ASUS TUF Gaming GeForce RTX 4080 SUPER 16GB OC Edition Graphics Card
Quicklinx: HX0XWS00 Mfr#: TUF-RTX4080S-O16G-GAMING
The ASUS TUF Gaming GeForce RTX 4080 SUPER 16GB graphics card is designed to deliver an exceptional gaming experience. With its powerful NVIDIA GeForce RTX 4080 SUPER graphics processor and 16 GB of GDDR6X SDRAM, it offers high performance for gaming enthusiasts. The card's cooling system, featuring a triple fan design and Axial-tech Fan Design, ensures optimal temperature control during intense gaming sessions.
Moreover, the inclusion of 3rd gen Ray Tracing Cores and 4th gen Tensor Cores allows for realistic and immersive graphics, making every game come to life. The ability to support up to 4 monitors with a maximum external resolution of 7680 x 4320 enables gamers to enjoy high-definition visuals across multiple displays.
Additionally, the TUF Gaming GeForce RTX 4080 SUPER 16GB is built to last, with a robust metal exoskeleton and military-grade capacitors that provide durability and reliability. Customizable ARGB lighting and ASUS AURA SYNC support allow users to personalize their gaming setup, creating an immersive atmosphere. With these features and more, the ASUS TUF Gaming GeForce RTX 4080 SUPER 16GB graphics card is an excellent choice for gamers looking to elevate their gaming experience.
  • Enhanced cooling
    The TUF Gaming GeForce RTX 4080 SUPER 16GB features a triple fan design, Axial-tech Fan Design, and Dual ball Bearing Fans, ensuring superior cooling performance for sustained gaming sessions.
  • Immersive graphics
    Equipped with 3rd gen Ray Tracing Cores and 4th gen Tensor Cores, this graphics card delivers highly realistic graphics and smooth, efficient performance, enhancing your gaming experience.
  • Vibrant visuals
    With support for a maximum external resolution of 7680 x 4320 and the ability to support up to 4 monitors, gamers can enjoy immersive, high-definition visuals across multiple displays.
  • Robust build
    The card's metal exoskeleton and military-grade capacitors provide a durable construction that's built to withstand intensive gaming use, ensuring long-term reliability.
  • Customizable lighting
    Featuring ARGB lighting and ASUS AURA SYNC support, users can customize the lighting to match their gaming setup, creating a personalized gaming atmosphere.
ASUS TUF Gaming GeForce RTX 4080 SUPER 16GB - OC Edition - graphics card - NVIDIA GeForce RTX 4080 SUPER - 16 GB
Graphics card
Bus Type
PCI Express 4.0
Graphics Engine
16 GB GDDR6X
Memory Speed
23 Gbps
Boost Clock
2610 MHz
Boost Clock (OC)
2640 MHz
CUDA Cores
10240
Memory Interface
256-bit
Max Resolution
7680 x 4320
Max Monitors Supported
4
Interfaces Details
3 x DisplayPort (version 1.4a) , 2 x HDMI
API Supported
OpenGL 4.6
7.26 cm x 34.82 cm x 15 cm
Graphics card
Bus Type
PCI Express 4.0
Graphics Engine
Boost Clock
2610 MHz
Boost Clock (OC)
2640 MHz
CUDA Cores
10240
Max Resolution
7680 x 4320
4
Interfaces Details
API Supported
OpenGL 4.6
3rd gen Ray Tracing Cores, 4th gen Tensor Cores, AUTO-EXTREME technology, Axial-tech Fan Design, Dual ball Bearing Fans, metal exoskeleton, military grade capacitors, NVIDIA Ada Lovelace GPU technology, NVIDIA DLSS 3, Triple Fan Design, 3.65-slot Fan Cooler, ASUS AURA SYNC support, ARGB Lighting, HDCP
Size
16 GB
GDDR6X SDRAM
Memory Speed
23 Gbps
Bus Width
256-bit
Required Power Supply
850 W
Additional Requirements
16 pin PCI Express power connector
Graphics card support bracket, TUF Gaming graphics card holder, TUF hook-and-loop fastener, 16-pin to 3x 8-pin cable adapter, collection card, thank you card, TUF Gaming Certificate
Software Included
ASUS GPU Tweak III, NVIDIA Studio drivers
HDCP 2.3, DisplayPort 1.4a
7.26 cm
34.82 cm
15 cm
