Get game-changing performance with the GeForce RTX™ 5070 Ti, powered by NVIDIA Blackwell. Game at high frame rates with DLSS 4, supercharge your creativity with NVIDIA Studio, and enable new experiences with the power of AI.
NVIDIA DLSS 4 - Supreme Speed. Superior Visuals. Powered by AI
DLSS is a revolutionary suite of neural rendering technologies that uses AI to boost FPS, reduce latency, and improve image quality. ?The latest breakthrough, DLSS 4, brings new Multi Frame Generation and enhanced Ray Reconstruction and Super Resolution, powered by GeForce RTX™ 50 Series GPUs and fifth-generation Tensor Cores. DLSS on GeForce RTX is the best way to play, backed by an NVIDIA AI supercomputer in the cloud constantly improving your PC’s gaming capabilities.
Full Ray Tracing with Neural Rendering - Game-Changing Realism
The NVIDIA Blackwell architecture unlocks the game-changing realism of full ray tracing. Experience cinematic quality visuals at unprecedented speed powered by GeForce RTX 50 Series with fourth-gen RT Cores and breakthrough neural rendering technologies accelerated with fifth-gen Tensor Cores.
NVIDIA Reflex 2 - Compete at Warp Speed
Reflex technologies optimize the graphics pipeline for ultimate responsiveness, providing faster target acquisition, quicker reaction times, and improved aim precision in competitive games. Reflex 2 introduces Frame Warp (coming soon!), which further reduces latency based on the game’s latest mouse input.
RTX AI PCs - NVIDIA Powers the World’s AI. And Yours
Upgrade to advanced AI with NVIDIA GeForce RTX™ GPUs and accelerate your gaming, creating, productivity, and development. Thanks to built-in AI processors, you get world-leading AI technology powering your Windows PC.
NVIDIA Studio - Your Creative AI-dvantage
NVIDIA Studio is your creative advantage. GeForce RTX 50 Series GPUs unlock transformative performance in video editing, 3D rendering, and graphic design. Experience RTX accelerations in top creative apps, world-class NVIDIA Studio drivers engineered and continually updated to provide maximum stability, and a suite of exclusive tools that harness the power of RTX for AI-assisted creative workflows.
Enhanced cooling technology
Vapor chamber cooling technology and efficient axial-tech fan design ensure your card stays cool and performs consistently during intense gaming sessions. -
High-performance specifications
With 8960 CUDA Cores and a boost clock speed of up to 2527 MHz in OC mode, this graphics card delivers remarkable gaming performance and speed. -
Flexible connectivity options
Equipped with multiple output ports including HDMI and DisplayPort, this graphics card allows for setups to maximize your gaming experience. -
Reliable dual BIOS feature
The dual BIOS feature provides gamers with the ability to switch between performance modes, enhancing compatibility and overall stability. -
Future-ready capabilities
Support for NVIDIA Avatar Cloud Engine (ACE) and compatibility with the latest gaming technology ensures that this graphics card is well-prepared for upcoming titles.
- ASUS TUF Gaming GeForce RTX 5070 Ti 16GB - OC Edition - graphics card - GeForce RTX 5070 Ti - 16 GB - grey
- Graphics card
- Bus Type
- PCI Express 5.0
- Graphics Engine
- NVIDIA GeForce RTX 5070 Ti - up to 1484 TOPS
- Memory
- 16 GB GDDR7
- Memory Speed
- 28 Gbps
- Boost Clock
- 2588 MHz
- Boost Clock (OC)
- 2610 MHz
- CUDA Cores
- 8960
- Memory Interface
- 256-bit
- Max Resolution
- 7680 x 4320
- Max Monitors Supported
- 4
- Interfaces Details
- 3 x DisplayPort ¦ HDMI
- API Supported
- DirectX 12 Ultimate, OpenGL 4.6
- 6.25 cm x 32.9 cm x 14 cm
- Enclosure Colour
- Grey
- Graphics card
- Bus Type
- PCI Express 5.0
- Graphics Engine
- Boost Clock
- 2588 MHz
- Boost Clock (OC)
- 2610 MHz
- CUDA Cores
- 8960
- VR Ready
- Max Resolution
- 7680 x 4320
- 4
- API Supported
- NVIDIA Blackwell GPU architecture, NVIDIA DLSS 4, phase-change thermal pad, ASUS GPU Guard, AUTO-EXTREME technology, 3.125-slot Fan Cooler, Axial-tech Fan Design, NVIDIA Ansel, NVIDIA G-Sync ready, Triple Fan Design, NVIDIA Avatar Cloud Engine (ACE), 5th gen Tensor Cores, 4th gen Ray Tracing Cores, MaxContact technology, Vapor chamber cooling technology, ARGB Lighting, ASUS AURA SYNC support, Dual ball Bearing Fans, NVIDIA Reflex 2, HDCP
- Size
- 16 GB
- Technology
- GDDR7 SDRAM
- Memory Speed
- 28 Gbps
- Bus Width
- 256-bit
Performance
- NPU Performance Up To (TOPS)
- 1484 TOPS
- Required Power Supply
- 850 W
- Additional Requirements
- 16 pin PCI Express power connector
- Software Included
- ASUS GPU Tweak III, MuseTree
- HDCP 2.3, DisplayPort 2.1b
- 6.25 cm
- 32.9 cm
- 14 cm
- 1.62 kg
- Shipping Width
- 42 cm
- Shipping Depth
- 22.6 cm
- Shipping Height
- 8.7 cm
- Shipping Weight
- 2.41 kg
- Enclosure Colour
- Grey
