Asus VA24DCP Eye Care Monitor – 23.8" Full HD, IPS 1920 x1080
Quicklinx: GNZSWS00 Mfr#: VA24DCP
ASUS VA24DCP Eye Care Monitor features IPS panel with Full HD (1920 x 1080) resolution, providing 178° wide viewing angle panel and vivid image quality. USB-C port supports video transmission in DisplayPort signal and 65W power output for your devices via only one USB-C cable. Up to 75Hz refresh rate with Adaptive-Sync/FreeSync technology to eliminate tracing and ensure crisp and clear video playback. In addition, it also features TÜV Rheinland-certified Flicker-free and Low Blue Light technologies to ensure a comfortable viewing experience.
  • Viewing perfection
    Expanded vision with 178° IPS wide-viewing-angle panel, giving consistent, accurate color at any viewing angle to minimize the color shift an promise for a better viewing experience.
  • Frameless design
    Makes it perfect for almost-seamless multi-display setups that give you an even greater degree of immersion.
  • USB-C connectivity
    USB-C connectivity capable to provide a variety of devices you can connect. The reversible USB-C connector design makes connecting any device effortless and quick. USB-C supports video transmission in DisplayPort signal and up to 65W power output for your notebook / mobile devices via only one USB-C cable.
  • Super smooth visuals with Adaptive-Sync/FreeSync
    Adaptive-Sync/FreeSync technology to eliminate screen tearing and choppy frame rates to give you seamless visuals and smooth gameplay. This gives you the upper hand in first person shooters, racing, real-time strategy and sports titles.
  • ASUS-exclusive GamePlus technology
    When it comes to design, ASUS always has customers in mind - ASUS exclusive GamePlus hotkey with Crosshair, Timer, FPS counter and Display Alignment functions to give you in-game enhancements that help you get more out of your game. This function is co-developed with input from pro gamers, allowing them to practice and improve their gaming skills.
  • SUS-exclusive Splendid technologies
    Splendid Video Intelligence technology that optimizes videos and images by enhancing color brightness, contrast, and sharpness. Splendid features two modes - Reading and Darkroom - in addition to the Scenery, Standard, Theater, sRGB, and Night View modes. Low-blue Light and Flicker-free technologies also reduce the strain on your eyes after long periods of use.
  • ASUS Blue Light Filter
    The TÜV Rheinland-certified ASUS Blue Light Filter protects you from harmful blue light. It's easy to access, intuitive and flexible with seamless adjustment (0 to maximum) via the OSD menu. ASUS displays has undergone stringent performance tests and has been certified by TÜV Rheinland laboratories, a global provider of technical, safety, and certification services.
  • Flicker-free technology
    It's time to say goodbye to those tired, strained eyes. ASUS displays features TÜV Rheinland-certified ASUS Flicker-Free technology to reduce flicker for a comfortable viewing experience. This technology helps minimize instances of eyestrain and other damaging ailments, especially when you spend long, countless hours in front of a display watching favorite videos.
ASUS VA24DCP - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/426987
Energy Class
Class D
Power Consumption (On mode)
14.1 W
Adaptive-Sync Technology
AMD FreeSync
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080 at 75 Hz
Pixel Pitch
0.2745 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 100000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, USB-C
Display Position Adjustments
Tilt
Screen Coating
Anti-glare
Voltage
AC 100-240 V (50/60 Hz)
53.97 cm x 20.501 cm x 39.041 cm
4 kg
Environmental Standards
TCO Certified Displays 9
TUV Rheinland Low Blue Light Certification, TUV Rheinland Flicker Free Certification, HDCP 1.4
Display Type
Energy Class
Class D
Diagonal Size
24"
Viewable Size
23.8"
AMD FreeSync
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2745 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
48 - 75 Hz
Horizontal Refresh Rate
30 - 85 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
LED backlight
HDCP, frameless, ASUS Splendid Video Intelligence Technology, ASUS Smart Contrast Ratio (ASCR), ASUS QuickFit Virtual Scale, ASUS GamePlus, Low Blue Light Mode, Flicker-Less technology, Adaptive-Sync technology, Colour Temperature Selection, USB-C power delivery up to 65 W, ASUS EyeCare+ Technology
53.97 cm x 20.501 cm x 39.041 cm - with stand
4 kg
Audio
Speakers - stereo
Output Power / Channel
2 watt
USB-C , HDMI , Headphones
Mechanical
Tilt
Tilt Angle
-5/+23
VESA Mounting Interface
100 x 100 mm
1 x HDMI cable , 1 x power cable
Security Slot Type
Kensington security slot
Input Voltage
14.1 W
14.1 kWh/1000h
Power Consumption Stand by
0.5 watt
Power Consumption (Off Mode)
0.3 watt
Dimensions & Weight Details
With stand - width: 53.97 cm - depth: 20.501 cm - height: 39.041 cm - weight: 4 kg , Without stand - width: 53.97 cm - depth: 5.26 cm - height: 32.355 cm - weight: 3.7 kg
Shipping Width
61.2 cm
Shipping Depth
15.2 cm
Shipping Height
45.5 cm
Shipping Weight
5.5 kg
Sustainability Information
TCO Certified
