Asus VivoBook Core i3-5005U 4GB 1TB 15.6" Windows 10
Quicklinx: DRTRWS00 Mfr#: X540LA-DM1052T
Display Size: 15.6in
Processor Model: I3-5005U
Operating System: Windows 10 Home 64-bit Edition
Installed Memory: 4GB, 4GB
Hard Drive Capacity: 1TB
  • Core i3
  • IEEE 802.11n
  • Bluetooth 4.0
£298.56 ex VAT
£358.27 inc VAT
The ASUS X540 Series is powered by a powerful processor to give you smooth and responsive computing performance. It is an ideal daily computing platform.
  • Faster and easier connections with USB Type-C
    The reversible USB Type-C port makes connecting devices much easier, and gives you super-fast USB 3.1 Gen 1 speeds of up to 5 Gbit/s so you can transfer a 2GB movie to a USB drive in less than 2 seconds! Its compact port design even helps preserve X540's thin dimensions. X540 still carries the traditional USB 3.0 and USB 2.0 ports to ensure compatibility with all your USB devices. X540 has additional connectivity options including HDMI and VGA output for external displays, a 3-in-1 SD/SDHC/SDXC card reader, an RJ-45 Ethernet port, and a DVD Super Multi optical disc drive.
  • Expansive audio, tuned by experts
    A mixture of hardware, software, and tuning, SonicMaster was developed with the clear goal of giving you the best notebook PC audio. A professional codec ensures precise sound performance; while an optimized amplifier, larger speakers and resonance chambers deliver powerful audio output and deeper bass. Additional signal processing helps fine tune the hardware, filtering noise and improving clarity so you can enjoy unrivaled audio on your X Series.
  • Crafted speaker design for greater sound
    X540 features round speakers that maximize every cubic millimeter of available chassis space to give you better low frequency performance and reduced noise. The extra-large 19.4cc chamber provides superior bass and excellent sound clarity.
  • Lightweight design
    ASUS X540 has a solid and lightweight chassis - ideal to take with you when you're out and about. Its premium brushed finish turns heads and makes sure that you stand out from the crowd.
  • Enjoy a world of color with ASUS Splendid Technology
    To ensure only the very best images, ASUS Splendid Technology has color temperature correction to reproduce richer, deeper colors. It features four visuals modes which can be accessed with a single click. Vivid Mode optimizes contrast for browsing photos or watching videos and movies; Eye Care Mode reduces blue light levels and is ideal when you're reading for long hours. Normal Mode has been tuned for daily tasks; while Manual Mode is for advanced color adjustments.
  • Protect your eyes with ASUS Eye Care
    Most LED panels emit blue light - the main cause of macular degeneration and retinal problems. ASUS Eye Care mode effectively reduces blue light levels by up to 33% to make reading comfortable, and to protect you from potential eye fatigue and other ailments.
  • Ergonomic keyboard design
    Typing is now more comfortable than ever with the X Series' full-size one-piece chiclet keyboard. An improved back assembly provides 1.8 mm of key travel and minimal key float, so you get a more solid typing feel.
  • Stays cool, even after hours of use
    ASUS IceCool Technology gives X Series a unique internal design that addresses uncomfortable heating issues by preventing heat build-up under the palm rest. This keeps the palm rest surface between 28°C to 35°C - significantly lower than body temperature. This exclusive internal layout places heat producing components away from you, and when combined with exceptional cooling from the heat pipes and vents, ensures you stay comfortable even after long hours of use.
ASUS VivoBook X540LA-DM1052T - 15.6" - Core i3 5005U - 4 GB RAM - 1 TB HDD
Notebook
Operating System
Win 10 Home 64-bit
Intel Core i3 (5th Gen) 5005U / 2 GHz / 3 MB Cache
4 GB DDR3L (provided memory is soldered)
Storage
1 TB HDD / 5400 rpm
Optical Drive
No optical drive
Display
15.6" LED backlight 1920 x 1080 / Full HD - matte
Graphics
Intel HD Graphics 5500
Numeric Keypad
Integrated Webcam
802.11b/g/n, Bluetooth 4.0, 10/100 Ethernet
3-cell
Gold, chocolate black
38.14 cm x 25.15 cm x 2.72 cm
1.9 kg
Notebook
Operating System
Processor / Chipset
CPU
Number of Cores
Dual-Core
Cache
3 MB
64-bit Computing
RAM
4 GB (provided memory is soldered)
DDR3L SDRAM
Speed
1600 MHz - 1600 MHz
Rated Speed
1600 MHz
Storage
Main Storage
1 TB HDD SATA / 5400 rpm
Display
15.6"
LCD Backlight Technology
LED backlight
Resolution
1920 x 1080 (Full HD)
Widescreen
ASUS Splendid Video Intelligence Technology, matte
Audio & Video
Graphics Processor
Camera
Yes - VGA
Sound
Stereo speakers, microphone
Audio Features
ASUS SonicMaster, ASUS AudioWizard
Input
Keyboard, touchpad
Numeric Keypad
ASUS Smart Gesture technology
Communications
Wireless
Network Interface
10/100 Ethernet
3-cell
33 Wh
AC Adapter
Input
Output
45 Watt, 19 V, 2.47 A
Connections & Expansion
Headphone/microphone combo jack , USB 3.1 Gen 1 , VGA , USB 2.0 , HDMI , LAN , USB-C 3.1 Gen 1
Memory Card Reader
3 in 1 (SD Card, SDHC Card, SDXC Card)
System password, hard drive password, ASUS IceCool design
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Power adapter
1.9 kg
Software applications
Asus VivoBook Core i3-5005U 4GB 1TB 15.6 Bundle deal on Asus VivoBook Core i3-5005U 4GB 1TB 15.6" Windows 10
£478.88
saving £3.64
£398.19
Optical Storage: None
Graphics: Intel HD Graphics 5500
Hard Drive Type: HDD
Brand: Asus
Price Range Ex VAT: 150 - 300
