Asus VH192D 18.5" 1366x768 5ms VGA Black Monitor
Quicklinx: 756VWS00 Mfr#: VH192D
Diagonal Size: 18.5in
Max Resolution: 1366 x 768
Response Time: 5ms
Speakers: None
Interfaces: VGA (HD-15)
£62.51 ex VAT
£75.01 inc VAT
With global resources becoming scarcer and the impact our demands have made on the planet becoming increasingly visible, green computing has become a critical issue in recent times. The VH192D LCD monitor adopts green power technology which uses just two lamps to save 28% power consumption and an advanced optical film to ensure brilliant image performance without sacrificing brightness.
18.5" 16:9 widescreen with HD resolution and anti-reflection glare panel enables borderless full-screen video display and more vibrant color performance.
ASCR (ASUS Smart Contrast Ratio) technology automatically adjusts the luminance of the backlight for better displays according to the image contents, and improves the contrast ratio to 10000:1 - resulting in more realistic depictions of night scenes during games or movies.
Aspect Control function allows users to select a preferred display mode among Full and 4:3 for true-to-life Full HD 1080p gaming or movie watching without any data loss or image distortion.
Splendid Video Intelligence technology adopts a color engine to detect activation and usage of video applications and automatically optimizes image quality with intelligent color, brightness, contrast and sharpness corrections for the best visual results. The Splendid offers 5 video modes designed for scenery, theater, gaming, night view, and standard images, 3 skin tones of yellowish, natural and reddish to add a human touch to videos on PC. You can see optimized images on screen and select five modes via hotkey quickly at your will.
Glare black frame and smooth base design create a fresh new look of LCD monitors Convenient key controls for functional set-up in the multi-language OSD. Cable manager gets rid of tangling cables and wires.
  • Delivers vibrant images with green power efficiency
  • Vibrant and excellent visual quality
  • ASCR (ASUS Smart Contrast Ratio) technology
  • Aspect Control
  • Splendid Video Intelligence technology
  • Stylish and user-friendly design for modern sophistication
Diagonal Size
18.5 in
Max Resolution
1366 x 768
Response Time
5 ms
Speakers
None
VGA (HD-15)
Aspect Ratio
16:9
Dimensions & Weight / Depth
38.7 cm
Dimensions & Weight / Height
21 cm
Dimensions & Weight / Width
44.2 cm
Display (Projector) / Dot Pitch / Pixel Pitch
0.3 mm
Display (Projector) / Image Brightness
250 cd/m2
Display (Projector) / Image Contrast Ratio
10000:1
Header / Product Line
ASUS
TFT active matrix
Display (Projector) / Colour Support
24-bit (16.7 million colours)
Display (Projector) / Colour Support (EA)
16.7 million colors
Display (Projector) / Diagonal Size (metric)
47 cm
Display (Projector) / Display Positions Adjustments
Tilt
Display (Projector) / Dynamic Contrast Ratio
10000:1
Display (Projector) / Form Factor
Desktop
Display (Projector) / Image Max H-View Angle
170
Display (Projector) / Image Max V-View Angle
160
Display (Projector) / Type
LCD display
Display (Projector) / Widescreen
Widescreen
Header / Compatibility
PC
Header / Manufacturer
ASUSTeK COMPUTER
Header / Model
VH192D
Miscellaneous / Microsoft Certification
Certified for Windows Vista
Service & Support / Type
3 years warranty
3.7 kg
Asus VH192D 18.5 Bundle deal on Asus VH192D 18.5" 1366x768 5ms VGA Black Monitor
£162.27
Response Time: 5ms
Speakers: None
Brand: Asus
Price Range Ex VAT: 50 - 100
