Asus TUF Gaming Radeon RX 7600 XT 16GB OC Edition Graphics Card
Quicklinx: HVGPWS00 Mfr#: TUF-RX7600XT-O16G-GAMING
The all-new ASUS TUF Gaming Radeon™ RX 7600 XT OC has arrived. Take your next step into AAA gaming with all new features such as the new AMD RDNA™ 3 graphics architecture, paired with ASUS' cooling technologies such as our Axial-tech fan design, Dual ball fan bearings, and GPU Tweak III for performance tuning. Play for victory with the ASUS TUF Gaming Radeon™ RX 7600 XT OC.
  • Enhanced cooling
    The TUF Gaming Radeon RX 7600 XT 16GB features a triple fan design, axial-tech fan design, and dual ball bearing fans, ensuring superior cooling performance for sustained gaming sessions. The metal exoskeleton enhances durability, while the ARGB lighting adds a personalized touch to your gaming setup.
  • Immersive gaming experience
    With support for AMD FidelityFX Super Resolution 2 (FSR), AMD Noise Suppression, and the AMD Radiance Display Engine, this graphics card delivers an immersive gaming experience. Enjoy enhanced visuals with less noise and more vibrant colors, making every game look its best.
  • High fidelity graphics
    Equipped with a 128-bit memory bus and 16 GB of GDDR6 SDRAM, the card supports high-resolution gaming at speeds of up to 18 Gbps. The boost clock speeds of up to 2830 MHz in OC mode ensure smooth, high-fidelity gaming.
  • Robust connectivity
    Featuring 3 HDMI and 3 DisplayPort outputs, the card supports up to 4 monitors, allowing for a versatile and expansive gaming setup. With HDCP 2.3 compliance, enjoy secure, high-quality streaming and gaming.
  • Durable construction
    The TUF Gaming Radeon RX 7600 XT 16GB is built with military-grade capacitors and an AUTO-EXTREME technology manufacturing process, ensuring reliability and durability for long-term gaming enjoyment.
ASUS TUF Gaming Radeon RX 7600 XT 16GB - OC Edition - graphics card - Radeon RX 7600 XT - 16 GB
Graphics card
Bus Type
PCI Express 4.0
Graphics Engine
AMD Radeon RX 7600 XT
16 GB GDDR6
Memory Speed
18 Gbps
Boost Clock
2810 MHz
Boost Clock (OC)
2830 MHz
Stream Processors
2048
Memory Interface
128-bit
Max Resolution
7680 x 4320
Max Monitors Supported
4
Interfaces Details
HDMI , 3 x DisplayPort
API Supported
OpenGL 4.6
5.92 cm x 30.02 cm x 14.275 cm
Package Type
Box
Graphics card
Bus Type
PCI Express 4.0
Graphics Engine
Boost Clock
2810 MHz
Boost Clock (OC)
2830 MHz
Stream Processors
2048
Max Resolution
7680 x 4320
4
Interfaces Details
API Supported
OpenGL 4.6
2.96-slot Fan Cooler, Triple Fan Design, ARGB Lighting, Axial-tech Fan Design, Dual ball Bearing Fans, AUTO-EXTREME technology, metal exoskeleton, RDNA 3 Gaming Architecture, military grade capacitors, ASUS AURA SYNC support, AMD Radiance Display Engine, AMD Noise Suppression, AMD FidelityFX Super Resolution 2 (FSR), HDCP
Size
16 GB
GDDR6 SDRAM
Memory Speed
18 Gbps
Bus Width
128-bit
Required Power Supply
600 W
Additional Requirements
2 x 8 pin PCI Express power connector
TUF certificate of reliability, graphics card holder, hook-and-loop fastener, collection card, thank you card
Software Included
ASUS GPU Tweak III, AMD Radeon Software Adrenalin Edition, Adobe Creative Cloud (1 month membership, limitations apply), ASUS Quantumcloud
HDCP 2.3
5.92 cm
30.02 cm
14.275 cm
Package Details
Box
