Asus VG245Q 24" 1920x1080 Gaming Monitor 1ms DP HDMI D-Sub
Quicklinx: CXNYWS00 Mfr#: VG245Q
Diagonal Size: 24in
Max Resolution: 1920 x 1080
Response Time: 1ms
Speakers: Speaker(s)
Interfaces: DisplayPort, HDMI, VGA (HD-15)
£173.61 ex VAT
£208.33 inc VAT
Built for the perfect console gaming experience, the 24" ASUS VG245Q Full HD gaming monitor features an ultrafast response time and high refresh rate. It also has GameFast input technology for lag-free experience along with two low input lag HDMI ports and one DisplayPort, so you can enjoy super-smooth visuals, and keep it hooked up to two devices. In addition, AMD FreeSync technology helps eliminate image tearing for fast gameplay over HDMI input for smooth gameplay.
  • GameFast input technology - because milliseconds count
    Input lag is the time delay between pressing a button and seeing its effects onscreen. Slow input lag may cause a laggy connection, that gives you trouble keeping up with the fast action. The VG245Q features the GameFast input technology to minimize input lag, so you'll always be up to speed with the action at the precise timing to respond as quickly as you should.
  • Lightning-fast response time and high refresh rate
    ASUS VG245Q boasts a fast response time, so all your fast-paced gaming action will be rendered smoothly without smearing, ghosting and motion blur. You'll be able to react and respond quickly to what you see onscreen - a definite advantage in the gaming arena.
  • Flexible connectivity - dual HDMI plus one DisplayPort
    ASUS VG245Q features two HDMI ports and one DisplayPort to give you more flexibility, allowing you to connect your game console, PC, and any other HDMI device at the same time. There's no need to frequently plug and change your connection.
  • Super-smooth visuals with AMD FreeSync
    ASUS VG245Q features AMD FreeSync technology to eliminate screen tearing and choppy frame rates to give you seamless visuals and smooth gameplay. This gives you the upper hand in first person shooters, racing, real-time strategy and sports titles.
  • GamePlus technology
    ASUS VG245Q features the ASUS-exclusive GamePlus hotkey to give you in-game enhancements, that help you get more out of your game.
  • GameVisual technology
    ASUS GameVisual technology has six pre-set display modes to optimize visuals for different types of content. This unique feature can be easily accessed through a hotkey or the onscreen display (OSD) settings menu.
  • Ultra-Low Blue Light technology
    ASUS Ultra-Low Blue Light technology reduces the amount of blue light. You can access and select four different filter settings onscreen easily to find the optimal one, that suits the task at hand.
  • Ergonomically designed and wall-mountable
    ASUS VG245Q is specially designed for long marathon gaming sessions. Its ergonomically designed stand lets you adjust the tilt, swivel, pivot, and height of the monitor, so you always find your ideal viewing position. It can also be VESA wall-mounted to fit in any limited space.
ASUS VG245Q - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class A
Energy Consumption per Year
30 kWh
Power Consumption (On mode)
21 W
5-way joystick
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.2768 mm
Brightness
250 cd/m²
Contrast Ratio
100000000:1 (dynamic)
Response Time
1 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
2xHDMI, VGA, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare
56.1 cm x 21.1 cm x 35.9 cm
5.1 kg
Environmental Standards
TCO Certified Displays 7, ENERGY STAR Qualified
UL, TUV GS, cUL, WHQL, CB, TUV Ergo, FCC, RoHS, ISO 9241-307, WEEE, ErP Ready, UkrSEPRO, TUV Rheinland Low Blue Light Certification, CU, TUV Rheinland Flicker Free Certification
3-year warranty
Display Type
Energy Class
Class A
30 kWh
21 W
Diagonal Size
24"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2768 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
1 ms (grey-to-grey)
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Screen Coating
Anti-glare
Backlight Technology
WLED
Trace Free Technology, ASUS Smart Contrast Ratio (ASCR), 72% NTSC colour gamut, ASUS GamePlus, Low Blue Light Mode, Flicker Free technology, ASUS EyeCare Technology, FreeSync Technology, ASUS GameVisual Technology, GameFast Input Technology
56.1 cm x 21.1 cm x 35.9 cm - with stand
5.1 kg
Audio
Speakers - stereo
Output Power / Channel
2 Watt
Input
5-way joystick
VGA , HDMI , DisplayPort , Headphone input , Audio line-out
Mechanical
Tilt Angle
-5/+33
Swivel Angle
180
Rotation Angle
180
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
40 Watt
Power Consumption (Off Mode)
0.5 Watt
On / Off Switch
No
Dimensions & Weight Details
Without stand - width: 56.1 cm - depth: 5 cm - height: 32.9 cm , With stand - width: 56.1 cm - depth: 21.1 cm - height: 35.9 cm - weight: 5.1 kg
ENERGY STAR Certified
TCO Certified
Limited warranty - 3 years , Limited warranty - LCD panel - 3 years
Asus VG245Q 24 Bundle deal on Asus VG245Q 24" 1920x1080 Gaming Monitor 1ms DP HDMI D-Sub
£272.78
Diagonal Size: 24in
Response Time: 1ms
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: Asus
Price Range Ex VAT: 150 - 300
