Envision bigger with WQHD! Premium wide-format VX24AH LED displays with 178° wide viewing angle panel for better productivity, opening extra multitasking space to fit more windows and projects on-screen. ASUS exclusive SplendidPlus Video Intelligence technology, QuickFit Virtual Scale, and 100% sRGB fidelity ensure reality-defining color and image accuracy, giving you true "what you imagine is what you create" power. Dual HDMI support WQHD natively, accentuated by room-dominating audio via twin speakers.
See better and wider
The VX24AH WQHD monitor provides high quality visuals. It allows users to view greater image detail and do more with an onscreen footprint larger than that of standard displays. -
Made for work and play
The ASUS VX24AH provides an ultra-wide 178° viewing angle on both horizontal and vertical planes, thereby minimizing onscreen color shift even when viewed from extreme angles. With its WQHD display, you enjoy more desktop space to spread out your windows and palettes. It is also sharper, delivering ultra-smooth visuals thanks to quick response time. This ensures you get lag-free experiences in movies and gaming, with the latter looking more vivid, with all in-game details shown in true color. -
Extensive connectivity
The VX24AH features a host of connectivity options. The HDMI port supports MHL which allows you to use the MHL with HDMI connection to view content from your mobile device on the VX24AH while simultaneously charging the mobile device. Twin built-in speakers provide quality audio for a completely immersive home theater experience. -
QuickFit Virtual Scale for true what you see is what you get
ASUS includes its exclusive QuickFit Virtual Scale feature with the VX24AH, allowing you to preview photos and documents on-screen in their actual size prior to printing. -
ASUS SplendidPlus Video Intelligence technology
ASUS SplendidPlus Video Intelligence technology is built upon a color engine that provides preset modes that allow you to adjust your display accordingly to ensure color accuracy and image fidelity to give you colors that best suit what's showing on the screen. -
ASUS EyeCare technology
The VX24AH is also equipped with the ASUS EyeCare technology. It adopts flicker-free technology which clears out the distracted flicker shown on the screen and delivers a more comfortable viewing experience. -
ASUS VividPixel technology
ASUS VividPixel technology adds to the VX24AH crystal-clear and detailed visuals by enhancing image outlines and reducing noise bars.
- ASUS VX24AH - LED monitor - 23.8"
- LED-backlit LCD monitor - 23.8"
- Energy Label QR Code URL
- Https://eprel.ec.europa.eu/qr/388082
- Energy Class
- Class G
- Energy Consumption per Year
- 36 kWh
- Power Consumption (On mode)
- 26.8 W
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- QHD 2560 x 1440
- Pixel Pitch
- 0.206 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 1000:1 / 100000000:1 (dynamic)
- Response Time
- 5 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 100% sRGB
- Input Connectors
- 2xHDMI, VGA
- Speakers
- Integrated
- Tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 54.05 cm x 21.01 cm x 39.44 cm
- 3.5 kg
- Environmental Standards
- ENERGY STAR Qualified
- UL, VCCI, C-Tick, BSMI, cUL, WHQL, CB, CCC, PSB, FCC, RoHS, J-MOSS, ErP Ready, ISO9241-307
- 3-year warranty
- Display Type
- Energy Class
- Class G
- 36 kWh
- Diagonal Size
- 23.8"
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- QHD 2560 x 1440
- Pixel Pitch
- 0.206 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- 100% sRGB
- Response Time
- Vertical Refresh Rate
- 56 - 76 Hz
- Horizontal Refresh Rate
- 30 - 80 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- LED backlight
- Controls & Adjustments
- Volume, brightness, input select, colour temperature
- HDCP, frameless, ASUS Splendid Video Intelligence Technology, Skin-Tone Selection, Trace Free Technology, ASUS Smart Contrast Ratio (ASCR), ASUS Splendid Video Preset Mode, ASUS QuickFit Virtual Scale, Mobile High-Definition Link (MHL), ASUS GamePlus, ASUS VividPixel Technology, Slim Design, ASUS SplendidPlus Video Intelligence Technology, ASUS EyeCare Technology
- Black
- 54.05 cm x 21.01 cm x 39.44 cm - with stand
- 3.5 kg
Audio
- Speakers - stereo - integrated
- Output Power / Channel
- 2 Watt
- 2 x HDMI , VGA , Audio line-in , Headphones
Mechanical
- Tilt
- Tilt Angle
- -5/+20
- Cables Included
- 1 x audio cable , 1 x VGA cable
- Security Slot Type
- Kensington security slot
- Power Supply
- External
- Input Voltage
- 26.8 W
- Power Consumption SDR (On mode)
- 26.8 kWh/1000h
- Power Consumption (Typical)
- 65 Watt
- Power Consumption Stand by
- 0.5 Watt
- Dimensions & Weight Details
- With stand - width: 54.05 cm - depth: 21.01 cm - height: 39.44 cm - weight: 3.5 kg , Without stand - width: 54.05 cm - depth: 4.02 cm - height: 32.63 cm
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 3 years , Limited warranty - LCD panel - 3 years
