Delicate touches make a monitor truly great, VS207N LED monitor, with 80000000:1 high contrast ratio and HDCP support, is optimized for the finest image and color quality. This approach extends to the sturdy stand and slim profile without compromising style in ensuring stability and durability.
Efficient power usage
With a typical power consumption of only 16.4 W and even less during sleep and standby modes, this monitor is designed for energy efficiency. Its compliance with ENERGY STAR certification ensures that it not only saves power but also reduces energy costs for users. -
Exceptional visual clarity
The ASUS VS207NE offers a dynamic contrast ratio and a native resolution of 1600 x 900, providing users with sharp, vivid images. The LED backlight enhances image brightness and clarity, making it perfect for both work and entertainment. -
Versatile connectivity
Equipped with both DVI and VGA interfaces, this monitor provides flexible connectivity options. Whether you're connecting to older devices with VGA or newer devices with DVI, the ASUS VS207NE has you covered. -
Ergonomic design
Designed with user comfort in mind, the monitor features tilt adjustments ranging from -5 to +20 degrees. This allows users to find the perfect viewing angle, reducing strain during long periods of use.
- ASUS VS207NE - LED monitor - 19.5"
- LED-backlit LCD monitor - 19.5"
- Power Consumption (On mode)
- 13.9 W
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- 1600 x 900
- Pixel Pitch
- 0.27 mm
- Brightness
- 200 cd/m²
- Contrast Ratio
- 600:1 / 80000000:1 (dynamic)
- Response Time
- 5 ms
- Colour Gamut
- 72% NTSC
- Input Connectors
- DVI-D, VGA
- Tilt
- Black
- 46.8 cm x 18.5 cm x 35.55 cm
- 2.59 kg
- Environmental Standards
- ENERGY STAR Qualified
- UL, VCCI, C-Tick, cUL, WHQL, CB, CCC, FCC, RoHS, WEEE, GOST-R, ErP Ready, China Energy Label Level 1
- 3-year warranty
- Display Type
- Diagonal Size
- 19.5"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- 1600 x 900
- Pixel Pitch
- 0.27 mm
- Brightness
- 200 cd/m²
- Contrast Ratio
- Colour Gamut
- 72% NTSC
- Response Time
- 5 ms
- Vertical Refresh Rate
- 55 - 75 Hz
- Horizontal Refresh Rate
- 30 - 80 kHz
- Horizontal Viewing Angle
- 90
- Vertical Viewing Angle
- 65
- Backlight Technology
- LED backlight
- Controls & Adjustments
- Brightness, aspect control
- sRGB colour management, HDCP, ASUS Splendid Video Intelligence Technology, Skin-Tone Selection, ASUS Smart Contrast Ratio (ASCR), ASUS Splendid Video Preset Mode, ASUS QuickFit Virtual Scale, 72% NTSC colour gamut
- Black
- 2.59 kg
- VGA , DVI-D
Mechanical
- Tilt
- Tilt Angle
- -5/+20
- VESA Mounting Interface
- 75 x 75 mm
- Cables Included
- 1 x VGA cable , 1 x DVI cable
- Power Supply
- Internal
- 13.9 W
- Power Consumption (Typical)
- 16.4 Watt
- Power Consumption Stand by
- 0.2 Watt
- Power Consumption Sleep
- 0.15 Watt
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 3 years , Limited warranty - LCD panel - 3 years
