Asus VG278Q 27 eSport FreeSync DP HDMI DVI
Quicklinx: D2BXWS00 Mfr#: VG278Q
Marketing description is not available.
  • Lightning-fast response time
    ASUS VG278Q boasts a fast response time to eliminate smearing and motion blur. This lets you react instantly to what you see on the screen, especially in fast-paced games.
  • Incredible refresh rate
    With an astonishing refresh rate, fast-moving visuals pose no problem for VG278Q. There's no frustrating lag, so you get the upper hand in first person shooters, racers, real-time strategy and sports titles.
  • Flicker-free technology
    Flicker-free technology reduces flicker to give you a comfortable gaming experience. This minimizes instances of eyestrain and other potentially damaging eye ailments when you're embroiled in long, drawn-out gaming sessions.
  • Ergonomically designed
    ASUS VG278Q is specially designed for long marathon gaming sessions. Its ergonomically designed stand lets you adjust the tilt, swivel, pivot, and height of the monitor so you always find your ideal viewing position.
ASUS VG278Q - LCD monitor - Full HD (1080p) - 27"
LCD monitor - 27"
Energy Class
Class F
Power Consumption (On mode)
26.1 W
Adaptive-Sync Technology
AMD FreeSync
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.311 mm
Brightness
400 cd/m²
Contrast Ratio
1000:1 / 100000000:1 (dynamic)
Response Time
1 ms (grey-to-grey)
Colour Support
16.7 million colours
Colour Gamut
72% NTSC
Input Connectors
HDMI, DVI-D, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare
61.9 cm x 21.1 cm x 37.6 cm
5.6 kg
UL, VCCI, BSMI, cUL, WHQL, CB, CCC, FCC, RoHS, KCC, WEEE, PSE Mark, MEPS, J-MOSS, ErP Ready, E-Standby, UkrSEPRO, RCM, CEL level 1, TUV Rheinland Low Blue Light Certification, CU, TUV Rheinland Flicker Free Certification
3-year warranty
Display Type
LCD monitor / TFT active matrix
Energy Class
Class F
Diagonal Size
27"
AMD FreeSync
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.311 mm
Brightness
400 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
72% NTSC
Response Time
1 ms (grey-to-grey)
Vertical Refresh Rate
40 - 144 Hz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Screen Coating
Anti-glare
HDCP, Skin-Tone Selection, Trace Free Technology, ASUS Smart Contrast Ratio (ASCR), Smart View Technology, 5-way Navigation Key, ASUS GamePlus, ASUS VividPixel Technology, Low Blue Light Mode, Flicker Free technology, ASUS EyeCare Technology, ASUS GameVisual Technology, Colour Temperature Selection, GameFast Input Technology, 72% NTSC colour gamut
61.9 cm x 21.1 cm x 37.6 cm - with stand
5.6 kg
Audio
Speakers - stereo
Output Power / Channel
2 Watt
HDMI , DisplayPort , DVI-D (dual link) , Audio line-in , Headphones
Mechanical
Tilt Angle
-5/+33
Swivel Angle
180
Rotation Angle
180
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
1 x audio cable
26.1 W
26.1 kWh/1000h
Power Consumption (Typical)
40 Watt
Power Consumption (Off Mode)
0.5 Watt
Dimensions & Weight Details
With stand - width: 61.9 cm - depth: 21.1 cm - height: 37.6 cm - weight: 5.6 kg , Without stand - width: 61.9 cm - depth: 5 cm - height: 36.3 cm - weight: 3.2 kg
Limited warranty - 3 years ¦ Limited warranty - LCD panel - 3 years
