Delicate touches make a monitor truly great, VS24AHL 1920x1200 IPS LED monitor, with 16:10 aspect ratio, 80,000,000:1 high contrast ratio and HDMI interface, is optimized for fine image and color quality. The VS24AHL reaches a desired viewing angle with support of pivot, tilt, height adjustment and swivel functions.
80,000,000:1 ASUS smart contrast ratio
Dynamically enhances the display's contrast by adjusting the luminance of the backlight to achieve the darkest black and brightest white - delivering lifelike images. -
178° ultra wide viewing angle
VS24AHL adopts 178°(H) / 178°(V) ultra wide viewing angle IPS panel that eliminates color shift on your screen no matter where and how you look at it. -
Versatile position for personal visual comfort
It's easy for you to reach a desired viewing angle with support of pivot, tilt, height adjustment and swivel functions. -
QuickFit virtual scale
The ASUS-exclusive QuickFit built in the monitor provides real-size document, photo, and grid mode on top of the operating windows on the screen. It can activated via a hotkey on monitor and used as a guide to accurately view and edit photos. -
Aspect Control function
Aspect Control function allows users to select a preferred display mode among Full and 4:3 for true-to-life gaming or movie watching without any data loss or image distortion. -
Splendid Video Intelligence technology
The exclusive Splendid Video Intelligence technology optimizes video performance and image fidelity by enhancing color, brightness, contrast, and sharpness. 6 preset video modes (Scenery, Theater, Game, Night View, sRGB and Standard) can be selected via a hotkey. To deliver a more comfortable viewing experience, ASUS Eyecare monitors adopts Flicker-Free technology to clear out the distracted flicker shown on the screen and help reduce eye fatigue for long-period watching.
- ASUS VS24AHL - LED monitor - 24.1"
- LED-backlit LCD monitor - 24.1"
- Energy Class
- Class A+
- Energy Consumption per Year
- 25.1 kWh
- Power Consumption (On mode)
- 17.2 W
- Panel Type
- IPS
- Aspect Ratio
- 16:10
- Native Resolution
- 1920 x 1200
- Pixel Pitch
- 0.27 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 1000:1 / 80000000:1 (dynamic)
- Response Time
- 5 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Input Connectors
- HDMI, DVI-D, VGA
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare
- Black
- 56.16 cm x 22.48 cm x 53.45 cm
- 6.1 kg
- Environmental Standards
- ENERGY STAR Qualified
- UL, VCCI, C-Tick, BSMI, cUL, WHQL, CB, FCC, RoHS, WEEE, PSE Mark, J-MOSS, ErP Ready
- 3-year warranty
- Display Type
- Energy Class
- Class A+
- 25.1 kWh
- Diagonal Size
- 24.1"
- Panel Type
- IPS
- Aspect Ratio
- 16:10
- Native Resolution
- 1920 x 1200
- Pixel Pitch
- 0.27 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- Vertical Refresh Rate
- 50 - 61 Hz
- Horizontal Refresh Rate
- 30 - 83 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Anti-glare
- Backlight Technology
- LED backlight
- Controls & Adjustments
- Brightness, input select, colour temperature, aspect control
- sRGB colour management, HDCP, ASUS Splendid Video Intelligence Technology, Skin-Tone Selection, ASUS Smart Contrast Ratio (ASCR), ASUS Splendid Video Preset Mode, ASUS QuickFit Virtual Scale
- Black
- 56.16 cm x 22.48 cm x 53.45 cm - with stand
- 6.1 kg
- VGA , DVI-D , HDMI , Headphones
Mechanical
- Tilt Angle
- -5/+20
- Swivel Angle
- 160
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x VGA cable , 1 x DVI cable , 1 x HDMI cable
- 17.2 W
- Power Consumption (Typical)
- 30 watt
- Power Consumption Stand by
- 0.5 watt
- Power Consumption Sleep
- 0.5 watt
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 3 years , Limited warranty - LCD panel - 3 years
