Asus VZ27AQ 27" 2560x1440 IPS Monitor
Quicklinx: CXNHWS00 Mfr#: VZ27AQ
Diagonal Size: 27in
Max Resolution: 2560 x 1440
Response Time: 5ms
Speakers: Speaker(s)
Interfaces: DisplayPort, HDMI, VGA (HD-15)
£270.46 ex VAT
£324.55 inc VAT
ASUS VZ27AQ has a space-saving design with an ultra-slim profile. Its frameless design makes it perfect for almost-seamless multi-display setups that give you an even greater degree of immersion. An advanced high-performance IPS panel gives you an astonishing 80,000,000:1 contrast ratio and wide 178° viewing angles. In addition, ASUS Eye Care technology ensures a comfortable viewing experience.
  • Ultra-slim profile
    VZ27AQ takes up very little desktop space and fits well in any setting.
  • See better with WQHD resolution
    Prepare to be amazed as you experience exceptional 2560 x 1440 resolution visuals with the VZ27AQ. With its 27" WQHD display, VZ27AQ gives you sharper images and more onscreen space than a similarly sized Full HD display - allowing you the freedom to spread out your various desktop windows.
  • Perfect for multi-display setups
    Whether you're playing games, watching a movie, or getting some work done, VZ27AQ's frameless design means two or three monitor setups are virtually seamless, giving you a panoramic display for an even greater degree of immersion.
  • Ultra-low Blue Light monitor
    The ASUS Blue Light Filter protects you from harmful blue light, and you can easily access its four different filter settings via a hotkey.
  • Flicker-Free technology
    It's time to say goodbye to those tired, strained eyes. VZ27AQ features ASUS Flicker-Free technology to reduce flicker for a comfortable viewing experience. This technology helps minimize instances of eyestrain and other damaging ailments, especially when you spend long, countless hours in front of a display watching favorite videos.
  • Wide 178° viewing angles
    VZ27AQ has an advanced high-performance IPS panel that provides an astonishing 80,000,000:1 contrast ratio and wide 178°viewing angles. This LED-backlit display covers the entire sRGB color space - ensuring extremely accurate color reproduction for professional-grade photo and video editing, or for home entertainment.
ASUS VZ27AQ - LED monitor - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class A
Energy Consumption per Year
35 kWh
Power Consumption (On mode)
24 W
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
WQHD 2560 x 1440
Pixel Pitch
0.233 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 80000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Colour Support
1.074 billion colours (10-bit)
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
Tilt
Screen Coating
Anti-glare
Black, icicle gold
61.27 cm x 21 cm x 44.08 cm
4.26 kg
Environmental Standards
TCO Certified Displays 8, ENERGY STAR Qualified
UL, VCCI, cUL, WHQL, CB, CCC, PSB, FCC, RoHS, KCC, WEEE, J-MOSS, ErP Ready, TUV Rheinland Low Blue Light Certification, CU, TUV Rheinland Flicker Free Certification
3-year warranty
Display Type
Energy Class
Class A
35 kWh
24 W
Diagonal Size
27"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
WQHD 2560 x 1440
Pixel Pitch
0.233 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
49 - 76 Hz
Horizontal Refresh Rate
29 - 130 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
WLED
Ultra Slim Design, HDCP, frameless, ASUS Smart Contrast Ratio (ASCR), ASUS Splendid Video Preset Mode, 100% sRGB colour gamut, ASUS GamePlus, Low Blue Light Mode, Flicker Free technology, ASUS EyeCare Technology, Blue Light Filter technology, Adaptive-Sync technology, Colour Temperature Selection
Black, icicle gold
61.27 cm x 21 cm x 44.08 cm - with stand
4.26 kg
Audio
Speakers - stereo
Output Power / Channel
1.5 Watt
VGA , HDMI , DisplayPort , Audio line-in
Mechanical
Tilt
Tilt Angle
-5/+22
1 x VGA cable , 1 x audio cable
Power Consumption (Off Mode)
0.5 Watt
Dimensions & Weight Details
Without stand - width: 61.27 cm - depth: 3.655 cm - height: 36.82 cm , With stand - width: 61.27 cm - depth: 21 cm - height: 44.08 cm - weight: 4.26 kg
Shipping Width
68.9 cm
Shipping Depth
11.7 cm
Shipping Height
54.4 cm
Shipping Weight
5.295 kg
TCO Certified
ENERGY STAR Certified
Limited warranty - 3 years
Diagonal Size: 27in
Response Time: 5ms
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: Asus
Price Range Ex VAT: 150 - 300
