Asus VivoBook Max Pentium N3710 4GB 1TB 15.6" Windows 10 - Aqua Blue
Quicklinx: CTQ1WS00 Mfr#: X541SA-XX121T
  • Pentium
  • IEEE 802.11n
  • Bluetooth 4.0
The ASUS VivoBook Max series laptops are designed to give you a truly immersive multimedia experience. Powered by a fast processor, gaming-grade graphics, and SonicMaster audio, the VivoBook Max series gives you outstanding audiovisuals.
  • Designed for immersive entertainment
    The ASUS VivoBook Max series laptops are designed to give you an immersive multimedia experience. ASUS technologies like SonicMaster audio, ASUS Splendid, and ASUS Tru2Life video make your movies and music come alive.
  • Incredible ASUS SonicMaster audio
    ASUS SonicMaster audio, gives the ASUS VivoBook Max series laptops crystal-clear sound. VivoBook Max series laptops feature a special transmission line design to provide rich, deep bass and distinct vocals.
  • Perfect video
    ASUS Tru2Life video technology makes your videos look amazing. It intelligently optimizes each pixel in the video frame to increase sharpness and contrast, so you'll enjoy great image quality.
  • Protect your eyes with ASUS Eye Care
    LED panels emit blue light - a cause of macular degeneration and retinal problems. ASUS Eye Care mode effectively reduces blue light levels to make reading comfortable, and to protect you from potential eye fatigue and other ailments.
  • Faster and easier connections
    ASUS VivoBook Max series laptops give you a wide array of connectivity features that include USB 3.0 Type-C, HDMI and VGA ports, a card reader, and more. The reversible USB Type-C port ensures a proper connection every time. It also provides you with fast data transmission speeds.
  • Easy input
    The ASUS VivoBook VivoBook Max series laptops employ incredible keyboard and touchpad technologies. Enjoy responsive keystrokes and a precise touchpad with palm rejection technology for a great input experience.
  • A superb typing feel
    The full-size, one-piece chiclet keyboard provides a comfortable typing experience. An improved assembly provides a comfortable key travel and minimal key float for more solid and responsive keystrokes.
  • Larger and smarter touchpad
    The larger touchpad found on the VivoBook Max series has a palm rejection feature which differentiates between actual fingertip and palm contact to prevent unintentional cursor movement.
ASUS VivoBook Max X541SA XX121T - 15.6" - Intel Pentium - N3710 - 4 GB RAM - 1 TB HDD
Notebook
Operating System
Win 10 Home 64-bit
Intel Pentium N3710 / 1.6 GHz, up to 2.56 GHz / 2 MB Cache
4 GB DDR3L (provided memory is soldered)
Storage
1 TB HDD / 5400 rpm
Optical Drive
DVD-Writer
Display
15.6" LED backlight 1366 x 768 / HD
Graphics
Intel HD Graphics 405
Numeric Keypad
Integrated Webcam
802.11b/g/n, Bluetooth 4.0, 10/100 Ethernet
3-cell
Aqua blue
38.14 cm x 25.15 cm x 2.76 cm
2 kg
Environmental Standards
- EPEAT Climate+
Notebook
Operating System
Windows 10 Home 64-bit Edition
Processor / Chipset
CPU
Max Turbo Speed
2.56 GHz
Number of Cores
Quad-Core
Cache
L2 - 2 MB
64-bit Computing
Intel Burst Technology
RAM
4 GB (provided memory is soldered)
DDR3L SDRAM
Speed
1600 MHz
Storage
Main Storage
1 TB HDD SATA 3Gb/s / 5400 rpm
Optical Drive
DVD±RW (±R DL)
Display
15.6"
LCD Backlight Technology
LED backlight
Resolution
1366 x 768 (HD)
Widescreen
Image Aspect Ratio
16:9
Colour Gamut
45% NTSC
ASUS Splendid Video Intelligence Technology
Audio & Video
Graphics Processor
Camera
Yes - VGA
Sound
Stereo speakers, microphone
Audio Features
Output: ASUS SonicMaster, ASUS Bang & Olufsen ICEpower, ASUS AudioWizard
Input
Keyboard, touchpad
Numeric Keypad
ASUS Smart Gesture technology
Communications
Wireless
Network Interface
10/100 Ethernet
3-cell
36 Wh
AC Adapter
Input
Output
33 Watt, 19 V, 1.75 A
Connections & Expansion
Interfaces Details
Headphone/microphone combo jack , USB 3.0 , VGA , USB 2.0 , HDMI , LAN , USB-C Gen 1
Memory Card Reader
Yes (SD Card, SDHC Card, SDXC Card)
Aqua blue
System password, hard drive password
Power adapter
2 kg
Sustainability Information
TCO Certified
EPEAT Compliant
EPEAT Climate+
