Asus TUF Gaming VG24VQE 23.6" Full HD Curved Gaming Monitor
Quicklinx: HD54WS00 Mfr#: VG24VQE
Diagonal Size: 23.6in
Max Resolution: 1920 x 1080
Response Time: 1ms
Speakers: Speaker(s)
Interfaces: DisplayPort, HDMI
£154.44 ex VAT
£185.32 inc VAT
TUF Gaming VG24VQE is a 23.6-inch, Full HD (1920x1080), curved display with an ultrafast 165Hz refresh rate designed for professional gamers and those seeking immersive gameplay. Its impressive curved display features Adaptive-Sync (FreeSync Premium) technology, for extremely fluid gameplay without tearing and stuttering.
  • Immersive curvature
    The 23.6-inch Full HD (1920 x 1080) panel of TUF Gaming VG24VQE delivers stunning visuals from all angles with an 1500R curvature that provides user with immersive and captivating gaming experience. This contributes to greater viewing comfort - even during extended use - and lets you enjoy a wide viewing angle with less distortion and color shift when gaming and watching movies.
  • 165 Hz refresh rate
    TUF Gaming VG24VQE has a super-fast 165 Hz refresh rate, ensuring that even fast-paced games played at the highest visual settings look buttery-smooth and completely lag-free. Get the upper hand in first-person shooters, racing, real-time strategy and sports titles.
  • Extreme Low Motion Blur
    The ASUS-exclusive Extreme Low Motion Blur technology, which achieves 1 ms MPRT to eliminate smearing and motion blur, and makes objects in motion look sharper, so gameplay is more fluid and responsive.
  • Shadow Boost
    ASUS Shadow Boost technology clarifies dark areas of the game without overexposing brighter areas, improving overall viewing while also making it easier to spot enemies hidden in dark areas of the map.
  • Flicker-Free technology
    Flicker-Free technology reduces flicker to minimize eyestrain for improved comfort when you're embroiled in long gaming sessions.
  • Ultra-Low Blue Light technology
    ASUS Ultra-Low Blue Light technology reduces the amount of potentially harmful blue light emitted by the display. Four different filter settings are available to control the amount of blue light reduction.
  • Rich connectivity
    Extensive connectivity options, including, DisplayPort 1.2, HDMI, earphone jack support a wide array of multimedia devices.
ASUS TUF Gaming VG24VQE - LED monitor - curved - Full HD (1080p) - 23.6"
LED-backlit LCD monitor - 23.6"
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/390290
Energy Class
Class E
Curved Screen
Adaptive-Sync Technology
AMD FreeSync Premium
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080 (DisplayPort: 165 Hz, HDMI: 144 Hz)
Pixel Pitch
0.272 mm
Brightness
250 cd/m²
Contrast Ratio
3000:1 / 100000000:1 (dynamic)
Response Time
4 ms (grey-to-grey), 1 ms (MPRT)
Gaming
Colour Support
16.7 million colours (8-bit)
Colour Gamut
72% NTSC
Input Connectors
2xHDMI, DisplayPort
Display Position Adjustments
Tilt
Screen Coating
Anti-glare
Voltage
53.76 cm x 20.59 cm x 40.4 cm
4.8 kg
TUV Rheinland Low Blue Light Certification, TUV Rheinland Flicker Free Certification, DisplayPort 1.2
3-year warranty
Display Type
Energy Class
Class E
Diagonal Size
23.6"
Curved Screen
Yes (1500R)
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.272 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
72% NTSC
Response Time
Vertical Refresh Rate
48 - 165 Hz
Horizontal Refresh Rate
30 - 200 kHz
Gaming
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
LED backlight
OSD Languages
Hungarian, Croatian, Indonesian, Thai, Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Polish, Russian, Spanish, Dutch, Turkish, Romanian, Japanese, Korean, Persian
HDCP, Trace Free Technology, ASUS Smart Contrast Ratio (ASCR), ASUS GamePlus, Flicker Free technology, ASUS GameVisual Technology, Colour Temperature Selection, GameFast Input Technology, ASUS Extreme Low Motion Blur technology, Low Blue Light technology, 3-sided bezeless, Shadow Boost technology, 72% NTSC colour gamut
53.76 cm x 20.59 cm x 40.4 cm - with stand
4.8 kg
Audio
Speakers - stereo
Output Power / Channel
2 Watt
2 x HDMI , DisplayPort , Headphones
Mechanical
Tilt
Tilt Angle
-5/+23
VESA Mounting Interface
100 x 100 mm
Security Slot Type
Kensington security slot
Input Voltage
17.7 kWh/1000h
Power Consumption (Typical)
23.34 Watt
Power Consumption (Off Mode)
0.5 Watt
Dimensions & Weight Details
With stand - width: 53.76 cm - depth: 20.59 cm - height: 40.4 cm - weight: 4.8 kg , Without stand - width: 53.76 cm - depth: 6.99 cm - height: 32 cm - weight: 3.37 kg
Shipping Width
62 cm
Shipping Depth
40.3 cm
Shipping Height
19 cm
Limited warranty - 3 years
Response Time: 1ms
Interfaces: HDMI
Brand: Asus
