Asus USB-N53 Dual Band N USB Network Adapter
Quicklinx: 7VM5WS00 Mfr#: USB-N53
Wired / Wireless: Wireless
Protocol: IEEE 802.11a, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Form Factor: External
Compatibility: PC
Type: Network adapter
  • IEEE 802.11n
£20.09 ex VAT
£24.10 inc VAT
The ASUS USB-N53 is a dual-band USB adapter that provides flexible dual-band connection for lag-free streaming and high performance networking. It also has a superior antenna design for extensive wireless coverage.
With the bundled USB cable, you can flexibly adjust the antenna to receive the strongest signal. A friendly user interface utility allows you to install and use the application easily, making the USB-N53 a fantastic USB Wi-Fi Adapter both at home and on the road.
Flexible Dual-band connection for lag-free streaming and high performance networking.
Power signal transmission for extensive wireless coverage.
Contains a USB cable that allows you to adjust the adapter for enhanced reception.
  • Flexible dual-band connection
    Wireless-N dual-band Internet connection is designed for lag-free, high definition streaming.
  • Power signal transmission
    Superior antenna design is designed for extensive wireless coverage- an increase of more than 150%.
  • Enhanced reception
    With the USB cable accessory, you can flexibly adjust the antenna to receive the strongest signal.
Header / Product Line
ASUS
Header / Model
USB-N53
Network adapter
Wired / Wireless
Wireless
External
Speed
300 Mbps
Compatibility
PC
System Requirements / OS Required
Microsoft Windows XP 64-bit Edition
Protocol
IEEE 802.11n
Hi-Speed USB
Header / Manufacturer
ASUSTeK COMPUTER
Dimensions & Weight / Width
9.6 cm
Dimensions & Weight / Weight
20 g
Dimensions & Weight / Depth
2.6 cm
Dimensions & Weight / Height
1.2 cm
Header / Packaged Quantity
1
Protocol: IEEE 802.11b
Protocol: IEEE 802.11g
Protocol: IEEE 802.11n
Compatibility: PC
Brand: Asus
Price Range Ex VAT: 0 - 50
