Asus Transformer Mini T102HA 10.1" Z8350 4GB 64GB Windows 10 - White/Gold
Quicklinx: D142WS00 Mfr#: T102HA-GR043T
The ultra-thin, feather-light, 10.1-inch ASUS Transformer Mini is two amazing devices in one! Built from magnesium-aluminum alloy, it’s a less-than-800g 10.1-inch ultraportable 2-in-1 with up to 11 hours of battery life, and it supports all the great new features of Windows 10!
The Best Materials, for the Best Mobility
Built from strong but incredibly light magnesium-aluminum alloy, Transformer Mini is ultra-thin and feather-light, with a tablet that's just 8.2mm thin and weighs a mere 530g! Even with the keyboard attached, it's still a slender 13.9mm thin and weighs less than 800g, so you'll never have an excuse to leave your Transformer Mini at home. Working (or playing!) on the go has never been so easy.
Convenient Smart Hinge Design
Using a Smart Hinge design that gives the stepless kickstand up to 170° of movement, Transformer Mini lets you adjust the display to any angle you wish. So wherever you’re using Transformer Mini — in the office, at home, or on your lap — you can always work or play in total comfort. Take Transformer Mini, wherever you go!
Easy One-touch Access
We wanted to make Transformer Mini always ready to use at any time, so we’ve given it a clever auto-scanning fingerprint sensor- Instant ID. This supports the new Windows Hello feature, so you can unlock Transformer Mini instantly with just a single touch!
Enjoy Brighter and Clearer Watching Experience
Transformer Mini T102HA looks amazing, and so does its gorgeous HD display. With up to 400cd/m² brightness, and thanks to 178°wide viewing display technology you can enjoy bright, vivid and clear images from almost any angle! The dual side-mounted stereo speakers create an immersive surround-sound effect, and exclusive ASUS Tru2Life video enhancement and TruVivid direct-bonding technology make sure you always see the best possible images, with sharp, realistic videos and fewer annoying reflections.
Define Your Unique Style
You’re an individual, and so is Transformer Mini! With four fun keyboard colors to choose from and two fresh and vibrant tablet colors, you can mix and match to reflect your own unique style.
Outstanding Performance!
The powerful quad-core Intel® Atom™ x5 Processor in the Transformer Mini T102HA has up to 10% more processing power than its predecessors, plus up to twice the graphics performance. With a massive 4GB of RAM, so you’ll rarely experience such slowdowns. So you’ll have no problem breezing through all your everyday tasks, with seamless multitasking allowing you to get more done in less time.
Every Connection You Need!
Even though Transformer Mini T102HA is incredibly slim and light, it has all the ports you need to connect devices on the go, including USB, micro USB, micro HDMI, Micro SD and a headphone jack. And even better, all these ports are on the tablet, so they’re always available. T102HA is small in size, but big on connectivity!
ASUS Transformer Mini T102HA GR043T
Sustainability Information
TCO Certified
