ASUS VA24DQLB Eye Care monitor features 23.8 inch IPS panel with Full HD (1920 x 1080) resolution, providing 178° wide viewing angle panel and vivid image quality. Up to 75Hz refresh rate with Adaptive-Sync technology to eliminate tracing and ensure crisp and clear video playback. In addition, it also features TÜV Rheinland-certified Flicker-free and Low Blue Light technologies to ensure a comfortable viewing experience.
Viewing perfection
Expanded vision with 178° IPS wide-viewing-angle panel, giving consistent, accurate color at any viewing angle to minimize the color shift a promise for a better viewing experience. -
Frameless design
Makes it perfect for almost-seamless multi-display setups that give you an even greater degree of immersion. -
Super smooth visuals with Adaptive-Sync
Adaptive-Sync technology to eliminate screen tearing and choppy frame rates to give you seamless visuals and smooth gameplay. This gives you the upper hand in first person shooters, racing, real-time strategy and sports titles. -
ASUS-exclusive GamePlus Technology
When it comes to design, ASUS always has customers in mind - ASUS exclusive GamePlus hotkey with Crosshair, Timer and FPS counter functions to give you in-game enhancements that help you get more out of your game. This function is co-developed with input from pro gamers, allowing them to practice and improve their gaming skills. -
ASUS-exclusive Splendid Technologies
Splendid Video Intelligence Technology that optimizes videos and images by enhancing color brightness, contrast, and sharpness. Splendid features two new modes - Reading and Darkroom - in addition to the Scenery, Standard, Theater, sRGB, and Night View modes. Low-blue Light and Flicker-free technologies also reduce the strain on your eyes after long periods of use. -
ASUS Blue Light Filter
The TÜV Rheinland-certified ASUS Blue Light Filter protects you from harmful blue light, and you can easily access its four different filter settings via a hotkey. ASUS displays has undergone stringent performance tests and has been certified by TÜV Rheinland laboratories to be flicker-free and to emit low blue light levels. -
Flicker-free Technology
It's time to say goodbye to those tired, strained eyes. ASUS displays features TÜV Rheinland-certified ASUS Flicker-Free technology to reduce flicker for a comfortable viewing experience. This technology helps minimize instances of eyestrain and other damaging ailments, especially when you spend long, countless hours in front of a display watching favorite videos. -
Space saving and cable management
With MiniPC kit for those who need to mount mini PCs on the monitor, to make the desktop clutter-free and space saving. Cable management design can help you to organize various cables to keep your desk area tidy. -
Ergonomic design
A comfortable viewing position is always within reach thanks to ergonomically-designed stand with tilt, swivel, pivot, and height adjustments. Its onscreen menu even rotates automatically to display correctly when using the monitor in portrait orientation - handy when working with websites or longer documents.
- ASUS VA24DQLB - LED monitor - Full HD (1080p) - 23.8"
- LED-backlit LCD monitor - 23.8"
- Energy Class
- Class F
- Power Consumption (On mode)
- 21.7 W
- USB 2.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Pixel Pitch
- 0.2745 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 100000000:1 (dynamic)
- Colour Support
- 16.7 million colours (8-bit)
- Input Connectors
- HDMI, VGA, DisplayPort
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 54 cm x 21.1 cm x 48 cm
- 5.5 kg
- Environmental Standards
- TCO Certified Displays 8, ENERGY STAR Qualified
- UL, TUV GS, VCCI, BSMI, WHQL, CB, CCC, TUV Ergo, FCC, RoHS, ISO 9241-307, KCC, WEEE, PSE Mark, E-Standby, CEC, KC, RCM, TUV Rheinland Low Blue Light Certification, CU, TUV Rheinland Flicker Free Certification
- Display Type
- Energy Class
- Class F
- Diagonal Size
- 23.8"
- Built-in Devices
- USB 2.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.2745 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Vertical Refresh Rate
- 48 - 75 Hz
- Horizontal Refresh Rate
- 24 - 85 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Anti-glare
- Backlight Technology
- LED backlight
- HDCP, Skin-Tone Selection, Trace Free Technology, ASUS Smart Contrast Ratio (ASCR), ASUS Splendid Video Preset Mode, ASUS QuickFit Virtual Scale, ASUS GamePlus, ASUS VividPixel Technology, Low Blue Light Mode, Flicker Free technology, ASUS EyeCare Technology, Adaptive-Sync technology, Colour Temperature Selection
- Black
- 54 cm x 21.1 cm x 48 cm - with stand
- 5.5 kg
- VGA , HDMI , DisplayPort , 2 x USB 2.0 downstream (Type A) , USB 2.0 upstream (Type B)
Mechanical
- Tilt Angle
- -5/+35
- Swivel Angle
- 180
- Rotation Angle
- 180
- Height Adjustment
- 130 mm
- VESA Mounting Interface
- 100 x 100 mm
- Security Slot Type
- Kensington security slot
- Input Voltage
- 21.7 W
- Power Consumption SDR (On mode)
- 21.7 kWh/1000h
- Power Consumption (Typical)
- 16.7 Watt
- 0.3 Watt
- Dimensions & Weight Details
- With stand - width: 54 cm - depth: 21.1 cm - height: 48 cm - weight: 5.5 kg , Without stand - width: 54 cm - depth: 5.5 cm - height: 32.5 cm - weight: 3.3 kg
- Shipping Width
- 65.2 cm
- Shipping Depth
- 20.2 cm
- Shipping Height
- 45 cm
- Shipping Weight
- 7.8 kg
- TCO Certified
- ENERGY STAR Certified
