Asus VP28UQG 28" 4k Gaming FreeSync DP HDMI
Quicklinx: D2BVWS00 Mfr#: VP28UQG
Diagonal Size: 28in
Max Resolution: 3840 x 2160
Response Time: 1ms
Interfaces: DisplayPort, HDMI
£279.26 ex VAT
£335.11 inc VAT
Marketing description is not available.
  • A 28-inch 4K UHD display for highly-detailed visuals and more onscreen space
    With its 28-inch 4K UHD display, ASUS VP28UQG gives you stunning 3840 x 2160 resolution visuals with a high pixel density for incredible photo-realistic visuals and sharp, crisp text. The VP28UQG gives you four times the pixels of similar-sized Full HD 1080p displays so you get more detailed images when playing games or watching movies, as well as more onscreen desktop space for your various work windows. VP28UQG draws you into immersive virtual worlds, with greatly-textured elements and terrain maps that boast impressive levels of detail.
  • Lightning-fast 1 ms rapid response time
    ASUS VP28UQG eliminates smearing and motion blur thanks to a 1 ms response time. This astonishing visual performance lets you react instinctively to what you see onscreen, so you can take corners like a pro race car driver, or take an enemy out with a headshot as he peeks around cover. In addition, Adaptive-Sync/FreeSync eliminates screen tearing and choppy frame rates for even more seamlessly smooth gameplay.
  • Robust connectivity
    Whether you're playing games or streaming videos, ASUS VP28UQG gives you smooth 4K UHD content playback, thanks to a 60 Hz refresh rate and native 4K UHD support via DisplayPort 1.2, HDMI.
  • ASUS-exclusive GamePlus technology
    ASUS VP28UQG features the ASUS-exclusive GamePlus to give you in-game enhancements that help you get more out of your game. These tools allow gamers to practice and improve on their gaming skills.
  • Ultra-Low Blue Light technology
    ASUS Ultra-Low Blue Light technology reduces the amount of harmful blue light emitted by ASUS VP28UQG. You can access and select four different filter settings onscreen easily through the OSD menu to find the best one that suits the task at hand.
  • Flicker-Free technology
    Flicker-Free technology reduces flicker to give you a comfortable gaming experience. This minimizes instances of eyestrain and other potentially damaging eye ailments when you're embroiled in long, drawn-out gaming sessions.
ASUS VP28UQG - LED monitor - 4K - 28"
LED-backlit LCD monitor - 28"
Energy Class
Class B
Energy Consumption per Year
61 kWh
Power Consumption (On mode)
42 W
Aspect Ratio
16:9
Native Resolution
4K 3840 x 2160
Pixel Pitch
0.16 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1 / 100000000:1 (dynamic)
Response Time
1 ms (grey-to-grey)
Colour Support
1.074 billion colours (10-bit)
Input Connectors
2xHDMI, DisplayPort
Display Position Adjustments
Tilt
66.04 cm x 22.94 cm x 44.58 cm
5.4 kg
Environmental Standards
TCO Certified Displays 8, ENERGY STAR Qualified
UL, VCCI, BSMI, cUL, WHQL, CB, CCC, PSB, FCC, RoHS, WEEE, PSE Mark, EAC, RCM, CEL level 1, TUV Rheinland Low Blue Light Certification, TUV Rheinland Flicker Free Certification, DisplayPort 1.2
3-year warranty
Display Type
Energy Class
Class B
61 kWh
42 W
Diagonal Size
28"
Aspect Ratio
16:9
Native Resolution
4K 3840 x 2160
Pixel Pitch
0.16 mm
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Response Time
1 ms (grey-to-grey)
Vertical Refresh Rate
40 - 60 Hz
Horizontal Refresh Rate
24 - 99 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
LED backlight
HDCP, ASUS Splendid Video Intelligence Technology, Skin-Tone Selection, Trace Free Technology, ASUS GamePlus, ASUS VividPixel Technology, Low Blue Light Mode, Flicker Free technology, Colour Temperature Selection
66.04 cm x 22.94 cm x 44.58 cm - with stand
5.4 kg
DisplayPort , 2 x HDMI , Audio line-out
Mechanical
Tilt
Tilt Angle
-5/+20
VESA Mounting Interface
100 x 100 mm
1 x DisplayPort cable
Security Slot Type
Kensington security slot
60 Watt
Power Consumption (Off Mode)
0.5 Watt
On / Off Switch
No
Dimensions & Weight Details
Without stand - width: 66.04 cm - depth: 6.22 cm - height: 38.08 cm - weight: 4.6 kg , With stand - width: 66.04 cm - depth: 22.94 cm - height: 44.58 cm - weight: 5.4 kg
TCO Certified
ENERGY STAR Certified
Limited warranty - 3 years , Limited warranty - LCD panel - 3 years
Asus VP28UQG 28 Bundle deal on Asus VP28UQG 28" 4k Gaming FreeSync DP HDMI
£378.43
Diagonal Size: 28in
Response Time: 1ms
Interfaces: HDMI
Brand: Asus
Price Range Ex VAT: 150 - 300
