Asus VT168N 15.6" 10-point Capacitive Multi-Touch Monitor
Quicklinx: CBF5WS00 Mfr#: VT168N
Diagonal Size: 15.6in
Max Resolution: 1366 x 768
Response Time: 10ms
Speakers: None
Interfaces: DVI, VGA (HD-15)
£118.69 ex VAT
£142.42 inc VAT
The ASUS VT168N touchscreen monitor combines 10-point multi-touch capability with amazing image quality, flexible connectivity and great ergonomics. The precise and accurate multi-touch display - allowing up to 10 simultaneous touches to work smarter and more efficiently.
ASUS Splendid Video Intelligence technology employs a color engine with six preset modes. These allow you to adjust your display easily for the best color accuracy and image fidelity, depending on what kind of content is being displayed. You can access the presets via a designated hotkey.
VT168N has multiple video and peripheral connectors, including VGA and DVI-D, making it suitable for use anywhere, either in the home or at the office. VT168N features an elegant circular base with an ergonomically-designed tilting stand that lets you choose the ideal viewing position. The monitor is also VESA mount-compatible, making it easy to mount on a wall or monitor arm.
ASUS Eye Care monitor provides eye care features - Flicker free and Low Blue Light technology with 4 different levels that prevent your eyes from fatigue, strain that caused by screen flicker, hazard blue light and various light sources from office environment.
  • 10-point multi-touch - an incredibly intuitive touch experience
  • The touchscreen monitor that gives you much more
  • Designed with you in mind
  • Eye Care technology with flicker free and Low Blue Light
ASUS VT168N - LED monitor - 15.6"
LED-backlit LCD monitor - 15.6" - touchscreen
Aspect Ratio
16:9
Native Resolution
1366 x 768
Pixel Pitch
0.252 mm
Brightness
200 cd/m²
Contrast Ratio
600:1 / 50000000:1 (dynamic)
Response Time
10 ms
Colour Support
262,144 colours
Input Connectors
DVI-D, VGA
Display Position Adjustments
Tilt
33.78 cm x 4.4 cm x 23.59 cm
1.4 kg
Environmental Standards
ENERGY STAR Qualified
TUV GS, VCCI, C-Tick, BSMI, WHQL, CB, TUV Ergo, PSB, RoHS, KCC, WEEE, MEPS, J-MOSS, E-Standby, UkrSEPRO, KC, ERP, RCM, CU-EAC, TUV Rheinland Low Blue Light Certification, TUV Rheinland Flicker Free Certification
3-year warranty
Display Type
Diagonal Size
15.6"
Aspect Ratio
16:9
Native Resolution
1366 x 768
Pixel Pitch
0.252 mm
Brightness
200 cd/m²
Contrast Ratio
Colour Support
262,144 colours
Response Time
10 ms
Vertical Refresh Rate
50 - 76 Hz
Horizontal Refresh Rate
30 - 80 kHz
Horizontal Viewing Angle
90
Vertical Viewing Angle
65
Backlight Technology
LED backlight
HDCP, Skin-Tone Selection, glare, ASUS Splendid Video Preset Mode, Smart View Technology, ASUS QuickFit Virtual Scale, ASUS VividPixel Technology, Low Blue Light Mode, Blue Light Filter technology
33.78 cm x 4.4 cm x 23.59 cm - without stand
1.4 kg
Input
Touchscreen
VGA , DVI-D , USB 2.0 (Type B)
Mechanical
Tilt
Tilt Angle
-5/+30
VESA Mounting Interface
75 x 75 mm
1 x VGA cable , 1 x HDMI-DVI cable , 1 x micro-USB cable
7 Watt
Power Consumption (Off Mode)
0.5 Watt
Dimensions & Weight Details
Without stand - width: 33.78 cm - depth: 4.4 cm - height: 23.59 cm , With stand - width: 33.78 cm - depth: 18.94 cm - height: 28.07 cm
ENERGY STAR Certified
Limited warranty - 3 years , Limited warranty - LCD panel - 3 years
Response Time: 10ms
Speakers: None
Interfaces: DVI
Interfaces: VGA (HD-15)
Brand: Asus
Price Range Ex VAT: 100 - 150
