Asus TUF Gaming K1 Keyboard
Quicklinx: GRY7WS00 Mfr#: 90MP01X0-BKEA00
Type: Keyboard
More than 50 In Stock
£45.83 ex VAT
£54.99 inc VAT
ASUS TUF Gaming K1 is a gaming keyboard that delivers uncompromising performance and exceptional durability. It's equipped with switches that deliver silent tactility with every press. These are housed in a 300 ml spill-resistant frame that's fortified by a specialized coating and validated for tough duty. K1 also features customizable RGB illumination and side-mounted light bars for personalized style, a dedicated volume knob for fast, intuitive control and a detachable ergonomic wrist rest for extended comfort.
  • Gaming grade performance
    TUF Gaming K1's delivers a superb tactile response with a cushioned action that's both quiet and comfortable. It's also engineered with 19-key-rollover (NKRO) technology, ensuring remarkable precision and no missed key presses.
  • Dynamic RGB and lighting bar
    TUF Gaming K1 features five individual lighting zones, and sports striking RGB bars on both sides. Each zone is individually customizable from the whole color spectrum, allowing you to illuminate your rig in your image. The ASUS Armoury Crate app provides next-generation RGB control that synchronizes lighting and game profiles with your content.
  • Dedicated volume knob
    With a dedicated volume knob at the top-right, TUF Gaming K1 makes it quick and easy to control your game audio on the fly. You can reach and twist intuitively, keeping your eyes firmly on the action.
  • Ergonomic wrist rest and adjustable legs
    With a detachable wrist rest and adjustable legs that provide two height positions, TUF Gaming K1 is ergonomically designed for optimal comfort.
  • Specialized coating with spill-resistance
    Inside and out, TUF Gaming K1 is built to provide years of service on the frontline. Its outer shell features a specialized coating that's fortified to withstand a battery of more than 10 stringent abrasion, friction, and perspiration tests. And spill-resistance up to 300ml ensures that accidents with cans or cups won't kill the action.
  • Programmable with onboard memory
    TUF Gaming K1 features eight programmable keys with on-the-fly macro-recording support, making it easy to configure your keyboard for personalized play. And three customizable plus one default onboard memory lets you take your keyboard on the road and have your settings available wherever you go.
ASUS TUF Gaming K1 - keyboard - UK - black Input Device
Keyboard
Backlit
5 zone RGB
USB
Wired
Localization and Layout
Hot Keys Function
Volume, mute, macro record button, play/pause, stop, skip backward, skip forward
Protection
Spill-resistant
Numeric Keypad
Gaming
45.1 cm x 15.5 cm x 3.6 cm
810 g
Keyboard
Backlit
5 zone RGB
USB
Hot Keys Function
Keyboard Technology
Tactile
Anti-ghosting
Simultaneous Key Press Quantity
19
Gaming
Adjustable Height
Palm Rest
Protection
Spill-resistant
Numeric keypad
45.1 cm
15.5 cm
3.6 cm
810 g
USB 2.0
Cable Length
1.8 m
Included Software
Armoury Crate
Windows 10, Windows 11
Type: Keyboard
Brand: Asus
