The TUF Gaming VG27AQA1A is a 27-inch WQHD (2 560 x 1 440) gaming monitor with an overclocking 170 Hz refresh rate and 1 ms (MPRT) response time for extremely immersive gameplay. It features exclusive Extreme Low Motion Blur (ELMB) technology and AMD FreeSync Premium to eliminate ghosting and tearing. In addition, it also features High Dynamic Range technology, supporting the HDR10 for great contrast and lifelike colors.
170 Hz refresh rate (OC) and 1 ms (MPRT) response time
TUF Gaming VG27AQA1A delivers stunning visuals from all angles. With overclock to 170 Hz refresh rate decimates lag and motion blur to give you the upper hand in first person shooters, racers, real-time strategy, and sports titles. This ultrafast refresh rate lets you play at the highest visual settings and lets you react instantly to what's onscreen - so you'll get that first strike in. -
Adaptive-Sync
AMD FreeSync Premium technology supported through DP and HDMI ports providing variable refresh rates for low latency, stuttering-free and tearing-free while gaming. -
High dynamic range
TUF Gaming VG27AQA1A takes advantage of HDR technology to deliver more vivid colors and higher contrast levels compared to traditional monitors. -
ASUS Extreme Low Motion Blur (ELMB) technology provides a 1 ms MPRT response time to eliminate smearing and motion blur. It makes moving objects appear even sharper, so gameplay is more fluid and responsive. -
Variable Overdrive
Integrated ASUS Variable Overdrive technology allows the display to dynamically alter its overdrive setting as frame rates fluctuate, ensuring optimal results for any game. -
Shadow boost
ASUS Shadow Boost technology clarifies dark areas of the game without overexposing brighter areas, improving overall viewing while also making it easier to spot enemies hidden in dark areas of the map. -
GamePlus
The ASUS-exclusive, integrated GamePlus hotkey offers in-game enhancements that help you get more out of your game. This function is co-developed with input from pro gamers, allowing them to practice and improve their gaming skills. -
GameVisual
ASUS GameVisual Technology has seven pre-set display modes to optimize visuals for different types of content. This unique feature can be easily accessed through a hotkey or the on-screen display settings menu. -
Flicker-Free technology
Flicker-Free technology reduces flicker to minimize eyestrain for improved comfort when you're embroiled in long gaming sessions. -
Low Blue Light
ASUS Low Blue Light technology reduces the amount of potentially harmful blue light emitted by the display. Four different filter settings are available to control the amount of blue light reduction. -
Extensive connectivity
A multitude of connectivity options, including two HDMI, plus DisplayPort 1.2, ensures wide compatibility with a variety of input sources. -
Ergonomic design
With an ergonomically-designed stand, it provides tilt so you can easily find your ideal viewing position. The display is also VESA-compatible for wall mounting.
- ASUS TUF Gaming VG27AQA1A - LED monitor - 27" - HDR
- LED-backlit LCD monitor - 27"
- Energy Label QR Code URL
- Https://eprel.ec.europa.eu/qr/1392005
- Energy Class
- Class F
- Adaptive-Sync Technology
- AMD FreeSync Premium
- Panel Type
- VA
- Aspect Ratio
- 16:9
- Native Resolution
- WQHD 2560 x 1440 at 170 Hz
- Pixel Pitch
- 0.231 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 3000:1
- HDR Capable
- HDR10
- Response Time
- 1 ms (MPRT)
- Gaming
- Colour Support
- 16.7 million colours
- Input Connectors
- 2xHDMI, DisplayPort
- Tilt
- Screen Coating
- Anti-glare
- Voltage
- AC 100-240 V (50/60 Hz)
- 61.519 cm x 21.354 cm x 45.486 cm
- 4.65 kg
- TUV Rheinland Flicker Free Certification, HDCP 2.2, TUV Rheinland Low Blue Light (Software Solution)
- Display Type
- Energy Class
- Class F
- Energy Class (HDR)
- Class G
- Diagonal Size
- 27"
- Panel Type
- VA
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.231 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 3000:1
- HDR Format
- HDR10
- Colour Support
- Response Time
- 1 ms (MPRT)
- Vertical Refresh Rate
- 48 - 170 Hz
- Horizontal Refresh Rate
- 30 - 250 kHz
- Gaming
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Anti-glare
- Backlight Technology
- LED backlight
- Trace Free Technology, ASUS GamePlus, Flicker Free technology, ASUS GameVisual Technology, Colour Temperature Selection, GameFast Input Technology, ASUS Extreme Low Motion Blur technology, Low Blue Light technology, 3-sided bezeless, Shadow Boost technology, overclocked 170 Hz, Variable refresh rate (VRR), ASUS Variable Overdrive, ASUS Display Widget Lite
- 61.519 cm x 21.354 cm x 45.486 cm - with stand
- 4.65 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 2 watt
- 2 x HDMI , DisplayPort 1.2 , Headphones
Mechanical
- Tilt
- Tilt Angle
- -5/+20
- VESA Mounting Interface
- 100 x 100 mm
- Security Slot Type
- Kensington security slot
- Input Voltage
- Power Consumption SDR (On mode)
- 24 kWh/1000h
- Power Consumption HDR (On mode)
- 32 kWh/1000h
- Power Consumption (Typical)
- 24 watt
- Power Consumption Stand by
- 0.5 watt
- 0.3 watt
- Dimensions & Weight Details
- Without stand - width: 61.519 cm - depth: 5.05 cm - height: 36.636 cm - weight: 3.85 kg , With stand - width: 61.519 cm - depth: 21.354 cm - height: 45.486 cm - weight: 4.65 kg
- Shipping Width
- 68.9 cm
- Shipping Depth
- 16 cm
- Shipping Height
- 47.5 cm
- Shipping Weight
- 6.75 kg
