Let's admit it - carrying both a tablet and a laptop is a nuisance. The T100HA is a 2-in-1, which means exactly what it says - it's a laptop with a keyboard. So it's two devices, in one amazing package. It's a simple idea that's elegant and convenient, too. Need to work? It's a powerful laptop. Time to relax? Detach the keyboard and it's a handy tablet. No fuss, no hassle. What's more, it's the only 2-in-1 with the revolutionary time-saving USB 3.1 Type-C port. And with up to an incredible 12 hours battery life, it's always ready - for work or play.
Incredible 2-in-1 and amazing battery life
Let's admit it - carrying both a tablet and a laptop is a nuisance. The T100HA is a 2-in-1, which means exactly what it says - it's a laptop with a keyboard. So it's two devices, in one amazing package. It's a simple idea that's elegant and convenient, too. Need to work? It's a powerful laptop. Time to relax? Detach the keyboard and it's a handy tablet. No fuss, no hassle. What's more, it's the only 2-in-1 with the revolutionary time-saving USB 3.1 Type-C port. And with up to an incredible 12 hours battery life, it's always ready - for work or play. -
Brilliant design, brilliant colors
With a lid finished in ultra-cool anodized aluminum, T100HA is not just designed to make a style statement. Yes, it's elegant. And of course it's sophisticated. But it's also durable and practical - and it feels great. -
Even thinner even lighter
The original Transformer Book T100 was no heavyweight, the tablet is 20% thinner than before, so you'll never have an excuse to leave it at home. Take it everywhere, store it anywhere. -
12 hours of battery power
The ultimate portable companion deserves the ultimate stamina, and with up to 12 hours battery life you can rest assured it will keep going as long as your mobile lifestyle demands. -
USB just got smarter
Sometimes, smaller can be better. The humble USB port is great, but it's definitely a bit clunky, and can be awkward to plug things into. The version of the USB port, called a Type-C port, is much smaller than a standard USB port, but it does just as much and has the extra benefit of being reversible. So there's no more struggling to work out which way up a connector is when you want to plug it in. And you still get the blindingly-fast capabilities of SuperSpeed USB 3.0, so data transfers are quick and speedy - up to 10 times faster than USB 2.0.
- ASUS Transformer Book T100HA-FU029T - 10.1" - Intel Atom x5 - Z8500 - 4 GB RAM - 64 GB eMMC
- Product Type
- Tablet - with keyboard dock
- Operating System
- Win 10 Home 64-bit
- Processor
- Intel Atom x5 Z8500 / 1.44 GHz, up to 2.24 GHz / 2 MB Cache
- Memory
- 4 GB LPDDR3 (provided memory is soldered)
- Storage
- 64 GB eMMC
- Display
- 10.1" LED backlight touchscreen 1280 x 800 / WXGA
- Graphics
- Intel HD Graphics
- Input Device
- Keyboard, touchpad
- Integrated Webcam
- Networking
- 802.11a/b/g/n, Bluetooth 4.0
- Battery
- 2-cell - up to 12 hours
- Asteroid grey
- Dimensions (WxDxH) - tablet
- 26.5 cm x 17.5 cm x 8.4 mm
- 500 g
- Environmental Standards
- ENERGY STAR Qualified
- Specific Absorption Rate (SAR)
- 0.462 W/kg (body) , 0.462 W/kg (limb)
- Product Type
- Operating System
- Windows 10 Home 64-bit Edition
Processor / Chipset
- CPU
- Max Turbo Speed
- 2.24 GHz
- Number of Cores
- Quad-Core
- Cache
- 2 MB
- 64-bit Computing
- RAM
- 4 GB (provided memory is soldered)
- Technology
- LPDDR3 SDRAM
- Speed
- 1600 MHz
Storage
- Main Storage
- 64 GB eMMC
Display
- 10.1"
- LCD Backlight Technology
- LED backlight
- Touchscreen
- Resolution
- 1280 x 800 (WXGA)
- Widescreen
- Image Aspect Ratio
- 16:10
- Image Brightness
- 350 cd/m²
- Colour Gamut
- 60% NTSC
- Detachable, glare, WideView
Audio & Video
- Graphics Processor
- Intel HD Graphics
- Camera
- Resolution
- 5 Megapixel (rear), 2 Megapixel (front)
- Sound
- Stereo speakers, microphone
Input
Communications
- Wireless
- Technology
- 2-cell lithium polymer
- Capacity
- 30 Wh
- Run Time
- Up to 12 hours
- Battery Run Time
- Video playback: up to 12 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 10 Watt, 5 V, 2 A
Connections & Expansion
- Micro-HDMI , Headphone/microphone combo jack , Micro-USB 2.0 , USB 2.0 , USB-C
- Memory Card Reader
- 2 in 1 (microSD, microSDHC, microSDXC)
- Asteroid grey
- Case Material
- Plastic, metal
- Included Accessories
- Power adapter
- UL, BSMI, CB, CCC, MIC, FCC, RoHS, GOST-R, CECP, iDA, ErP 2013
- SAR Value
- 0.462 W/kg (body), 0.462 W/kg (limb)
- 500 g
- Dimensions (WxDxH) / Weight Details
- 26.5 cm x 17.5 cm x 1.84 cm / 1 kg - tablet with keyboard
Sustainability Information
- ENERGY STAR Certified
C2G 5m USB 2.0 A/B Cable - Black | In Stock | £5.74 |
