Asus STRIX SOAR Gaming Soundcard 600ohm Headphone Amplifier
Quicklinx: BQ8LWS00 Mfr#: 90YB00J0-M1UA00
Interface: PCI Express
Sound Output Mode: 7.1 channel surround
  • Windows 8 (32/64 bits)
  • Windows 8.1 (32/64 bits)
£66.41 ex VAT
£79.69 inc VAT
Strix Soar is a gaming sound card built with high-performance components to satisfy gamers who demand pure, full-sounding audio. Strix Soar features rich, immersive, and clear sound with an incredible signal-to-noise ratio (SNR), and the headphone amplifier for deep, tight bass. The simple yet powerful Sonic Studio sound utility provides complete sound card control and allows easy in-game audio adjustments.
  • Gain the gaming edge with Sonic Radar Pro
    Precise audio positioning gives gamers a distinct edge over enemies. That's why Strix Soar includes Sonic Radar Pro, the technology that visualizes and enhances in-game sounds, giving you a vital edge in first-person shooters. Fire up your favorite game and Sonic Radar Pro displays a radar HUD (heads-up display) that pinpoints in-game actions relative to your position, so you'll know exactly where you are on the battlefield and what's happening around you.
  • High signal-to-noise ratio (SNR) clarity
    High-fidelity grade DAC delivers unrivaled, jitter-free sound and an exceptional signal-to-noise ratio (SNR) for greater clarity on-board audio.
  • Hyper Grounding technology
    Noise-blocking multi-layer PCB developed with proficiency.
  • Lighting effects
    Express your gaming style with Strix Soar. Its owl-eye design even lights up in the dark.
  • Unleash your gaming instincts
    Strix means keen hearing and sharp eyesight. Strix means feeling your environment so that you detect and react to any slight movement. Strix means survival on the very edge of instinct.
ASUS Strix Soar - sound card
Sound card
Enclosure Type
Internal
Interface Type
PCI Express
2.2 cm x 19 cm x 13 cm
480 g
Signal Processor
CM6632AX
Sound Output Mode
DAC Resolution
24-bit
Sample Rate
44.1 kHz (min) - 192 kHz (max)
Signal-To-Noise Ratio
116 dB
Microsoft Windows 7 (32/64 bits) SP1, Windows 8 (32/64 bits), Windows 8.1 (32/64 bits)
Sound card
Internal
Interface Type
PCI Express
2.2 cm
19 cm
13 cm
480 g
Processor / Memory
Signal Processor
CM6632AX
Audio Output
Sound Output Mode
DAC Resolution
24-bit
Sample Rate
116 dB
Frequency Response
10 - 48000 Hz
Headphone Amplifier, Hyper Grounding Technology, Sonic Radar Pro
ASIO 2.0
Audio Modes
Record: 24-bit 192 kHz , Playback: 24-bit 192 kHz
1 x headphones - mini-phone 3.5 mm , 1 x speakers (front surround) - mini-phone 3.5 mm , 1 x speakers (center/subwoofer) - mini-phone 3.5 mm , 1 x speakers (side)/SPDIF output - mini-phone 3.5 mm , 1 x speakers (rear) - mini-phone 3.5 mm , 1 x audio line-in/microphone - mini-phone 3.5 mm
1 x S/PDIF optical adapter
Software
Sonic Studio
BQ8L C2G 2m 3.5mm M/M Stereo Audio Cable In Stock £4.29
BQ8L C2G 3.5mm Stereo Male to Dual 3.5mm Stereo Female Adapter In Stock £4.44
BQ8L C2G 3m 3.5mm M/M Stereo Audio Cable In Stock £4.52
BQ8L C2G 2m 3.5mm M/F Stereo Audio Extension Cable In Stock £4.08
BQ8L C2G 5m Velocity™ 3.5mm M/M Stereo Audio Cable In Stock £7.09
BQ8L C2G 6.3MM STEREO MALE TO 3.5MM STEREO FEMALE In Stock £4.44
BQ8L C2G 10m Velocity™ 3.5mm M/M Stereo Audio Cable In Stock £11.35
BQ8L C2G 3.5mm Stereo Male to 6.3mm Stereo Female Adapter In Stock £4.29
Brand: Asus
Price Range Ex VAT: 50 - 100
