Asus VS207NE 19.5" 1600x900 5ms VGA DVI LED Monitor
Quicklinx: 9TQ8WS00 Mfr#: VS207NE
Delicate touches make a monitor truly great, VS207N LED monitor, with 80000000:1 high contrast ratio and HDCP support, is optimized for the finest image and color quality. This approach extends to the sturdy stand and slim profile without compromising style in ensuring stability and durability.
ASUS VS207NE - LED monitor - 19.5"
LED-backlit LCD monitor - 19.5"
Power Consumption (On mode)
13.9 W
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
1600 x 900
Pixel Pitch
0.27 mm
Brightness
200 cd/m²
Contrast Ratio
600:1 / 80000000:1 (dynamic)
Response Time
5 ms
Colour Gamut
72% NTSC
Input Connectors
DVI-D, VGA
Display Position Adjustments
Tilt
46.8 cm x 18.5 cm x 35.55 cm
2.59 kg
Environmental Standards
ENERGY STAR Qualified
UL, VCCI, C-Tick, cUL, WHQL, CB, CCC, FCC, RoHS, WEEE, GOST-R, ErP Ready, China Energy Label Level 1
3-year warranty
Display Type
Diagonal Size
19.5"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
1600 x 900
Pixel Pitch
0.27 mm
Brightness
200 cd/m²
Contrast Ratio
Colour Gamut
72% NTSC
Response Time
5 ms
Vertical Refresh Rate
55 - 75 Hz
Horizontal Refresh Rate
30 - 80 kHz
Horizontal Viewing Angle
90
Vertical Viewing Angle
65
Backlight Technology
LED backlight
Controls & Adjustments
Brightness, aspect control
sRGB colour management, HDCP, ASUS Splendid Video Intelligence Technology, Skin-Tone Selection, ASUS Smart Contrast Ratio (ASCR), ASUS Splendid Video Preset Mode, ASUS QuickFit Virtual Scale, 72% NTSC colour gamut
2.59 kg
VGA , DVI-D
Mechanical
Tilt
Tilt Angle
-5/+20
VESA Mounting Interface
75 x 75 mm
1 x VGA cable , 1 x DVI cable
Power Supply
Internal
13.9 W
Power Consumption (Typical)
16.4 Watt
Power Consumption Stand by
0.2 Watt
Power Consumption Sleep
0.15 Watt
Sustainability Information
ENERGY STAR Certified
Limited warranty - 3 years , Limited warranty - LCD panel - 3 years
