Asus VA24EHF Eye Care Gaming Monitor 23.8-inch
Quicklinx: HTQFWS00 Mfr#: VA24EHF
Diagonal Size: 24in
Max Resolution: 1920 x 1080
Response Time: 1ms
Speakers: None
Interfaces: HDMI
£102.92 ex VAT
£123.50 inc VAT
ASUS VA24EHF Eye Care Gaming Monitor
SMOOTH YOUR WORK & PLAY
ASUS VA24EHF Eye Care Gaming Monitor features 23.8-inch IPS panel with Full HD (1920 x 1080) resolution, providing 178° wide viewing angle panel and vivid image quality. With fast 100Hz refresh rate and Adaptive-Sync technology to eliminate screen tearing and choppy frame rates for the smoother-than-ever experience. It also features TÜV Rheinland-certified Flicker-free and Low Blue Light technologies to ensure a comfortable viewing experience.
Fluid viewing experience with 100Hz SmoothMotion
ASUS VA24EHF with fast 100Hz refresh rate and Adaptive-Sync technology to eliminate screen tearing and choppy frame rates. It refreshes content on the display 1.67-time faster than the one with a standard 60Hz refresh rate, giving you more fluid animation in video, casual gaming, and day-to-day work, can all benefit from the smoother-than-ever experience.
Smooth Game Play
A 100Hz refresh rate and 1ms Moving Picture Response Time (MPRT) help reduce smearing and motion blur, making VA24EHF perfect for fast-paced games that require quick reactions to what’s happening onscreen. In addition, Adaptive-Sync technology helps eliminate screen tearing and choppy frame rates for ultra-smooth gameplay.
ASUS-exclusive GamePlus Technology
When it comes to design, ASUS always has customers in mind – ASUS exclusive GamePlus hotkey with Crosshair, Timer, FPS counter and Display Alignment functions to give you in-game enhancements that help you get more out of your game. This function is co-developed with input from pro gamers, allowing them to practice and improve their gaming skills.
ASUS Blue Light Filter
The TÜV Rheinland-certified ASUS Blue Light Filter protects you from harmful blue light. It's easy to access, intuitive and flexible with seamless adjustment (0 to Maximum) via the OSD menu. ASUS displays has undergone stringent performance tests and has been certified by TÜV Rheinland laboratories, a global provider of technical, safety, and certification services.
Lifelike views with 178° wide view angle
Full HD resolution and frameless IPS panel provides 178° viewing angles, both horizontally and vertically, so you can enjoy its beautiful visuals from almost any direction.
Frameless Design
Makes it perfect for almost-seamless multi-display setups that give you an even greater degree of immersion.
  • Fluid viewing experience with 100 Hz smoothmotion
    ASUS VA24EHF with fast 100 Hz refresh rate and Adaptive-Sync technology to eliminate screen tearing and choppy frame rates. It refreshes content on the display 1.67-time faster than the one with a standard 60 Hz refresh rate, giving you more fluid animation in video, casual gaming, and day-to-day work, can all benefit from the smoother-than-ever experience.
  • Smooth game play
    A 100 Hz refresh rate and 1 ms Moving Picture Response Time (MPRT) help reduce smearing and motion blur, making VA24EHF perfect for fast-paced games that require quick reactions to what's happening onscreen. In addition, Adaptive-Sync technology helps eliminate screen tearing and choppy frame rates for ultra-smooth gameplay.
  • Lifelike views with 178° wide view angle
  • Frameless design
  • ASUS Blue light filter
  • ASUS Flicker free technology
    TÜV Rheinland-certified ASUS Flicker free technology eliminates flicker, ensuring comfortable viewing experiences. This technology helps minimize eyestrain and other ailments typically associated with extended hours of viewing.
ASUS VA24EHF - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/1514726
Energy Class
Class D
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080 at 100 Hz
Pixel Pitch
0.2745 mm
Brightness
250 cd/m²
Contrast Ratio
1300:1 / 100000000:1 (dynamic)
Response Time
1 ms (MPRT)
Gaming
Colour Support
16.7 million colours (6-bit+FRC)
Input Connectors
HDMI
Display Position Adjustments
Tilt
Screen Coating
Anti-glare
Voltage
AC 100-240 V (50/60 Hz)
53.952 cm x 20.594 cm x 41.722 cm
2.84 kg
Environmental Standards
TCO Certified Edge Displays, TCO Certified Displays 9, ENERGY STAR Qualified EPEAT Bronze
VCCI, BSMI, ICES-003, CB, CCC, FCC, RoHS, ISO 9241-307, KCC, WEEE, PSE Mark, cTUVus, MEPS, J-MOSS, E-Standby, CEC, UkrSEPRO, KC, ERP, CEL, RCM, EU Energy Label, CU, TUV Rheinland Flicker Free Certification, HDCP 1.4, TUV Rheinland Low Blue Light (Software Solution)
Display Type
Energy Class
Class D
Diagonal Size
24"
Viewable Size
23.8"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2745 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
1 ms (MPRT)
Vertical Refresh Rate
48 - 100 Hz
Horizontal Refresh Rate
30 - 120 kHz
Gaming
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
LED backlight
HDCP, Trace Free Technology, ASUS Splendid Video Preset Mode, ASUS QuickFit Virtual Scale, ASUS GamePlus, Flicker Free technology, Blue Light Filter technology, Adaptive-Sync technology, Colour Temperature Selection, 3-sided bezeless, ASUS EyeCare+ Technology, Variable refresh rate (VRR)
53.952 cm x 20.594 cm x 41.722 cm - with stand
2.84 kg
HDMI
Mechanical
Tilt
Tilt Angle
-5/+23
VESA Mounting Interface
100 x 100 mm
Security Slot Type
Kensington security slot
Input Voltage
14 kWh/1000h
Power Consumption (Typical)
12.02 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption (Off Mode)
0.3 Watt
Dimensions & Weight Details
Without stand - width: 53.952 cm - depth: 4.815 cm - height: 32.315 cm - weight: 2.46 kg , With stand - width: 53.952 cm - depth: 20.594 cm - height: 41.722 cm - weight: 2.84 kg
Shipping Width
60 cm
Shipping Depth
12.5 cm
Shipping Height
44.8 cm
Shipping Weight
4.31 kg
Sustainability Information
TCO Certified
EPEAT Compliant
EPEAT Bronze
ENERGY STAR Certified
10 - 80%
Diagonal Size: 24in
Response Time: 1ms
Speakers: None
Interfaces: HDMI
Brand: Asus
