Asus VivoBook N3550 4GB32GB 14.1" Windows 10 - White
Quicklinx: D0TXWS00 Mfr#: E402NA-GA005T
  • Celeron
  • IEEE 802.11n
The latest ASUS EeeBook is an affordable 14-inch compact and lightweight notebook. Exclusive technology used in the production of smartphone touchscreens has been incorporated into the touchpad, giving you a highly sensitive surface for almost instantaneous response and incredible accuracy. Asus eeebook e402 is designed to give you a more intuitive touchpad experience. CPU, Memory and Operating System: Intel Celeron intel dual-core celeron n3350 processor dual core processor. 2.4GHz processor speed. 4GB RAM. Display features: 14 inch screen. High definition display. Resolution 1366 x 768 pixels. Graphics: Intel HD Graphicsintel hd graphics 500 graphics card. Interfaces and connectivity: SD media card reader. Secure Digital (SD), Multi-Media Card (MMC) compatible. 1 USB 2.0 port. 1 USB 3.0 port. 1 Ethernet port. 1 HDMI port. Wi-Fi enabled. Multimedia features: VGA webcam. Built-in mic. Built-in audio sound system. General features: Up to 11 hours battery life. Weight 1.65kg.
ASUS VivoBook E402NA GA005T - 14" - Celeron - 32 GB eMMC
Notebook
Intel Celeron
Storage
32 GB eMMC
Display
14" LED backlight
Integrated Webcam
33.9 cm x 23.5 cm x 2.19 cm
1.65 kg
Notebook
Processor / Chipset
CPU
Intel Celeron
Number of Cores
Dual-Core
64-bit Computing
Storage
Main Storage
32 GB eMMC
Display
14"
LCD Backlight Technology
LED backlight
Widescreen
ASUS Splendid Video Intelligence Technology
Audio & Video
Camera
Sound
Microphone
Input
Keyboard, touchpad
AC Adapter
Input
Output
19 V
Connections & Expansion
Memory Card Reader
(SD Card)
Power adapter
1.65 kg
