Superior Image Quality Meets Classic Elegant Design
Delicate touches make a monitor truly great, VS247NR Full HD LED monitor, with 50,000,000:1 high contrast ratio and HDCP support, is optimized for the finest image and color quality. This approach extends to the sturdy stand and slim profile without compromising style in ensuring stability and durability.
True-to-life Pictures Powered by LED
Dynamically enhances the display's contrast by adjusting the luminance of the backlight to achieve the darkest black and brightest white - delivering lifelike images.
Full HD 1080p Support 7 Aspect Control
Enter a spectacular world of colors with Full HD 1080p (1920x1080) support When you would like to watch movies upward lying down, Smart View Technology can adjust color parameters to deliver the same image quality and colors with straight viewing. Aspect Control function allows users to select a preferred display mode among Full and 4:3 for true-to-life gaming or movie watching without any data loss or image distortion.
Splendid™ Video Intelligence Technology
The exclusive Splendid Video Intelligence Technology optimizes video performance and image fidelity by enhancing color, brightness, contrast, and sharpness. 6 preset video modes (Scenery, Theater, Game, Night View, sRGB and Standard) can be selected via a hotkey.
- Stylish and User-friendly Design for Modern Sophistication
- Convenient key controls for functional set-up in the multi-language OSD.
- Easily detachable base for wall mount. VESA Wall Mount Standard (100 x 100 mm ).
- 25° ( forward 5°, backwards 20° )Tilting Angle.
- KENSINGTON Security Lock.
SPECIFICATION
Display
- Panel Size: Wide Screen 23.6"(59.9cm) 16:9
- True Resolution : 1920x1080
- Pixel Pitch : 0.272mm
- Brightness(Max) : 250 cd/?
- ASUS Smart Contrast Ratio (ASCR) : 50000000:1
- Viewing Angle (CR?10) : 170°(H)/160°(V)
- Response Time : 5ms
- Display Colors : 16.7M
Video Feature
- SPLENDID Video Intelligence Technology
- SPLENDID Video Preset Modes : 6 Modes (sRGB Mode/Scenery Mode/Theater Mode/Standard Mode/Night View Mode/Game Mode)
- Skin-Tone Selection : 3 Modes
- Color Temperature Selection : 4 Modes
- HDCP support
Convenient Hotkey
- SPLENDID Video Preset Mode Selection
- Auto. Adjustment
- Brightness Adjustment
- Contrast Adjustment
I/O Ports
- Signal Input : D-Sub, DVI-D
Signal Frequency
- Analog Signal Frequency : 24~83 KHz(H)/ 50~75 Hz(V)
- Digital Signal Frequency : 24~83 KHz(H)/ 50~75 Hz(V)
Power Consumption
- Power ON: < 22.7W*
- Power Saving Mode : < 0.5W
- Power Off Mode : < 0.5W
- Voltage : 100-240V, 50/60Hz
Mechanical Design
- Chassis Colors : Black
- Tilt : +20°~-5°
- VESA Wall Mounting : 100x100mm
Security
- Kensington lock
Regulation Approval
- Energy Star®, BSMI, CB, CCC, CE, C-Tick, CU, EK,, ErP, FCC, J-MOSS, PSB, RoHS, UL/cUL, VCCI, WEEE, WHQL (Windows 7, Windows Vista)
Note
*Based on Energy Star 6.0 standard
Superior image quality meets classic elegant design
Delicate touches make a monitor truly great, VS247NR Full HD LED monitor, with 50000000:1 high contrast ratio and HDCP support is optimized for the finest image and color quality. This approach extends to the sturdy stand and slim profile without compromising style in ensuring stability and durability. -
50000000:1 ASUS smart contrast ratio
Dynamically enhances the display's contrast by adjusting the luminance of the backlight to achieve the darkest black and brightest white - delivering lifelike images. -
Full HD 1080p support
Enter a spectacular world of colors with Full HD 1080p (1920x1080) support. -
Versatile viewing positions with Smart View technology
When you would like to watch movies upward lying down, Smart View technology can adjust color parameters to deliver the same image quality and colors with straight viewing. -
Aspect control function
Aspect control function allows users to select a preferred display mode among full and 4:3 for true-to-life gaming or movie watching without any data loss or image distortion. -
Splendid Video Intelligence technology
The exclusive Splendid Video Intelligence technology optimizes video performance and image fidelity by enhancing color, brightness, contrast, and sharpness.
- ASUS VS247NR - LED monitor - Full HD (1080p) - 23.6"
- LED-backlit LCD monitor - 23.6"
- Power Consumption (On mode)
- 19.4 W
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Pixel Pitch
- 0.272 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 50000000:1 (dynamic)
- Response Time
- 5 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- DVI-D, VGA
- Tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 56.18 cm x 20 cm x 41.06 cm
- 4.2 kg
- Environmental Standards
- ENERGY STAR Qualified
- UL, VCCI, C-Tick, BSMI, cUL, WHQL, CB, CCC, PSB, EK, FCC, RoHS, WEEE, J-MOSS, ErP Ready
- 3-year warranty
- Display Type
- Diagonal Size
- 23.6"
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.272 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- 5 ms
- Vertical Refresh Rate
- 50 - 75 Hz
- Horizontal Refresh Rate
- 24 - 83 kHz
- Horizontal Viewing Angle
- 170
- Vertical Viewing Angle
- 160
- Backlight Technology
- LED backlight
- Controls & Adjustments
- Brightness, contrast, input select, colour temperature, aspect control
- sRGB colour management, HDCP, ASUS Splendid Video Intelligence Technology, Skin-Tone Selection, ASUS Smart Contrast Ratio (ASCR), ASUS Splendid Video Preset Mode, Smart View Technology
- Black
- 56.18 cm x 20 cm x 41.06 cm - with stand
- 4.2 kg
- VGA , DVI-D
Mechanical
- Tilt
- Tilt Angle
- -5/+20
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x VGA cable , 1 x DVI cable
- Power Supply
- Internal
- Input Voltage
- 19.4 W
- Power Consumption (Typical)
- 22.7 Watt
- Power Consumption Stand by
- 0.28 Watt
- Power Consumption Sleep
- 0.21 Watt
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 3 years , Limited warranty - LCD panel - 3 years
C2G 2m HDMI to DVI-D Digital Video Cable | In Stock | £11.38 |
