Faster and easier connections with USB Type-C
The reversible USB Type-C port makes connecting devices much easier; and gives you super-fast USB 3.1 speeds so you can transfer a movie to a USB drive in seconds. Its compact port design even helps preserve X540YA's thin dimensions. -
Crafted speaker design for greater sound
The X540YA features round speakers that maximize every cubic millimeter of available chassis space to give you better low frequency performance and reduced noise. -
Elegant finished, lightweight design
ASUS X540YA has a solid and lightweight chassis - ideal to take with you when you're out and about. Its premium brushed finish turns heads and makes sure that you stand out from the crowd.
- ASUS VivoBook X540YA XX020T - 15.6" - AMD E1 - 7010 - 4 GB RAM - 1 TB HDD
- Product Type
- Notebook
- Operating System
- Win 10 Home 64-bit
- Processor
- AMD E1 7010 / 1.5 GHz / 1 MB Cache
- Memory
- 4 GB DDR3L (provided memory is soldered)
- Storage
- 1 TB HDD / 5400 rpm
- Optical Drive
- DVD SuperMulti
- Display
- 15.6" LED backlight 1366 x 768 / HD
- Graphics
- AMD Radeon R2
- Integrated Webcam
- Networking
- 802.11b/g/n, 10/100 Ethernet
- Battery
- 3-cell
- Chocolate black IMR with hairline (LCD cover), gold IMR with hairline (top)
- 38.1 cm x 25.2 cm x 2.72 cm
- 2 kg
- Environmental Standards
- - EPEAT Climate+
- Product Type
- Notebook
- Operating System
- Windows 10 Home 64-bit Edition
Processor / Chipset
- CPU
- Number of Cores
- Dual-Core
- Cache
- 1 MB
- 64-bit Computing
- RAM
- 4 GB (provided memory is soldered)
- Technology
- DDR3L SDRAM
- Speed
- 1600 MHz
- Form Factor
- SO-DIMM 204-pin
Storage
- Main Storage
- 1 TB HDD SATA / 5400 rpm
- Optical Drive
- DVD±RW (±R DL) / DVD-RAM
Display
- 15.6"
- LCD Backlight Technology
- LED backlight
- Resolution
- 1366 x 768 (HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Image Brightness
- 200 cd/m²
- Colour Gamut
- 45% NTSC
- ASUS Splendid Video Intelligence Technology, glare
Audio & Video
- Graphics Processor
- AMD Radeon R2
- Camera
- Yes - VGA
- Sound
- Stereo speakers, microphone
- Audio Features
- Output: ASUS SonicMaster, ASUS Bang & Olufsen ICEpower, ASUS AudioWizard
Input
- Keyboard, touchpad
- ASUS Smart Gesture technology
Communications
- Wireless
- 802.11b/g/n
- Network Interface
- 10/100 Ethernet
- Technology
- 3-cell Lithium Ion
- Capacity
- 33 Wh
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 45 Watt, 19 V, 2.37 A
Connections & Expansion
- Interfaces Details
- Headphone/microphone combo jack , USB 3.0 , VGA , USB 2.0 , HDMI , LAN , USB-C Gen 1
- Memory Card Reader
- Yes (SD Card, SDHC Card, SDXC Card)
- System password, hard drive password, ASUS IceCool design
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- Included Accessories
- Power adapter
- 2 kg
Sustainability Information
- TCO Certified
- EPEAT Compliant
- EPEAT Climate+
