It's easy for you to reach a desired viewing angle with support of pivot, tilt, height adjustment and swivel functions.
Dynamically enhances the display's contrast by adjusting the luminance of the backlight to achieve the darkest black and brightest white - delivering lifelike images.
50000000:1 ASUS smart contrast ratio
Dynamically enhances the display's contrast by adjusting the luminance of the backlight to achieve the darkest black and brightest white - delivering lifelike images. -
Ergonomic design for personal visual comfort
It's easy for you to reach a desired viewing angle with support of pivot, tilt, height adjustment and swivel functions. -
Splendid Video Intelligence technology
The exclusive Splendid Video Intelligence technology optimizes video performance and image fidelity by enhancing color, brightness, contrast, and sharpness. 6 preset video modes can be selected via a hotkey. -
Mercury-free LED-backlit panel
Corrugated cardboard packaging with at least 80% recycled content. Slim-flat packaging allows more cartons to be fitted per cargo, reducing transportation costs and CO2 emission.
- ASUS VW199TL - LED monitor - 19"
- LED-backlit LCD monitor - 19"
- Power Consumption (On mode)
- 13.1 W
- Panel Type
- TN
- Native Resolution
- 1440 x 900
- Pixel Pitch
- 0.2835 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 50000000:1 (dynamic)
- Response Time
- 5 ms
- Colour Support
- 16.7 million colours
- Colour Gamut
- 72% NTSC
- Input Connectors
- DVI-D, VGA
- Speakers
- Integrated
- Height, pivot (rotation), swivel, tilt
- Voltage
- AC 120/230 V
- Black
- 44.4 cm x 21.4 cm x 36.44 cm
- 5.1 kg
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified
- UL, VCCI, C-Tick, BSMI, cUL, ISO 13406-2, WHQL, CB, CCC, PSB, EK, FCC, RoHS, ISO 9241-307, PSE Mark, GOST-R, J-MOSS
- 3-year warranty
- Display Type
- Diagonal Size
- 19"
- Panel Type
- TN
- Native Resolution
- 1440 x 900
- Pixel Pitch
- 0.2835 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- 72% NTSC
- Response Time
- 5 ms
- Vertical Refresh Rate
- 55 - 75 Hz
- Horizontal Refresh Rate
- 30 - 80 kHz
- Horizontal Viewing Angle
- 170
- Vertical Viewing Angle
- 160
- Backlight Technology
- LED backlight
- Controls & Adjustments
- Volume, brightness, contrast, sharpness, colour temperature
- sRGB colour management, HDCP, ASUS Splendid Video Intelligence Technology, anti-glare, Skin-Tone Selection, ASUS Smart Contrast Ratio (ASCR), ASUS Splendid Video Preset Mode, 72% NTSC colour gamut
- Black
- 44.4 cm x 21.4 cm x 36.44 cm - with stand
- 5.1 kg
Audio
- Speakers - stereo - integrated
- Output Power / Channel
- 1 Watt
- Audio line-in , VGA , DVI-D
Mechanical
- Tilt Angle
- -5/+20
- Swivel Angle
- 90
- Height Adjustment
- 100 mm
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), integrated cable management
- Cables Included
- 1 x VGA cable , 1 x DVI cable
- Power Supply
- Internal
- Input Voltage
- AC 120/230 V
- 13.1 W
- Power Consumption (Typical)
- 27 Watt
- Power Consumption Stand by / Sleep
- 0.2 Watt
- 0.16 Watt
- Power Consumption Sleep
- 0.15 Watt
- Dimensions & Weight Details
- Without stand - width: 44.4 cm - depth: 29.57 cm - height: 6.46 cm
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 3 years , Limited warranty - LCD panel - 3 years
