Asus USB-AC56 Dual-band Wireless-AC1200 USB 3.0 Wi-Fi Adapter
Quicklinx: 95GBWS00 Mfr#: USB-AC56
Wired / Wireless: Wireless
Protocol: IEEE 802.11a, IEEE 802.11ac, IEEE 802.11b, IEEE 802.11g + 1 more
Form Factor: External
Compatibility: Mac, PC
Type: Network adapter
  • Windows 8 (32/64 bits)
  • IEEE 802.11n
18 in stock
£44.28 ex VAT
£53.13 inc VAT
The ASUS USB-AC56 is a dual-band 802.11ac Wi-Fi adapter with a USB 3.0 connection that brings high-performance wireless networking support to desktop and notebook PCs. The USB-AC56 features a USB 3.0 connection with support for wireless data rates up to 300 Mbit/s at 2.4 GHz and 867 Mbit/s at 5 GHz with compatible routers. Suitable for use with both desktop and notebook PCs, the USB-AC56 features a dual internal antenna design for great wireless network coverage with minimal desktop clutter and a removable high-gain external antenna that boosts reception still further in weak Wi-Fi signal areas.
USB-AC56
Next gen 802.11ac wireless, up to 3X faster than 2x2 wireless N adapters
The fastest Wi-Fi ever becomes more accessible via USB, going up to 867 Mbps on the clear 5 GHz band. Using 802.11ac wireless, faster connectivity and enjoyment come to all your devices. Compared with current 802.11n, the USB-AC56 delivers up to 867 Mbps at 5 GHz, which is 3X faster than 802.11n!
Maximum flexibility for maximum wireless coverage
The USB-AC56 wireless-AC1200 USB adapter can cover larger homes and offices, including multi-floor locations. Its detachable high-gain external antenna and strong dual internal antennas provide ample transmission power for bigger areas. The detachable antenna can be removed to reduce power draw and emissions should medium-range coverage be sufficient. It can also be upgraded with a more powerful antenna if needed.
Intelligent signal management for stable wireless connections
ASUS AiRadar intelligently strengthens wireless device connectivity using precise directional signal amplification for extended coverage, increased data throughput speed, and enhanced stability. Because connection strength varies based on your environment, the USB-AC56 Dual-Band Wireless-AC1200 USB wireless adapter uses two internal antennas and an external high gain antenna and high-powered beam packing to detect wireless router locations to shape transmissions so they're optimized for the fastest, most stable connection strength.
USB 3.0 for full 802.11ac performance
USB 3.0 allows the USB-AC56 Dual-Band Wireless-AC1200 USB wireless adapter to pair with notebooks and desktops using a bandwidth up to ten times that of USB 2.0. It means the full advantage of 802.11ac networking is realized, as the adapter has enough throughput overhead to support much faster network speeds.
The USB-AC56 also includes a desktop cradle with a three-foot cable for more flexible positioning in troublesome Wi-Fi reception areas.
  • Next gen 802.11ac wireless, up to 3x faster than 2 x 2 wireless N adapters
    The fastest Wi-Fi ever becomes more accessible via USB, going up to 867 Mbps on the clear 5 GHz band. Using 802.11ac wireless, faster connectivity and enjoyment come to all your devices. Compared with current 802.11n, the USB-AC56 delivers up to 867 Mbps at 5 GHz, which is 3x faster than 802.11n!
  • Maximum flexibility for maximum wireless coverage
  • Intelligent signal management for stable wireless connections
    ASUS AiRadar intelligently strengthens wireless device connectivity using precise directional signal amplification for extended coverage, increased data throughput speed, and enhanced stability. Because connection strength varies based on your environment, the USB-AC56 dual-band wireless-AC1200 USB wireless adapter uses two internal antennas and an external high gain antenna and high-powered beam packing to detect wireless router locations to shape transmissions so they're optimized for the fastest, most stable connection strength.
  • USB 3.0 for full 802.11ac performance
    USB 3.0 allows the USB-AC56 dual-band wireless-AC1200 USB wireless adapter to pair with notebooks and desktops using a bandwidth up to ten times that of USB 2.0. It means the full advantage of 802.11ac networking is realized, as the adapter has enough throughputs overhead to support much faster network speeds.
ASUS USB-AC56 - network adapter
Network adapter
External
Interface (Bus) Type
SuperSpeed USB 3.0
11.5 cm x 2.8 cm x 1.9 cm
50 g
802.11ac
Data Transfer Rate
1200 Mbps
Frequency Band
2.4 GHz, 5 GHz
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Microsoft Windows 2000, Apple MacOS X 10.6, Apple MacOS X 10.5, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Apple MacOS X Lion 10.7, Apple OS X 10.8 Mountain Lion, Windows 8 (32/64 bits)
Network adapter
External
SuperSpeed USB 3.0
Wireless
Data Transfer Rate
1200 Mbps
Frequency Band
2.4 GHz, 5 GHz
Wi-Fi Protected Setup (WPS), ASUS AiRadar
Aerial
Antenna
External detachable and internal
Antenna Qty
3
USB cradle
1 x USB extension cable
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA-PSK, WPA2-PSK
Software Included
Drivers & Utilities
11.5 cm
2.8 cm
1.9 cm
50 g
Limited warranty - parts and labour - 2 years
95GB C2G 5m USB 2.0 A/B Cable - Black In Stock £5.02
95GB C2G 12m USB 2.0 A/A Active Extension Cable In Stock £16.53
Protocol: IEEE 802.11ac
Protocol: IEEE 802.11b
Protocol: IEEE 802.11g
Protocol: IEEE 802.11n
Compatibility: Mac
Compatibility: PC
Brand: Asus
Price Range Ex VAT: 0 - 50
