Asus VS24AHL 24.1" 1920x1200 5ms VGA DVI HDMI IPS LED Monitor
Quicklinx: 9TR2WS00 Mfr#: VS24AHL
Delicate touches make a monitor truly great, VS24AHL 1920x1200 IPS LED monitor, with 16:10 aspect ratio, 80,000,000:1 high contrast ratio and HDMI interface, is optimized for fine image and color quality. The VS24AHL reaches a desired viewing angle with support of pivot, tilt, height adjustment and swivel functions.
  • 80,000,000:1 ASUS smart contrast ratio
    Dynamically enhances the display's contrast by adjusting the luminance of the backlight to achieve the darkest black and brightest white - delivering lifelike images.
  • 178° ultra wide viewing angle
    VS24AHL adopts 178°(H) / 178°(V) ultra wide viewing angle IPS panel that eliminates color shift on your screen no matter where and how you look at it.
  • Versatile position for personal visual comfort
    It's easy for you to reach a desired viewing angle with support of pivot, tilt, height adjustment and swivel functions.
  • QuickFit virtual scale
    The ASUS-exclusive QuickFit built in the monitor provides real-size document, photo, and grid mode on top of the operating windows on the screen. It can activated via a hotkey on monitor and used as a guide to accurately view and edit photos.
  • Aspect Control function
    Aspect Control function allows users to select a preferred display mode among Full and 4:3 for true-to-life gaming or movie watching without any data loss or image distortion.
  • Splendid Video Intelligence technology
    The exclusive Splendid Video Intelligence technology optimizes video performance and image fidelity by enhancing color, brightness, contrast, and sharpness. 6 preset video modes (Scenery, Theater, Game, Night View, sRGB and Standard) can be selected via a hotkey. To deliver a more comfortable viewing experience, ASUS Eyecare monitors adopts Flicker-Free technology to clear out the distracted flicker shown on the screen and help reduce eye fatigue for long-period watching.
ASUS VS24AHL - LED monitor - 24.1"
LED-backlit LCD monitor - 24.1"
Energy Class
Class A+
Energy Consumption per Year
25.1 kWh
Power Consumption (On mode)
17.2 W
Panel Type
IPS
Aspect Ratio
16:10
Native Resolution
1920 x 1200
Pixel Pitch
0.27 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1 / 80000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI-D, VGA
Display Position Adjustments
Screen Coating
Anti-glare
56.16 cm x 22.48 cm x 53.45 cm
6.1 kg
Environmental Standards
ENERGY STAR Qualified
UL, VCCI, C-Tick, BSMI, cUL, WHQL, CB, FCC, RoHS, WEEE, PSE Mark, J-MOSS, ErP Ready
3-year warranty
Display Type
Energy Class
Class A+
25.1 kWh
Diagonal Size
24.1"
Panel Type
IPS
Aspect Ratio
16:10
Native Resolution
1920 x 1200
Pixel Pitch
0.27 mm
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
50 - 61 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
LED backlight
Controls & Adjustments
Brightness, input select, colour temperature, aspect control
sRGB colour management, HDCP, ASUS Splendid Video Intelligence Technology, Skin-Tone Selection, ASUS Smart Contrast Ratio (ASCR), ASUS Splendid Video Preset Mode, ASUS QuickFit Virtual Scale
56.16 cm x 22.48 cm x 53.45 cm - with stand
6.1 kg
VGA , DVI-D , HDMI , Headphones
Mechanical
Tilt Angle
-5/+20
Swivel Angle
160
VESA Mounting Interface
100 x 100 mm
1 x VGA cable , 1 x DVI cable , 1 x HDMI cable
17.2 W
Power Consumption (Typical)
30 watt
Power Consumption Stand by
0.5 watt
Power Consumption Sleep
0.5 watt
Sustainability Information
ENERGY STAR Certified
Limited warranty - 3 years , Limited warranty - LCD panel - 3 years
