The 19" regular LED monitor VB199T adopts advanced mercury-free and wide viewing angle LED-backlit panel to deliver many benefits of better visual details with high contrast ratio, energy saving with lower power consumption, and reduction of environmental pollution.
Ultra wide viewing angle
Come along with wide viewing angle LED panel to minimize the color shift from any viewing angle. -
Smart contrast ratio
Adopt ASUS Smart contrast ratio (ASCR) technology to provide the high contrast ratio, which can dynamically adjust contrast between black and white, and to create sharper and brighter images, especially during video and movies. -
Splendid video intelligence technology
The exclusive Splendid video intelligence technology optimizes video performance and image fidelity by enhancing color, brightness, contrast, and sharpness.
- ASUS VB199T - LED monitor - 19"
- LED-backlit LCD monitor - 19"
- Power Consumption (On mode)
- 18.4 W
- Panel Type
- IPS
- Aspect Ratio
- 5:4
- Native Resolution
- 1280 x 1024
- Pixel Pitch
- 0.294 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 50000000:1 (dynamic)
- Response Time
- 5 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Input Connectors
- DVI-D, VGA
- Speakers
- Integrated
- Tilt
- Black
- 41.3 cm x 21 cm x 41 cm
- 3.2 kg
- Environmental Standards
- ENERGY STAR Qualified
- UL, TUV GS, VCCI, C-Tick, BSMI, cUL, WHQL, CB, CCC, TUV Ergo, PSB, FCC, RoHS, ISO 9241-307, WEEE, J-MOSS
- 3-year warranty
- Display Type
- 18.4 W
- Diagonal Size
- 19"
- Viewable Size
- 19"
- Panel Type
- IPS
- Aspect Ratio
- 5:4
- Native Resolution
- 1280 x 1024
- Pixel Pitch
- 0.294 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- Vertical Refresh Rate
- 50 - 76 Hz
- Horizontal Refresh Rate
- 53 - 80 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- LED backlight
- Controls & Adjustments
- Volume, brightness, colour temperature
- sRGB colour management, HDCP, ASUS Splendid Video Intelligence Technology, Skin-Tone Selection, ASUS Smart Contrast Ratio (ASCR), ASUS Splendid Video Preset Mode, 72% NTSC colour gamut
- Black
- 41.3 cm x 21 cm x 41 cm - with stand
- 3.2 kg
Audio
- Speakers - stereo - integrated
- Output Power / Channel
- 1 Watt
- DVI-D , VGA , Audio line-in
Mechanical
- Tilt
- Tilt Angle
- -5/+20
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x VGA cable , 1 x audio cable , 1 x DVI cable
- Power Supply
- Internal
- Voltage Required
- AC 120/230 V (50/60 Hz)
- 17.1 Watt
- Power Consumption Stand by
- 0.37 Watt
- Power Consumption Sleep
- 0.35 Watt
- Dimensions & Weight Details
- Without stand - width: 41.3 cm - depth: 6.48 cm - height: 34.24 cm , With stand - width: 41.3 cm - depth: 21 cm - height: 41 cm - weight: 3.2 kg
- ENERGY STAR Certified
- Limited warranty - 3 years , Limited warranty - LCD panel - 3 years
Bundle includes:
Microsoft Office 365 Business Premium ‘in a box’ 1 year subscription/license worth £99.17 | in stock |
£214.91
C2G 1m DVI-D™ M/M Dual Link Digital Video Cable | In Stock | £7.63 |
C2G 2m DVI-D™ M/M Dual Link Digital Video Cable | In Stock | £8.91 |
C2G 5m DVI-D™ M/M Dual Link Digital Video Cable | In Stock | £16.15 |
C2G Velocity™ DVI-D™ Male to HDMI® Female Inline Adapter | In Stock | £5.00 |
C2G 2m HDMI to DVI-D Digital Video Cable | In Stock | £8.28 |
