Asus VW199DR 19" LED Monitor VGA Black
Quicklinx: 8B3BWS00 Mfr#: VW199DR
ASUS VW199DR dynamically enhances the display's contrast by adjusting the luminance of the backlight to achieve the darkest black and brightest white - delivering lifelike images.
Indulge your visual senses with 1440 x 900 resolution and 5 ms quick response time for work and entertainment. The best dual-display companion with your widescreen notebook enlarges the visual space for multi-tasking efficiency. Aspect control function allows users to select a preferred display mode among full and 4:3 for true-to-life gaming or movie watching without any data loss or image distortion.
  • 50,000,000:1 ASUS smart contrast ratio
    Dynamically enhances the display's contrast by adjusting the luminance of the backlight to achieve the darkest black and brightest white - delivering lifelike images.
  • Excellent visual performance
  • Splendid video intelligence technology
    The exclusive Splendid video intelligence technology optimizes video performance and image fidelity by enhancing color, brightness, contrast, and sharpness. 6 preset video modes (scenery, theater, game, night view, sRGB and standard) can be selected via a hotkey.
ASUS VW199DR - LED monitor - 19"
LED-backlit LCD monitor - 19"
Native Resolution
1440 x 900
Pixel Pitch
0.2835 mm
Brightness
250 cd/m²
Contrast Ratio
50000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
VGA
Display Position Adjustments
Tilt
44.4 cm x 21 cm x 36.4 cm
4.2 kg
Environmental Standards
ENERGY STAR Qualified
UL, TUV GS, VCCI, C-Tick, BSMI, cUL, NOM, WHQL, CB, CCC, TUV Ergo, PSB, FCC, RoHS, ISO 9241-307, GOST-R, J-MOSS
3-year warranty
Display Type
Diagonal Size
19"
Native Resolution
1440 x 900
Pixel Pitch
0.2835 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Vertical Refresh Rate
75 Hz
Horizontal Refresh Rate
80 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
LED backlight
Controls & Adjustments
Brightness, contrast, colour temperature, aspect control
ASUS Splendid Video Intelligence Technology, Skin-Tone Selection, ASUS Smart Contrast Ratio (ASCR), ASUS Splendid Video Preset Mode
44.4 cm x 21 cm x 36.4 cm - with stand
4.2 kg
VGA
Mechanical
Tilt
Tilt Angle
25
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), wall mountable, cable organizer
1 x VGA cable
Power Consumption (Typical)
27 Watt
Power Consumption Stand by / Sleep
0.1 Watt
Sustainability Information
ENERGY STAR Certified
Limited warranty - 3 years ¦ Limited warranty - LCD panel - 3 years
