Asus VS278Q 27" 1920x1080 1ms VGA DVI HDMI DisplayPort LED Monitor
Quicklinx: 9TNVWS00 Mfr#: VS278Q
Delicate touches make a monitor truly great, VX278Q Full HD LED monitor, with extremely quick 1 ms response time, 80,000,000:1 high contrast ratio and HDMI interfaces, is optimized for fine image and color quality. This approach extends to the sturdy sundial-inspired design stand and ultra-slim profile without compromising style in ensuring stability and durability.
  • 80,000,000:1 ASUS smart contrast ratio
    Dynamically enhances the display's contrast by adjusting the luminance of the backlight to achieve the darkest black and brightest white - delivering lifelike images.
  • Full HD 1080p support
    Enter a spectacular world of colors with Full HD 1080p (1920x1080) support.
  • 1 ms response time
    Quick response time of 1 ms (GTG) eliminates ghosting and tracers for more fluid video playback.
  • Aspect Control function
    Aspect Control function allows users to select a preferred display mode among Full and 4:3 for true-to-life gaming or movie watching without any data loss or image distortion.
  • Robust connectivity for multimedia enjoyment
    VX278Q comes with rich connectivity including Dual HDMI and D-sub so that users could easily connect it to Full HD Blu-ray disc players and myriad HD playback devices like DVD players and set-top boxes for limitless entertainment and multimedia enjoyment.
  • ASUS Flicker Free technology
    ASUS Flicker-Free technology by using Smart Dynamic Backlight Adjustment avoids low brightness level and high speed LED backlight flashing, clears out the distractive flicker, brings comfort viewing experience to avoid Computer Vision Syndrome.
  • QuickFit Virtual Scale
    The ASUS-exclusive QuickFit built in the monitor provides real-size document, photo, and grid mode on top of the operating windows on the screen. It can activated via a hotkey on monitor and used as a guide to accurately view and edit photos.
  • Splendid Video Intelligence technology
    The exclusive Splendid Video Intelligence Technology optimizes video performance and image fidelity by enhancing color, brightness, contrast, and sharpness. 6 preset video modes (Scenery, Theater, Game, Night View, sRGB and Standard) can be selected via a hotkey.
ASUS VS278Q - LED monitor - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class A+
Energy Consumption per Year
31.2 kWh
Power Consumption (On mode)
21.4 W
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.311 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1 / 80000000:1 (dynamic)
Response Time
1 ms (grey-to-grey)
Colour Support
16.7 million colours
Colour Gamut
72% NTSC
Input Connectors
2xHDMI, VGA, DisplayPort
Speakers
Integrated
Display Position Adjustments
Tilt
Voltage
64.886 cm x 5 cm x 47.011 cm
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
UL, VCCI, C-Tick, BSMI, cUL, WHQL, CB, CCC, PSB, FCC, RoHS, WEEE, GOST-R, ErP Ready
3-year warranty
Display Type
Energy Class
Class A+
31.2 kWh
Diagonal Size
27"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.311 mm
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
72% NTSC
Response Time
1 ms (grey-to-grey)
Vertical Refresh Rate
50 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
LED backlight
Controls & Adjustments
Volume, brightness, input select, colour temperature
HDCP, ASUS Splendid Video Intelligence Technology, anti-glare, Skin-Tone Selection, Trace Free Technology, ASUS Smart Contrast Ratio (ASCR), ASUS Splendid Video Preset Mode, ASUS QuickFit Virtual Scale, 72% NTSC colour gamut
64.886 cm x 5 cm x 47.011 cm - without stand
Audio
Speakers - stereo - integrated
Output Power / Channel
2 Watt
VGA , DisplayPort , 2 x HDMI , Headphones , Audio line-in
Mechanical
Tilt
Tilt Angle
-5/+20
VESA Mounting Interface
100 x 100 mm
1 x VGA cable , 1 x HDMI-DVI cable , 1 x audio cable
Power Supply
Internal
Input Voltage
21.4 W
Power Consumption (Typical)
45 Watt
Power Consumption Stand by / Sleep
0.5 Watt
0.5 Watt
Power Consumption Sleep
0 Watt
On / Off Switch
Dimensions & Weight Details
With stand - width: 64.886 cm - depth: 22.5 cm - height: 47.011 cm - weight: 5.1 kg
Sustainability Information
ENERGY STAR Certified
Limited warranty - 3 years , Limited warranty - LCD panel - 3 years
9TNV StarTech.com Dual Monitor Mount - Stackable In Stock £212.26
9TNV StarTech.com TV/Monitor Arm - Wallmount In Stock £82.22
9TNV StarTech.com Monitor Arm - Heavy Duty In Stock £93.15
9TNV StarTech.com Monitor Desk Mount - Steel In Stock £43.93
