Imagine all the functionalities of a traditional desktop PC in a chic, compact box with a footprint slightly larger than a standard DVD jewel case. Meet the ASUS VivoPC.
Powered by an Intel processor and featuring SonicMaster technology, VivoPC paves the way for a complete day-to-day computing and true-to-life cinematic multimedia experience. Sit back and enjoy as its built-in 802.11ac Wi-Fi gives you speeds up to three times faster than standard wireless-N speeds and stable connections for online Web surfing, media streaming, and online gaming.
Chic and elegant design
VivoPC defies convention and redefines the look of a desktop PC. Simple and elegant, its spun-metal finish fits right in your living or workspace. -
Spun-metal finish keeps it in the family
Sporting the same spun-metal design found on other ASUS offerings, VivoPC continues on the ASUS tradition of fine aesthetics and a quality finish. -
Mini yet powerful
Do not judge VivoPC by its size. It provides the same performance as your traditional desktop PC. From plowing through spreadsheets to enjoying viral videos, VivoPC makes light work of these tasks. -
Faster Wi-Fi speeds and wireless control
Surf your favorite web pages or stream movies and music from online libraries more smoothly with the 802.11ac dual band Wi-Fi. Wi-Fi GO! technology gives you full control over VivoPC without having to get up off the couch - it turns your smartphone or tablet into a remote control where you can access VivoPC through the remote desktop function and virtual keyboard or mouse. -
Pitch-perfect audio
VivoPC has everything you need right out of the box. Built-in SonicMaster speakers and MaxxAudio tuning ensures pitch-perfect audio, every time. -
Intuitive audio effect setting
SonicMaster and AudioWizard audio utilities found on VivoPC ensure the best sound for your movies and music. A few simple clicks loads up optimized audio setting for your Hollywood blockbuster or ripping guitar solos. -
Easy-access for DIY upgrades
VivoPC keeps things simple when it is time for an upgrade. A user-friendly slide-out cover gives you quick, easy access to its internals for DIY memory and hard drive upgrades. -
Full compatibility for convenient connectivity
VivoPC comes with numerous USB 2.0 and USB 3.0 ports, with the latter delivering faster device charging and up to 10 times faster transfer speeds than previous generation USB, are available for quick file transfers and device sync-ups.
- ASUS Vivo PC VM40B - mini PC - Celeron 1007U 1.5 GHz - 2 GB - HDD 500 GB
- Personal computer - mini PC - ASUS SonicMaster, Maxx Audio support, Asus AudioWizard
- Processor
- Intel Celeron 1007U / 1.5 GHz (Dual-Core)
- Cache Memory
- 2 MB
- Cache Per Processor
- 2 MB
- RAM
- 2 GB (installed) / 16 GB (max) - DDR3 SDRAM - non-ECC - PC3-12800
- Storage Controller
- SATA (SATA 6Gb/s)
- Hard Drive
- HDD 500 GB - SATA 6Gb/s - 7200 rpm
- Optical Storage
- No optical drive
- Card Reader
- 2 in 1
- Graphics Controller
- Intel HD Graphics
- Audio Output
- Stereo - integrated
- Networking
- GigE, 802.11a, 802.11b/g/n, Bluetooth 4.0, Wi-Fi 5
- OS Provided
- Windows 8 64-bit Edition
- Silver
- 19 cm x 19 cm x 5.62 cm
- 1.2 kg
- Environmental Standards
- ENERGY STAR Qualified EPEAT Gold
- Personal computer
- Product Form Factor
- Mini PC
- Silver
Processor / Chipset
- CPU
- Clock Speed
- 1.5 GHz
- Number of Cores
- Dual-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- Chipset Type
- Mobile Intel HM70 Express
Cache Memory
- Installed Size
- 2 MB
- 2 MB
RAM
- Installed Size
- 2 GB / 16 GB (max)
- Technology
- Effective Memory Speed
- 1600 MHz
- Rated Memory Speed
- 1600 MHz
- Memory Specification Compliance
- PC3-12800
- Form Factor
- SO-DIMM 204-pin
- Slots
- 2 (Total) / 1 (empty)
- Unbuffered, dual channel memory architecture
- Configuration Features
- 1 x 2 GB
Hard Drive
- HDD
- Capacity
- 1 x 500 GB
- Interface Type
- SATA 6Gb/s
- Spindle Speed
- 7200 rpm
Storage Controller
- 1 x SATA - integrated
- Controller Interface Type
- SATA 6Gb/s
Optical Storage
- No optical drive
Card Reader
- 2 in 1 card reader
- Supported Flash Memory Cards
- MultiMediaCard, SD Memory Card
Monitor
- Monitor Type
- None.
Graphics Controller
- Integrated
- Graphics Processor
- Intel HD Graphics
- Video Interfaces
- VGA, HDMI
Audio Output
- Integrated
- Sound Output Mode
- Stereo
- Wireless LAN Supported
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, Bluetooth 4.0, IEEE 802.11ac
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
- Bays
- 1 (total) / 0 (free) x internal 3.5" x 1/3H
- Slots
- 1 (total) / 0 (free) x CPU , 2 (total) / 1 (free) x SO-DIMM 204-pin
- 2 x USB 3.0 , 4 x USB 2.0 , 1 x HDMI , 1 x LAN (Gigabit Ethernet) , 1 x TOSLINK , 1 x VGA , 1 x microphone - mini-jack , 1 x headphones - mini-jack , 1 x audio line-in - mini-jack
- Theft/Intrusion Protection
- Power adapter
- Power Provided
- 65 Watt
- Power Factor Correction
Operating System / Software
- OS Provided
Sustainability Information
- EPEAT Compliant
- EPEAT Gold
- ENERGY STAR Certified
- 19 cm
- 19 cm
- 5.62 cm
- 1.2 kg
Asus VivoPC Intel Celeron 1007U 1.5GHz 500GB 2GB USB 3.0 HDMI
