ASUS TUF Gaming Radeon RX 7900 XTX 24GB OC Edition Graphics Card
Quicklinx: HX1YWS00 Mfr#: TUF-RX7900XTX-O24G-GAMING
£856.37 ex VAT
£1,027.64 inc VAT
The AMD RDNA 3 architecture elevated by buffed cooling and power delivery to effortlessly churn out frames at 4K resolution and beyond, and backed with an arsenal of rugged reinforcements to cover your six. Lock, load, and dominate with the TUF Gaming Radeon RX 7900 XTX.
  • Axial-tech upgrades
    Bigger and better. Axial-tech fans spin on dual-ball bearings and have been scaled up to more air through the card, setting the stage for lower temperatures, less noise, and higher performance.
  • Well-maintained formation
    The two side fans spin counterclockwise to minimize turbulence and maximize air dispersion through the heatsink. All three fans come to a standstill when GPU temps are below 55 Celsius, letting you play less-demanding games or perform light tasks in relative silence. Fans start up again when temps are over 60 Celsius, referencing a speed curve that balances performance and acoustics for work or play.
  • 3.63-slot design
    A generously sized heatsink efficiently soaks up heat from the AMD Radeon RX 7900 XTX GPU, allowing it to be whisked away by the three Axial-tech fans.
  • Resilient squadron
    A lineup of capacitors rated to last 20000 hours at 105 Celsius brings higher temperature and ripple tolerance to the GPU power rail, arming the card for longterm deployment in challenging conditions.
  • Metal exoskeleton
    A diecast frame, aluminum shroud, and backplate prevent PCB flex and feature large vents to further increase heat dissipation.
  • Lock, load, and let the performance flow
    The Radeon RX 7900 XTX gloriously presented on a backdrop of low noise and rugged durability.
  • Reliability boost
    Auto-Extreme technology is an automated manufacturing process that sets standards in the industry by allowing all soldering to be completed in a single pass. This reduces thermal strain on components and avoids the use of harsh cleaning chemicals, resulting in less environmental impact, lower manufacturing power consumption, and a more reliable product overall.
  • Aura Sync
    Aura-compatible ARGB lighting on the shroud adds a dash of customizable color or functional effects to your build. Pair up with a vast range of compatible system components and coordinate the glow to create a theme that's uniquely you.
ASUS TUF Gaming Radeon RX 7900 XTX 24GB - OC Edition - graphics card - Radeon RX 7900 XTX - 24 GB
Graphics card
Bus Type
PCI Express 4.0
Graphics Engine
24 GB GDDR6
Memory Speed
20 Gbps
Boost Clock
2565 MHz
Stream Processors
6144
Memory Interface
384-bit
Max Resolution
7680 x 4320
Max Monitors Supported
4
Interfaces Details
HDMI ¦ 3 x DisplayPort
API Supported
OpenGL 4.6
7.26 cm x 35.29 cm x 15.82 cm
Graphics card
Bus Type
PCI Express 4.0
Graphics Engine
Boost Clock
2565 MHz
Stream Processors
6144
Max Resolution
7680 x 4320
4
Interfaces Details
API Supported
OpenGL 4.6
Axial-tech Fan Design, Dual ball Bearing Fans, AUTO-EXTREME technology, ARGB Lighting, RDNA 3 Gaming Architecture, Triple Fan Design, Aura Sync, AMD Infinity Cache, AMD Radiance Display Engine, AMD FidelityFX Super Resolution 2 (FSR), HDCP
Size
24 GB
GDDR6 SDRAM
Memory Speed
20 Gbps
Bus Width
384-bit
Required Power Supply
850 W
Additional Requirements
3 x 8 pin PCI Express power connector, 3 adjacent PCI slots
TUF certificate of reliability, graphics card holder, hook-and-loop fastener, collection card
Software Included
ASUS GPU Tweak III, Adobe Creative Cloud (1 month membership)
DisplayPort 2.1, HDCP 2.3
7.26 cm
35.29 cm
15.82 cm
Brand: Asus
Price Range Ex VAT: £750 - £1000
