Asus VivoBook 15 Intel Core i5-1135G7 8GB 512GB SSD 15.6" Windows 11 Home S
Quicklinx: HC6LWS00 Mfr#: X1500EA-BQ2182W
  • Core i5
  • IEEE 802.11n
Whether for work or play, ASUS Vivobook 15 is the entry-level laptop that delivers powerful performance and immersive visuals. Its NanoEdge display boasts wide 178° viewing angles and a matte anti-glare coating for a truly engaging experience. Inside, it's powered by an advanced processor with huge RAM, and features discrete graphics. A dual-storage design with gives you the perfect combination of large storage capacity and fast data read / write speeds.
  • Fast and efficient
    With a powerful processor and discrete graphics. Vivobook 15 helps you get things done swiftly and efficiently.
  • Store more, do more
    Vivobook 15 has a dual-storage design to give you the benefits of superfast data performance and a large storage capacity. Install apps on the SSD for quicker response and loading times, and use the HDD to store large files such as movies, music libraries, and photo albums.
  • Get a wider view of the world
    The NanoEdge display gives Vivobook 15 a vast screen area for an immersive viewing experience for work and play. Its wide-view panel features an anti-glare coating to reduce unwanted distractions from irritating glare and reflections, so you can truly focus on what's in front of you.
  • Empower your dynamic lifestyle
    With an overall weight of just 1.8kg, the extremely portable Vivobook 15 is the lightweight laptop that keeps up with your fast-paced lifestyle.
  • Just touch to log in
    Accessing Vivobook 15 has never been easier or more secure! With the built-in fingerprint sensor in the touchpad and Windows Hello, there's no need to type in your password every time - all you need is a single touch!
  • Exactly your type
    The full-size backlit keyboard on Vivobook 15 is perfect for working in dim environments. Ergonomically designed, its sturdy, one-piece construction and 1.4mm key travel provide a comfortable typing experience.
  • Constantly connected
    Vivobook 15 is equipped with the reversible USB-C 3.2 port, featuring an any-way-up design that makes connecting devices as easy as possible. So you can easily connect all your current peripherals, displays and projectors with zero hassle.
  • Internal protection / HDD protection and chassis enhancements
    Vivobook 15 features E-A-R HDD shock dampening to protect your data from every bump, while its reinforced chassis improves typing and allows you to open and close the lid in one smooth motion.
ASUS VivoBook 15 X1500EA-BQ2182W - 15.6" - Intel Core i5 - 1135G7 - 8 GB RAM - 512 GB SSD
Notebook
Operating System
Win 11 Home
Intel Core i5 (11th Gen) - 1135G7 / 2.4 GHz, up to 4.2 GHz / 8 MB Cache
8 GB DDR4 (provided memory is soldered)
Storage
512 GB SSD - NVMe
Display
15.6" 1920 x 1080 / Full HD @ 60 Hz
Graphics
Intel Iris Xe Graphics
Numeric Keypad
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 4.1
2-cell
Security
Firmware Trusted Platform Module (TPM) Security Chip
Indie black
36 cm x 23.5 cm x 1.99 cm
1.8 kg
Environmental Standards
ENERGY STAR Qualified
Notebook
Operating System
Windows 11 Home
Processor / Chipset
CPU
Intel Core i5 (11th Gen) 1135G7 / 2.4 GHz
Max Turbo Speed
4.2 GHz
Number of Cores
Quad-Core
Cache
8 MB
Intel Smart Cache
RAM
8 GB (provided memory is soldered)
DDR4 SDRAM
Storage
Main Storage
512 GB SSD M.2 PCIe 3.0 - NVM Express (NVMe)
Display
15.6"
Resolution
1920 x 1080 (Full HD)
V-Sync Rate at Max Res.
60 Hz
Widescreen
Image Aspect Ratio
16:9
Image Brightness
250 cd/m²
Colour Gamut
45% NTSC
Anti-glare, IPS-level, 83% screen-to-body ratio, NanoEdge display, 178° viewing angle
Audio & Video
Graphics Processor
Video System Features
Functions as Intel UHD graphics (for single-channel memory)
Camera
Yes - VGA
Sound
Stereo speakers, microphone
Input
Keyboard, touchpad
Numeric Keypad
Chiclet keyboard, 1.4mm travel distance
Communications
Wireless
Single stream (1x1)
2-cell Lithium Ion
37 Wh
AC Adapter
Input
AC 100-240 V (50/60 Hz)
Output
45 Watt, 19 V, 2.37 A
Connections & Expansion
Interfaces Details
Headphone/microphone combo jack , USB 3.2 Gen 1 , 2 x USB 2.0 , USB-C 3.2 Gen 1 , HDMI
Software
Software Included
Microsoft 365 (1 month trial), MyASUS, McAfee LiveSafe
Indie black
Security
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Power adapter
1.8 kg
Sustainability Information
ENERGY STAR Certified
