEE 802.11n
The ASUS X Series is the perfect all-round value laptop for work and play. Powered by fast processors, the X Series is a stylish notebook designed for those looking to stand out from the crowd. The X Series immerses you in high quality ASUS SonicMaster-enhanced audio; and gives you a 2-second resume from sleep mode, so it's always ready at a moment's notice. What's more, there's also USB 3.0 for super-fast data transfer speeds.
  • Quality notebook with a premium feel
    A value notebook doesn't have to mean settling for something basic. ASUS X Series notebooks give you all the computing essentials in a notebook with a tactile finish and a high quality, premium feel. It covers all the bases, making it the ideal choice for all your computing needs.
  • It's all in the details
    With various finishes and colors to choose from, the ASUS X Series notebooks let you express your personal style. But it's not just about looks; X Series has all the necessary features and ports you require for everyday computing. After all, it's the little details that count.
  • Designed for productivity and entertainment
    ASUS X Series notebooks are powered by fast processors for smooth, responsive performance. This processing performance, coupled with powerful graphics and an advanced onboard memory controller, makes the X Series ideal for daily computing tasks or for watching movies and videos. X Series tackles them all with ease, giving you all the multitasking performance you need for work or play within a compact chassis.
  • Lifelike colors with ASUS Splendid technology
    Developed by the ASUS Golden Eye team, the exclusive ASUS Splendid technology gives you accurate colors and color temperature. It delivers brilliant, vibrant colors by fine-tuning various display settings and parameters.
  • Various modes for different scenario choices
    ASUS Splendid technology gives you four different video settings to suit whatever is on screen, ensuring you get only the very best visuals. It enhances images to give you richer, deeper colors for stunning visuals whether you're watching videos and movies, or browsing through photos.
  • Notebook with smartphone-like accessibility
    With the ASUS X Series, you get a notebook with smartphone-like response times. It features a 2-second instant resume, so you can go from sleep mode to surfing the net or working on documents in a jiffy. X Series notebooks even give you various optimized power modes so you get the most life out of your battery. They can even remain in standby mode for an incredible two weeks! You needn't worry about losing data during that time too, since it automatically gets backed up when the battery level drops below 5% charge.
  • Extensive connectivity options
    ASUS X Series notebooks feature USB 3.0, HDMI and VGA ports, a 3-in-1 SD/SDHC/SDXC card reader, and other connectivity options to ensure compatibility with a wide range of peripherals and devices.
  • USB3.0 for ultra-fast data transfers
    USB 3.0 gives you ten times the speed of USB 2.0, allowing you to save photos, or transfer music and large video files in a fraction of the time.
  • Full HD 1080p output through HDMI
    On top of the standard VGA port, ASUS X Series notebooks also feature a HDMI port for Full HD 1080p output.
  • Immersive, crystal-clear audio
    Most notebooks feature small onboard speakers that often result in a single-source audio that lacks distinctiveness. ASUS X Series notebooks deliver high-fidelity audio thanks to ASUS SonicMaster technology and ASUS AudioWizard. Be immersed in the X Series' omnidirectional audio delivery and hear music the way it's supposed to be heard.
  • Precise input and control at your fingertips
    ASUS X Series notebooks are designed to give you a more intuitive touchpad experience.
  • Ergonomically designed keyboard
    The full size, one-piece chiclet keyboard features an improved back-assembled design with 1.6mm of key travel and minimal key float for a solid feel and a more comfortable typing experience.
  • Keeping your palm rest cool
    ASUS notebooks feature a unique internal design that addresses uncomfortable heat issues by preventing heat build-up under the palm rest. ASUS IceCool technology keeps the palm rest at a temperature range between 28?C to 35?C, this is significantly lower than body temperature, making typing a little bit more comfortable for you.
ASUS X555LA-XX3016T - 15.6" - Intel Core i3 - 5005U - 4 GB RAM - 1 TB HDD
Notebook
Operating System
Win 10 Home 64-bit
Intel Core i3 (5th Gen) - 5005U / 2 GHz / 3 MB Cache
4 GB DDR3 (provided memory is soldered)
Storage
1 TB HDD / 5400 rpm
Optical Drive
DVD SuperMulti
Display
15.6" LED backlight 1366 x 768 / HD
Graphics
Intel HD Graphics 5500
Numeric Keypad
Integrated Webcam
802.11b/g/n, Bluetooth 4.0, Gigabit Ethernet
2-cell
Matte silver IMR (top), black IMR with matte spin texture (LCD cover)
38.2 cm x 25.6 cm x 2.58 cm
2.3 kg
Environmental Standards
- EPEAT Climate+
Notebook
Operating System
Windows 10 Home 64-bit Edition
Processor / Chipset
CPU
Intel Core i3 (5th Gen) 5005U / 2 GHz
Number of Cores
Dual-Core
Cache
3 MB
64-bit Computing
RAM
4 GB (provided memory is soldered)
Max RAM Supported
12 GB
DDR3 SDRAM
Speed
1600 MHz
Slots Qty
1
Empty Slots
1
Storage
Main Storage
1 TB HDD SATA / 5400 rpm
Optical Drive
DVD±RW (±R DL) / DVD-RAM
Display
15.6"
LCD Backlight Technology
LED backlight
Resolution
1366 x 768 (HD)
Widescreen
Image Aspect Ratio
16:9
Image Brightness
200 cd/m²
Colour Gamut
45% NTSC
ASUS Splendid Video Intelligence Technology, glare
Audio & Video
Graphics Processor
Camera
Yes - VGA
Sound
Stereo speakers, microphone
Audio Features
Output: ASUS SonicMaster, ASUS Bang & Olufsen ICEpower, ASUS AudioWizard
Input
Keyboard, touchpad
Numeric Keypad
ASUS Smart Gesture technology
Communications
Wireless
Network Interface
Gigabit Ethernet
2-cell lithium polymer
37 Wh
AC Adapter
Input
Output
45 Watt, 19 V, 2.37 A
Connections & Expansion
Interfaces Details
Headphone/microphone combo jack , 2 x USB 3.0 , VGA , USB 2.0 , HDMI , LAN
Memory Card Reader
Yes (SD Card)
Software
Software Included
Dropbox (25 GB Cloud Storage)
System password, hard drive password, ASUS IceCool design, ASUS USB Charger+
Theft/Intrusion Protection
Power adapter
2.3 kg
Sustainability Information
TCO Certified
EPEAT Compliant
EPEAT Climate+
