ASUS VZ27AQ has a space-saving design with an ultra-slim profile. Its frameless design makes it perfect for almost-seamless multi-display setups that give you an even greater degree of immersion. An advanced high-performance IPS panel gives you an astonishing 80,000,000:1 contrast ratio and wide 178° viewing angles. In addition, ASUS Eye Care technology ensures a comfortable viewing experience.
Ultra-slim profile
VZ27AQ takes up very little desktop space and fits well in any setting. -
See better with WQHD resolution
Prepare to be amazed as you experience exceptional 2560 x 1440 resolution visuals with the VZ27AQ. With its 27" WQHD display, VZ27AQ gives you sharper images and more onscreen space than a similarly sized Full HD display - allowing you the freedom to spread out your various desktop windows. -
Perfect for multi-display setups
Whether you're playing games, watching a movie, or getting some work done, VZ27AQ's frameless design means two or three monitor setups are virtually seamless, giving you a panoramic display for an even greater degree of immersion. -
Ultra-low Blue Light monitor
The ASUS Blue Light Filter protects you from harmful blue light, and you can easily access its four different filter settings via a hotkey. -
Flicker-Free technology
It's time to say goodbye to those tired, strained eyes. VZ27AQ features ASUS Flicker-Free technology to reduce flicker for a comfortable viewing experience. This technology helps minimize instances of eyestrain and other damaging ailments, especially when you spend long, countless hours in front of a display watching favorite videos. -
Wide 178° viewing angles
VZ27AQ has an advanced high-performance IPS panel that provides an astonishing 80,000,000:1 contrast ratio and wide 178°viewing angles. This LED-backlit display covers the entire sRGB color space - ensuring extremely accurate color reproduction for professional-grade photo and video editing, or for home entertainment.
- ASUS VZ27AQ - LED monitor - 27"
- LED-backlit LCD monitor - 27"
- Energy Class
- Class A
- Energy Consumption per Year
- 35 kWh
- Power Consumption (On mode)
- 24 W
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- WQHD 2560 x 1440
- Pixel Pitch
- 0.233 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 80000000:1 (dynamic)
- Response Time
- 5 ms (grey-to-grey)
- Colour Support
- 1.074 billion colours (10-bit)
- Colour Gamut
- 100% sRGB
- Input Connectors
- HDMI, VGA, DisplayPort
- Tilt
- Screen Coating
- Anti-glare
- Black, icicle gold
- 61.27 cm x 21 cm x 44.08 cm
- 4.26 kg
- Environmental Standards
- ENERGY STAR Qualified
- UL, VCCI, cUL, WHQL, CB, CCC, PSB, FCC, RoHS, KCC, WEEE, J-MOSS, ErP Ready, TUV Rheinland Low Blue Light Certification, CU, TUV Rheinland Flicker Free Certification
- 3-year warranty
- Display Type
- Energy Class
- Class A
- 35 kWh
- Diagonal Size
- 27"
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- WQHD 2560 x 1440
- Pixel Pitch
- 0.233 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- 100% sRGB
- Response Time
- Vertical Refresh Rate
- 49 - 76 Hz
- Horizontal Refresh Rate
- 29 - 130 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Anti-glare
- Backlight Technology
- WLED
- Ultra Slim Design, HDCP, frameless, ASUS Smart Contrast Ratio (ASCR), ASUS Splendid Video Preset Mode, ASUS GamePlus, Low Blue Light Mode, Flicker Free technology, ASUS EyeCare Technology, Blue Light Filter technology, Adaptive-Sync technology, Colour Temperature Selection
- 61.27 cm x 21 cm x 44.08 cm - with stand
- 4.26 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 1.5 Watt
- VGA , HDMI , DisplayPort , Audio line-in
Mechanical
- Tilt
- Tilt Angle
- -5/+22
- Cables Included
- 1 x VGA cable ¦ 1 x audio cable
- 24 W
- 0.5 Watt
- Dimensions & Weight Details
- Without stand - width: 61.27 cm - depth: 3.655 cm - height: 36.82 cm , With stand - width: 61.27 cm - depth: 21 cm - height: 44.08 cm - weight: 4.26 kg
- Shipping Width
- 68.9 cm
- Shipping Depth
- 11.7 cm
- Shipping Height
- 54.4 cm
- Shipping Weight
- 5.295 kg
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 3 years
