Asus STRIX RAID DLX Gaming Soundcard 124dB SNR Raid Mode & Contrl
Quicklinx: BQ8QWS00 Mfr#: 90YB00H0-M1UA00
  • Windows 8 (32/64 bits)
  • Windows 8.1 (32/64 bits)
Strix Raid DLX is a premium sound card set built with audiophile-grade components to satisfy gamers who demand ultimate audio performance. Strix Raid DLX features rich, immersive, and clear sound with an incredible signal-to-noise ratio (SNR), and a headphone amplifier for deep, tight bass. The simple yet powerful Sonic Studio sound utility and control box provides complete sound card control and allows instant in-game audio adjustments.
  • Gamer-friendly design
    Raid Mode can be turned on right in the heat of gaming action with just one click on the audio control box to provide the exact audio adjustment you want. With this powerful combination of Raid Mode and the audio control box, gamers no longer need to pause the game and open sound software to adjust their audio, ensuring they don't miss a single moment of gaming action.
  • Gain the gaming edge with Sonic Radar Pro
    Precise audio positioning gives gamers a distinct edge over enemies. That's why Strix Soar includes Sonic Radar Pro, the technology that visualizes and enhances in-game sounds, giving you a vital edge in first-person shooters. Fire up your favorite game and Sonic Radar Pro displays a radar HUD (heads-up display) that pinpoints in-game actions relative to your position, so you'll know exactly where you are on the battlefield and what's happening around you.
  • High signal-to-noise ratio (SNR) clarity
    High-fidelity grade DAC delivers unrivaled, jitter-free sound and an exceptional signal-to-noise ratio (SNR) for greater clarity on-board audio.
  • Sound detail boost with the integrated headphone amplifier
    The powerful headphone amp lets you experience the full potential of your gaming headset. It provides enhanced bass and clear, detailed sound.
  • Hyper Grounding technology
    Noise-blocking multi-layer PCB is developed with proficiency.
  • Lighting effects
    Express your gaming style with Strix Soar. Its owl-eye design even lights up in the dark.
  • Unleash your gaming instincts
    Strix means keen hearing and sharp eyesight. Strix means feeling your environment so that you detect and react to any slight movement. Strix means survival on the very edge of instinct.
ASUS Strix Raid DLX - sound card
Sound card
Enclosure Type
Internal
Interface Type
PCI Express
2.2 cm x 19 cm x 13 cm
Signal Processor
CM6632A
Sound Output Mode
7.1 channel surround
DAC Resolution
24-bit
Sample Rate
44.1 kHz (min) - 192 kHz (max)
Signal-To-Noise Ratio
124 dB
Microsoft Windows 7 (32/64 bits), Windows 8 (32/64 bits), Windows 8.1 (32/64 bits)
Sound card
Internal
Interface Type
PCI Express
2.2 cm
19 cm
13 cm
Processor / Memory
Signal Processor
CM6632A
Audio Output
Sound Output Mode
DAC Resolution
24-bit
Sample Rate
124 dB
Frequency Response
10 - 48000 Hz
Headphone Amplifier, Hyper Grounding Technology, Sonic Radar Pro
ASIO 2.0
Audio Modes
Record: 24-bit 192 kHz , Playback: 24-bit 192 kHz
1 x headphones - mini-phone 3.5 mm , 1 x speakers (front surround) - mini-phone 3.5 mm , 1 x speakers (center/subwoofer) - mini-phone 3.5 mm , 1 x speakers (side)/SPDIF output - mini-phone 3.5 mm , 1 x speakers (rear) - mini-phone 3.5 mm , 1 x audio line-in/microphone - mini-phone 3.5 mm
Control box
1 x S/PDIF optical adapter
Software
Drivers & Utilities, ASUS Instant On, Sonic Studio
