The ASUS VT168N touchscreen monitor combines 10-point multi-touch capability with amazing image quality, flexible connectivity and great ergonomics. The precise and accurate multi-touch display - allowing up to 10 simultaneous touches to work smarter and more efficiently.
ASUS Splendid Video Intelligence technology employs a color engine with six preset modes. These allow you to adjust your display easily for the best color accuracy and image fidelity, depending on what kind of content is being displayed. You can access the presets via a designated hotkey.
VT168N has multiple video and peripheral connectors, including VGA and DVI-D, making it suitable for use anywhere, either in the home or at the office. VT168N features an elegant circular base with an ergonomically-designed tilting stand that lets you choose the ideal viewing position. The monitor is also VESA mount-compatible, making it easy to mount on a wall or monitor arm.
ASUS Eye Care monitor provides eye care features - Flicker free and Low Blue Light technology with 4 different levels that prevent your eyes from fatigue, strain that caused by screen flicker, hazard blue light and various light sources from office environment.
10-point multi-touch - an incredibly intuitive touch experience
The ASUS VT168N touchscreen monitor combines 10-point multi-touch capability with amazing image quality, flexible connectivity and great ergonomics. The precise and accurate multi-touch display - allowing up to 10 simultaneous touches to work smarter and more efficiently. -
The touchscreen monitor that gives you much more
ASUS Splendid Video Intelligence technology employs a color engine with six preset modes. These allow you to adjust your display easily for the best color accuracy and image fidelity, depending on what kind of content is being displayed. You can access the presets via a designated hotkey. -
Designed with you in mind
VT168N has multiple video and peripheral connectors, including VGA and DVI-D, making it suitable for use anywhere, either in the home or at the office. VT168N features an elegant circular base with an ergonomically-designed tilting stand that lets you choose the ideal viewing position. The monitor is also VESA mount-compatible, making it easy to mount on a wall or monitor arm. -
Eye Care technology with flicker free and Low Blue Light
- ASUS VT168N - LED monitor - 15.6"
- LED-backlit LCD monitor - 15.6" - touchscreen
- Aspect Ratio
- 16:9
- Native Resolution
- 1366 x 768
- Pixel Pitch
- 0.252 mm
- Brightness
- 200 cd/m²
- Contrast Ratio
- 600:1 / 50000000:1 (dynamic)
- Response Time
- 10 ms
- Colour Support
- 262,144 colours
- Input Connectors
- DVI-D, VGA
- Tilt
- Black
- Dimensions (WxDxH) - without stand
- 33.78 cm x 4.4 cm x 23.59 cm
- 1.4 kg
- Environmental Standards
- ENERGY STAR Qualified
- TUV GS, VCCI, C-Tick, BSMI, WHQL, CB, TUV Ergo, PSB, RoHS, KCC, WEEE, MEPS, J-MOSS, E-Standby, UkrSEPRO, KC, ERP, RCM, CU-EAC, TUV Rheinland Low Blue Light Certification, TUV Rheinland Flicker Free Certification
- 3-year warranty
- Display Type
- Diagonal Size
- 15.6"
- Aspect Ratio
- 16:9
- Native Resolution
- 1366 x 768
- Pixel Pitch
- 0.252 mm
- Brightness
- 200 cd/m²
- Contrast Ratio
- Colour Support
- 262,144 colours
- Response Time
- 10 ms
- Vertical Refresh Rate
- 50 - 76 Hz
- Horizontal Refresh Rate
- 30 - 80 kHz
- Horizontal Viewing Angle
- 90
- Vertical Viewing Angle
- 65
- Backlight Technology
- LED backlight
- HDCP, Skin-Tone Selection, glare, ASUS Splendid Video Preset Mode, Smart View Technology, ASUS QuickFit Virtual Scale, ASUS VividPixel Technology, Low Blue Light Mode, Blue Light Filter technology
- Black
- 33.78 cm x 4.4 cm x 23.59 cm - without stand
- 1.4 kg
Input
- Touchscreen
- VGA , DVI-D , USB 2.0 (Type B)
Mechanical
- Tilt
- Tilt Angle
- -5/+30
- VESA Mounting Interface
- 75 x 75 mm
- Cables Included
- 1 x VGA cable , 1 x HDMI-DVI cable , 1 x micro-USB cable
- Voltage Required
- AC 120/230 V (50/60 Hz)
- 7 Watt
- 0.5 Watt
- Dimensions & Weight Details
- Without stand - width: 33.78 cm - depth: 4.4 cm - height: 23.59 cm , With stand - width: 33.78 cm - depth: 18.94 cm - height: 28.07 cm
- ENERGY STAR Certified
- Limited warranty - 3 years , Limited warranty - LCD panel - 3 years
