Asus VS229NA 21.5" 1920x1080 18ms VGA DVI LED Monitor
Quicklinx: 9TPXWS00 Mfr#: VS229NA
Delicate touches make a VS229NA Full HD LED monitor truly great with 80,000,000:1 high contrast ratio is optimized for the finest image and color quality. This approach extends to the sturdy stand and slim profile without compromising style in ensuring stability and durability.
  • ASUS Smart contrast ratio
    Dynamically enhances the display's contrast by adjusting the luminance of the backlight to achieve the darkest black and brightest white - delivering lifelike images.
  • Full HD
    Enter a spectacular world of colors with Full HD 1080p support.
  • 17° ultra wide viewing angle
    VS229NA adopts 178°(H) / 178°(V) ultra wide viewing angle panel that eliminates color shift on your screen no matter where and how you look at it.
  • Aspect control function
    Aspect control function allows users to select a preferred display mode among Full and 4:3 for true-to-life gaming or movie watching without any data loss or image distortion.
  • Splendid video intelligence technology
    The exclusive Splendid video intelligence technology optimizes video performance and image fidelity by enhancing color, brightness, contrast, and sharpness. Featuring two modes - Reading and Darkroom - in addition to the Scenery, Standard, Theater, and sRGB modes. Low-blue light technologies also reduce the strain on your eyes after long-time usage.
  • QuickFit virtual scale (patent-pending)
    The ASUS-exclusive QuickFit built in the monitor provides real-size photo and grid mode on top of the operating windows on the screen. It can activated via a hotkey on monitor and used as a guide to accurately view and edit photos.
  • Stylish and user-friendly design for modern sophistication
    This product has convenient key controls for functional set-up in the multi-language OSD, it also has easily detachable base for wall mount.
  • Greener materials
    It is made from environmentally-friendly material - Mercury-free LED-backlit panel, corrugated cardboard packaging with at least 80% recycled content. Besides, slim-flat packaging allows more cartons to be fitted per cargo, reducing transportation costs and carbon dioxide emission.
ASUS VS229NA - LED monitor - Full HD (1080p) - 21.5"
LED-backlit LCD monitor - 21.5"
Energy Class
Class A
Energy Consumption per Year
26.4 kWh
Power Consumption (On mode)
18.1 W
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
80000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA
Display Position Adjustments
Tilt
Voltage
51.41 cm x 20.063 cm x 38.722 cm
3.5 kg
Environmental Standards
ENERGY STAR Qualified
UL, VCCI, C-Tick, BSMI, cUL, WHQL, CB, CCC, PSB, FCC, RoHS, WEEE, J-MOSS, ErP Ready, EAC, CEL level 1
3-year warranty
Display Type
Energy Class
Class A
26.4 kWh
Diagonal Size
21.5"
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
50 - 75 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
Controls & Adjustments
Brightness, contrast, colour temperature, aspect control
sRGB colour management, HDCP, ASUS Splendid Video Intelligence Technology, Skin-Tone Selection, Trace Free Technology, ASUS Smart Contrast Ratio (ASCR), ASUS Splendid Video Preset Mode, WideView, ASUS QuickFit Virtual Scale
51.41 cm x 20.063 cm x 38.722 cm - with stand
3.5 kg
VGA , DVI-D
Mechanical
Tilt
Tilt Angle
-5/+20
VESA Mounting Interface
100 x 100 mm
1 x VGA cable , 1 x DVI cable
Input Voltage
18.1 W
Power Consumption (Typical)
30 watt
Power Consumption Stand by
0.5 watt
Power Consumption Sleep
0.5 watt
Dimensions & Weight Details
Without stand - width: 51.41 cm - depth: 4.84 cm - height: 31.518 cm
Sustainability Information
ENERGY STAR Certified
Limited warranty - 3 years , Limited warranty - LCD panel - 3 years
9TPX C2G 2m HDMI to DVI-D Digital Video Cable In Stock £8.17
