ASUS TUF Gaming GeForce RTX 4070 Ti SUPER 16GB OC Edition Graphics Card
Quicklinx: HX10WS00 Mfr#: TUF-RTX4070TIS-O16G-GAMING
The ASUS TUF Gaming GeForce RTX 4070 Ti SUPER 16GB video card redefines gaming and creative performance. It's equipped with a high-capacity 16 GB GDDR6X memory and a wide 256-bit bus width, delivering fast data transfer speeds of 21 Gbps. This powerhouse supports OpenGL 4.6 and comes with 8448 CUDA Cores, making it capable of running high-resolution games and demanding applications smoothly.
The card's innovative cooling system, featuring Axial-tech Fan Design, Dual ball Bearing Fans, and a triple fan setup, ensures it stays cool under pressure, enhancing reliability and performance longevity. With support for up to 4 monitors and a maximum resolution of 7680 x 4320, it offers an expansive and immersive visual experience. The inclusion of AUTO-EXTREME technology, a metal exoskeleton, and military-grade capacitors underscores its durability, making it a wise choice for gamers and professionals seeking high performance and reliability.
  • Enhanced cooling
    The TUF Gaming GeForce RTX 4070 Ti SUPER 16GB features an advanced cooling system with Axial-tech Fan Design, Dual ball Bearing Fans, and a triple fan Design, ensuring optimal performance even under heavy loads.
  • High performance
    Equipped with 8448 CUDA Cores and a robust 16 GB GDDR6X SDRAM, this video card delivers exceptional graphics processing power, making it suitable for high-resolution gaming and creative work.
  • Next-generation gaming
    With 3rd gen Ray Tracing Cores and 4th gen Tensor Cores, the card offers an immersive gaming experience, supported by NVIDIA DLSS 3 and NVIDIA Ada Lovelace GPU technology for realism and efficiency.
  • High fidelity visuals
    Supporting a maximum external resolution of 7680 x 4320 and capable of connecting to up to 4 monitors, this graphics card provides stunning, high-fidelity visuals for an immersive viewing experience.
  • Durable build
    The card's metal exoskeleton and military grade capacitors ensure a durable and reliable performance, making it a solid investment for gamers and professionals alike.
ASUS TUF Gaming GeForce RTX 4070 Ti SUPER 16GB - OC Edition - graphics card - GeForce RTX 4070 Ti Super - 16 GB
Graphics card
Bus Type
PCI Express 4.0
Graphics Engine
NVIDIA GeForce RTX 4070 Ti SUPER
16 GB GDDR6X
Memory Speed
21 Gbps
Boost Clock
2640 MHz
Boost Clock (OC)
2670 MHz
CUDA Cores
8448
Memory Interface
256-bit
Max Resolution
7680 x 4320
Max Monitors Supported
4
Interfaces Details
2 x HDMI , 3 x DisplayPort (version 1.4a)
API Supported
OpenGL 4.6
6.5 cm x 30.5 cm x 13.8 cm
Graphics card
Bus Type
PCI Express 4.0
Graphics Engine
Boost Clock
2640 MHz
Boost Clock (OC)
2670 MHz
CUDA Cores
8448
Max Resolution
7680 x 4320
4
Interfaces Details
API Supported
OpenGL 4.6
Triple Fan Design, 3.25-slot Fan Cooler, 3rd gen Ray Tracing Cores, 4th gen Tensor Cores, Axial-tech Fan Design, NVIDIA DLSS 3, AUTO-EXTREME technology, NVIDIA Ada Lovelace GPU technology, Dual ball Bearing Fans, metal exoskeleton, military grade capacitors, ARGB SYNC, HDCP
Size
16 GB
GDDR6X SDRAM
Memory Speed
21 Gbps
Bus Width
256-bit
Required Power Supply
750 W
Additional Requirements
16 pin PCI Express power connector
Graphics card support bracket, collection card, hook-and-loop fastener, 16-pin to 2x 8-pin cable adapter, thank you card, TUF Gaming Certificate
Software Included
ASUS GPU Tweak III, GeForce Game Ready Drivers
HDCP 2.3, DisplayPort 1.4a
6.5 cm
30.5 cm
13.8 cm
