Asus TUF-GTX1650-O4GD6-Gaming - OC Edition 4GB PCIe 3.0x16
Quicklinx: GD8FWS00 Mfr#: TUF-GTX1650-O4GD6-GAMING
The TUF Gaming GeForce GTX 1650 stacks an arsenal of weapons that bring reliable 3D horsepower to the TUF Gaming ecosystem. Each card is built using Auto-Extreme manufacturing, protected by a rigid backplate that prevents PCB flex and features fans with space-grade lubricant that are sealed to IP5X standards. If you're looking for the tank of graphics cards, lock and load your rig with the TUF.
  • Built TUF
  • IP5X dust resistance
    Dust is enemy number one for fans. It's easy to clean the blades, but taking the fan apart to remove dust that has made its way inside is not a simple task. The IP5X certification means the housing is safe from nasty particulates, so you'll never need that deep clean.
  • Precision-automated manufacturing
    Auto-Extreme technology is an automated manufacturing process that sets standards in the industry by allowing all soldering to be completed in a single pass. This reduces thermal strain on components and avoids the use of harsh cleaning chemicals, resulting in less environmental impact, lower manufacturing power consumption, and a more reliable product overall.
  • Monitor, tweak, and tune
    The ASUS GPU Tweak II utility takes graphics card tuning to the next level. It allows you to tweak critical parameters including GPU core clocks, memory frequency, and voltage settings, with the option to monitor everything in real time through a customizable on-screen display. Advanced fan control is also included along with many more features to help you get the most out of your graphics card.
  • Turing shaders
    Featuring concurrent execution of floating point and integer operations, adaptive shading technology, and a unified memory architecture with twice the cache of its predecessor, NVIDIA Turing shaders enable awesome performance increases in modern games.
  • NVIDIA Ansel
    This powerful tool lets you take professional-grade screenshots of your games. Now, you can record and share your most brilliant gaming experiences with super-resolution, 360-degree, HDR, and stereoscopic capture modes.
  • More creating less waiting
    Dedicated GPU power accelerates the creative apps you use every day. Combined with NVIDIA Creator Ready Drivers, you'll get additional performance and reliability to supercharge your creativity.
ASUS TUF-GTX1650-O4GD6-GAMING - OC Edition - graphics card - GF GTX 1650 - 4 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
NVIDIA GeForce GTX 1650 - up to
4 GB GDDR6
Boost Clock
1680 MHz
CUDA Cores
896
Memory Interface
128-bit
Max Resolution
7680 x 4320
Max Monitors Supported
3
Interfaces Details
DisplayPort , HDMI , DVI-D
API Supported
OpenGL 4.6
4.56 cm x 20.45 cm x 12.49 cm
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
Boost Clock
1680 MHz
CUDA Cores
896
Max Resolution
7680 x 4320
3
Interfaces Details
API Supported
OpenGL 4.6
NVIDIA G-Sync ready, AUTO-EXTREME technology, NVIDIA Ansel, NVIDIA Turing GPU architecture, 2.3-slot Fan Cooler, HDCP
Size
4 GB
GDDR6 SDRAM
Bus Width
128-bit
Required Power Supply
300 W
IP5X, DisplayPort 1.4, HDCP 2.2
4.56 cm
20.45 cm
12.49 cm
