Asus X551CA-SX029H Cel 1007U 4GB 500GB 15.6" DVDRW Win8
Quicklinx: 92CFWS00 Mfr#: X551CA-SX029H
  • Celeron
  • Windows 8 64-bit Edition
  • IEEE 802.11n
The ASUS X series is the perfect all-round laptop for work and play. Stylish and durable design is combined with Intel processor, while 2-second instant on gives smartphone like accessibility and SonicMaster technology gives great sound quality.
Value-packed with all the essentials, the X series reinvents your daily computing experience. Whether you are using it for work or for fun, this is an ideal machine for both productive computing and entertainment. It features Intel processor and Instant on that resumes your computer from sleep mode in 2 seconds and USB 3.0 for 10 times faster data transfer speed. ASUS X series gives you everything you need for a truly satisfying multitask computing and multimedia experience.
  • Incredible beauty: a classic, timeless design
  • Incredible performance: providing a smooth computing experience
  • Incredible sound: precise, crystal clear audio to complete the cinematic experience
    On most notebooks, all sound frequencies originate from small onboard speakers. The resulting audio comes from a single source and lacks distinctiveness. Like other notebooks in the ASUS range, the X series comes equipped with SonicMaster technology and ASUS AudioWizard to bring you high fidelity audio. Experience omnidirectional sound and hear each individual instrument's nuances with the X series.
  • Incredible touch: precise input
    The X series has a large touchpad equipped with Smart Gesture technology for quick and precise response across a wide range of touch inputs. The ergonomic seamless one-piece keyboard is designed to provide you the most comfortable typing experience.
ASUS X551CA-SX029H - 15.6" - Intel Celeron 1007U - 4 GB RAM - 500 GB HDD
Notebook
Operating System
Win 8 64-bit
Intel Celeron 1007U / 1.5 GHz ULV / 2 MB Cache
4 GB DDR3 (provided memory is soldered)
Storage
500 GB HDD / 5400 rpm
Optical Drive
DVD SuperMulti
Display
15.6" LED backlight 1366 x 768 / HD
Graphics
Intel HD Graphics
Numeric Keypad
Integrated Webcam
802.11b/g/n, 10/100 Ethernet
4-cell
38 cm x 25.1 cm x 3.659 cm
2.15 kg
Environmental Standards
ENERGY STAR Qualified
Notebook
Operating System
Processor / Chipset
CPU
Number of Cores
Dual-Core
Cache
2 MB
64-bit Computing
Power Efficiency
Ultra Low Voltage (ULV)
Chipset
Mobile Intel HM70 Express
RAM
4 GB (provided memory is soldered)
DDR3 SDRAM
Speed
1600 MHz
Storage
Main Storage
500 GB HDD SATA 3Gb/s / 5400 rpm
Optical Drive
DVD±RW (±R DL) / DVD-RAM
Display
15.6"
LCD Backlight Technology
LED backlight
Resolution
1366 x 768 (HD)
Widescreen
Image Aspect Ratio
16:9
Glare
Audio & Video
Graphics Processor
Intel HD Graphics
Camera
Sound
Stereo speakers, microphone
Audio Features
Output: ASUS SonicMaster, ASUS Bang & Olufsen ICEpower, ASUS AudioWizard, MaxxAudio
Input
Keyboard, touchpad
Numeric Keypad
Multi-touch touchpad, ASUS Smart Gesture technology
Communications
Wireless
802.11b/g/n
Network Interface
10/100 Ethernet
4-cell
37 Wh
AC Adapter
Input
Output
45 Watt, 19 V, 2.37 A
Connections & Expansion
Headphone/microphone combo jack , VGA , HDMI , LAN , USB 2.0 , USB 3.0
Memory Card Reader
2 in 1 (SD Card, MultiMediaCard)
Security lock slot (cable lock sold separately), InstantOn, ASUS IceCool design, ASUS Super Hybrid Engine II
Power adapter
UL, BSMI, CB, JATE, CCC, FCC, RoHS, CECP
2.15 kg
Sustainability Information
ENERGY STAR Certified
