Asus Vulcan Anc Active Noise Cancelling Pro Gaming Headset
Quicklinx: BRQLWS00 Mfr#: 90-YAHI7180-UA00-
The Republic of Gamers is committed to helping you win more through superior audio power, precise positioning, and lifelike immersion - the perfect aids for those critical online shooter moments. Opposing snipers hide in the dark, taking advantage of cover to keep you suppressed? It's time to get your team on the offensive with powerful and precise battleground audio intelligence - thanks to advanced Xonar sound hardware. No more confusion or uncertainty. Clear audio turns you into a virtual online gaming general, and paves the way to victory.
Superior audio detection and positioning make gamers equipped with ROG audio gear true champions. Developed using real life insight from full-time players and refined by the expertise of the Xonar team, the ultimate goal here is to help you win! Built for the most dedicated gamers, ROG audio product is committed to win-boosting features, from clear communications to precision detection that amplifies every footstep taken by opponents. No more sneaking around or getting stealth-flanked!
  • Focus to win
    Retaining advanced active noise cancellation technology specifically designed to eliminate low frequency computer fan noise, high frequency environmental noise, and human voice from external sources, the ROG team researched and created Vulcan PRO with the exclusive ROG Spitfire USB audio processor. It allows gamers to experience precise audio positioning and enhanced surround with no driver install needed, perfect for LAN parties.
  • ROG Spitfire USB audio processor - powerful driver-free hardware DSP
    ROG Vulcan PRO adds the ROG Spitfire USB audio processor, which works at the hardware level and requires no driver install. Its design contributes to quicker setup in gaming events, and complies with the most professional venues, which prohibit the installation of additional drivers. The ROG Spitfire deploys the powerful hardware digital signal processor to offer such driver-free convenience, especially perfect for LAN parties.
  • Block disruption perfectly with advanced dual noise technologies
    Noise ranks as one of the leading issues for pro gamers, often causing distractions and leading to the wrong decisions - which in turn lower win ratios. The ROG Vulcan PRO features brushed metal headphone side covers that offer a style as well as better strength. It offers gamers active and passive noise cancellation technologies, meticulously designed by ROG engineers to ensure better gaming success and immersion.
  • Long-lasting comfort and gamer-friendly design
    ROG Vulcan PRO employs a durable and detachable braided cable, enabling easy wire management and eliminating unsightly entanglements. It uses emergency detachment, unplugging neatly and safely if you stand up suddenly while gaming with the headset on, preventing the unexpected pull from sending your precious hardware tumbling to the floor.
ASUS Vulcan PRO Republic of Gamers - headset
Headset - wired
Recommended Use
Computer
Additional Functions
Amplifier
Headphones Form Factor
Full size binaural
Wired
Sound Output Mode
Stereo
Sound Effects
7.1 Channel Virtual Surround Sound
Audio Specifications
Frequency Response 10 - 20000 Hz - Sensitivity 42 dB
Impedance
32 Ohm
Active Noise Canceling
Microphone
Detachable - boom
Headset - wired
Amplifier
21 cm
7 cm
18 cm
326 g
Recommended Use
Computer
Audio Output
Full size binaural
Wired
Sound Output Mode
Stereo
Sound Effects
Frequency Response
10 - 20000 Hz
Total Harmonic Distortion (THD)
0.01%
Sensitivity
42 dB
Impedance
32 Ohm
Diaphragm
40 mm
Magnet Material
Neodymium magnet
In-Cord Volume Control
Microphone
Boom
Sensitivity
42 dB
Frequency Response
100 - 10000 Hz
Connector Type
Headphones (mini-phone 3.5mm) , Microphone (mini-phone 3.5mm)
Carrying case
Cable Details
Headset cable - 2.5 m
