Asus VX229H 21.5" 1920x1080 5ms VGA HDMI IPS LED Monitor
Quicklinx: 9TPMWS00 Mfr#: VX229H
Inspired by millennia of artistic legacy, the VX229H sports an elegant and precision-crafted sundial design. The VX229H features an edge-to-edge frameless panel with 178° ultra-wide viewing angle AH-IPS A+ panel for incredible visuals. It's ultra-slim and ergonomic design can be tilted to provide you comfortable viewing experiences, while dual HDMI/MHL ports offers extensive connectivity options.
VX229H features a 16:9 aspect ratio LED-backlit AH-IPS A+ panel with a 178° wide-view angle that minimizes color shift on both horizontal and vertical planes to ensure quality visuals from almost any direction. AH-IPS is the latest in IPS technology - delivering improved color accuracy plus increased energy efficiency.
  • Superior image quality meets frameless elegant design
  • IPS technology with wide-view angles
  • Extensive connectivity and built-in stereo speaker for multimedia enjoyment
    VX229H comes with rich connectivity including Dual HDMI and D-sub so that users could easily connect it to Full HD Blu-ray Disc players and myriad HD playback devices like DVD players and set-top boxes for limitless entertainment and multimedia enjoyment with the built-in stereo speakers.
  • 80,000,000:1 ASUS Smart Contrast Ratio
    With ASUS Smart Contrast Ratio (ASCR) of 80,000,000:1 and 250 cd/m² brightness, VX229H augments display contrast and sharpness by adjusting backlighting luminance to achieve the deepest blacks and brightest whites for truly lifelike visuals
  • Splendid Video Intelligence technology
    The exclusive Splendid Video Intelligence technology optimizes video performance and image fidelity by enhancing color, brightness, contrast, and sharpness. 6 preset video modes can be selected via a hotkey.
  • QuickFit virtual scale for true what you see is what you get
    ASUS includes its exclusive QuickFit virtual scale feature with the VX229H, allowing you to preview photos and documents on-screen in their actual size prior to printing. It can be activated via a monitor hotkey, and serves as a highly useful guide to accurately view and edit photos in their native size.
ASUS VX229H - LED monitor - Full HD (1080p) - 21.5"
LED-backlit LCD monitor - 21.5"
Energy Class
Class A
Energy Consumption per Year
27.9 kWh
Power Consumption (On mode)
19.1 W
Panel Type
AH-IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 80000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
2xHDMI, VGA
Speakers
Integrated
Display Position Adjustments
Tilt
Voltage
49.98 cm x 21.01 cm x 37.13 cm
3.05 kg
Environmental Standards
ENERGY STAR Qualified
UL, VCCI, C-Tick, BSMI, cUL, WHQL, CB, CCC, FCC, RoHS, WEEE, ErP Ready, CEL
3-year warranty
Display Type
Energy Class
Class A
27.9 kWh
Diagonal Size
21.5"
Panel Type
AH-IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
56 - 76 Hz
Horizontal Refresh Rate
30 - 80 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
Controls & Adjustments
Volume, brightness, input select, colour temperature
Ultra Slim Design, HDCP, frameless, ASUS Splendid Video Intelligence Technology, anti-glare, Skin-Tone Selection, ASUS Smart Contrast Ratio (ASCR), ASUS Splendid Video Preset Mode, Senseye+Photo Image Technology, ultra wide viewing angle, ASUS QuickFit Virtual Scale, ASUS GamePlus
49.98 cm x 21.01 cm x 37.13 cm - with stand
3.05 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
1 Watt
2 x HDMI , VGA , Audio line-in , Headphones
Mechanical
Tilt
Tilt Angle
-5/+20
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), wall mountable
1 x audio cable , 1 x VGA cable
Security Slot Type
Kensington security slot
Power Supply
Internal
Input Voltage
19.1 W
Power Consumption (Typical)
26 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.5 Watt
Sustainability Information
ENERGY STAR Certified
Limited warranty - 3 years
