ASUS TUF Gaming Radeon RX 7900 XT 20GB OC Edition Graphics Card
Quicklinx: HVGNWS00 Mfr#: TUF-RX7900XT-O20G-GAMING
The AMD RDNA 3 Architecture elevated by buffed cooling and power delivery to effortlessly churn out frames at 4K resolution and beyond, and backed with an arsenal of rugged reinforcements to cover your six. Lock, load, and dominate with the TUF Gaming Radeon RX 7900 XT.
  • Axial-tech upgrades
    Bigger and better. Axial-tech fans spin on dual-ball bearings and have been scaled up to propel 14% more air through the card, setting the stage for lower temperatures, less noise, and higher performance.
  • Well-maintained formation
    The two side fans spin counterclockwise to minimize turbulence and maximize air dispersion through the heatsink. All three fans come to a standstill when GPU temps are below 55 Celsius, letting you play less-demanding games or perform light tasks in relative silence. Fans start up again when temps are over 60 Celsius, referencing a speed curve that balances performance and acoustics for work or play.
  • 3.63-slot design
    A generously sized heatsink efficiently soaks up heat from the AMD Radeon RX 7900 XT GPU, allowing it to be whisked away by the three Axial-tech fans.
  • Military-grade 20K capacitors
    A lineup of capacitors rated to last 20,000 hours at 105 Celsius brings higher temperature and ripple tolerance to the GPU power rail, arming the card for long-term deployment in challenging conditions.
  • Metal exoskeleton
    A diecast frame, aluminum shroud, and backplate prevent PCB flex and feature large vents to further increase heat dissipation.
  • Lock, load, and let the performance flow
    The Radeon RX 7900 XT gloriously presented on a backdrop of low noise and rugged durability.
  • Auto-Extreme technology
    Auto-Extreme technology is an automated manufacturing process that sets new standards in the industry by allowing all soldering to be completed in a single pass. This reduces thermal strain on components and avoids the use of harsh cleaning chemicals, resulting in less environmental impact, lower manufacturing power consumption, and a more reliable product overall.
ASUS TUF Gaming Radeon RX 7900 XT 20GB - OC Edition - graphics card - Radeon RX 7900 XT - 20 GB
Graphics card
Bus Type
PCI Express 4.0
Graphics Engine
AMD Radeon RX 7900 XT - up to
20 GB GDDR6
Memory Speed
20 Gbps
Boost Clock
2500 MHz
Stream Processors
5376
Memory Interface
320-bit
Max Resolution
7680 x 4320
Max Monitors Supported
4
Interfaces Details
HDMI , 3 x DisplayPort
API Supported
OpenGL 4.6
7.26 cm x 35.29 cm x 15.82 cm
Graphics card
Bus Type
PCI Express 4.0
Graphics Engine
Boost Clock
2500 MHz
Stream Processors
5376
Max Resolution
7680 x 4320
4
Interfaces Details
API Supported
OpenGL 4.6
Dual ball Bearing Fans, Triple Fan Design, AUTO-EXTREME technology, Axial-tech Fan Design, Aura Sync, AMD Infinity Cache, RDNA 3 Gaming Architecture, AMD FidelityFX Super Resolution 2 (FSR), AMD Radiance Display Engine, ARGB Lighting, HDCP
Size
20 GB
GDDR6 SDRAM
Memory Speed
20 Gbps
Bus Width
320-bit
Required Power Supply
750 W
Additional Requirements
3 x 8 pin PCI Express power connector, 3 adjacent PCI slots
Collection card, graphics card holder, hook-and-loop fastener, TUF certificate of reliability
Software Included
ASUS GPU Tweak III, Adobe Creative Cloud (1 month membership, limitations apply)
HDCP 2.3, DisplayPort 2.1
7.26 cm
35.29 cm
15.82 cm
